BUSH 19" lcd pink model no. BTVD91186P. standby
3 Suggested Answers
jhinsincity
  • 616 Answers
SOURCE: Digistar PH-4210D Black Screen
Plasma tvs do not have "back lights" LCDs do. you probably have a bad driver board along with the upper or lower buffer board or maybe both, best to have a tv shop look at it.
Posted on Aug 30, 2009
  • 9 Answers
SOURCE: INSIGNIA LCD won't turn on
replace 2 condensers in the power supply with greater voltage ones.original are 1000uf 35volt...use 1000uf 65volt...99cents each
power circuit is made to fail with typical tv industry tactics...the warranty is reflected by the life of their condensors (capacitors) average life is 2000 hours..
easy...huh
if your a smoker...you must clean the button cover as they get stuck on with your stupid tobacco residue. 75% of all LCD tv's that smokers own fail this way...
\tough huh?
TRY TO STOP SMOKING...
Posted on May 18, 2009
The blue standby light on my bush 19" lcd tv stays on all the time but i get no picture or sound can you help.
The II2 Bus has the fault. It detects some malfunction from other circuit boards. Your TV need a through checkup. Contact any experienced service technician, as the work is a very skilled one, and not a user reparable.
Jan 05, 2013 | Televison & Video
Hi! I have a 32" LCD led backlit bush tv (not sure
Yes, all the issues point to a problem in the standby power supply which runs 7/24 if the set is plugged into wall power--get it taken care of under warranty before it really fails bad.
Dec 17, 2012 | Televison & Video
Tv switching on and off by itself on standby
Check ur power source,like the other electronic equipments that plug into that wall outlet have power and working?Yes?Than the tv power supply board it is the problems and the causes.That the board where the tv power a/c cord plug into it.The tv power supply board it is shorting out and dying to causes this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new tv refurbish power supply board for the replacement.
Aug 29, 2011 | Bush Industries IDLCD26TV16HD LCD TV
Im after a bush ac power adaptor for a LCDS20TV011
You could get one from ebay , but they seem very expensive. http://cgi.ebay.co.uk/24V-AC-power-adapter-Bush-1LCD23TV022-LCD-TV-/360224352429?pt=Televisions&hash=item53df0b68ad#ht_2521wt_1094 (It does say make an offer)
Other models may use the same supply and its cheaper, You could check with the vendor if a cheaper one is suitable for the Bush, after all why pay more for the same thing. http://cgi.ebay.com.sg/24V-AC-power-supply-adapter-BenQ-FP231W-Q23W3-LCD-TV-/330393378073 You just need to make sure the current/wattage and the plug on the end are the same.
Jan 17, 2011 | Bush 24v Ac Power Adapter For Bush...
Element stuck in standby and wont turn back on.
you can unplug the power cord and drench the power and after go ahead and plug in back the TV and try to start it
Jul 30, 2010 | Element Electronics FLX-1910 19 in. LCD...
19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
Apr 17, 2009 | AOC 917Sw 19" LCD Monitor
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Gateway FPD 1960-uk 19 " LCD?TFT Monitor keeps going into standby
It sounds like the monitor whose writing comes up in pink has a problem with the RGB usually IC driven and all of them sound like they have faulty power supply boards. Will investigate further and give a more detailed answer. Hope this helps for the time being.
Oct 11, 2007 | Gateway 19" Flat Panel LCD Monitor
Televison & Video Logo
177 people viewed this question
Top Televison & Video Experts
