Question about Scosche Industries Scosche Kia 07-up Amanti Din Install Dash Radio Kit
How to replace a 2007 kia sorento alternator - Scosche Industries Scosche Kia 07-up Amanti Din Install Dash Radio Kit
Show me how Alternator relay on 2011 Kia Sorento look like
Alternators don't have relays. An alternator is a generator of power to charge the battery. Relays are electronic switches using a small amount of power to open and close a larger switch with high amps.
Alternator relay on 2011 Kia Sorento Google Search
Dec 28, 2016 | 2011 Kia Sorento
My kia 2007 sorento cd player has error code 5 and ejects cd model no K200S0-A manual only goes to error 4
You might need to replace it with an aftermarket stereo or go to the dealership or a reputable car audio shop!
Jan 04, 2015 | 2007 Kia Sorento 4x4
Kia Sorento 2007:My windshield wiper stops on wrong side, what can I do?'.
If the wipers are consistent in where they stop the problem may be due to the splined shaft of the drive motor has rotated within wiper linkage attachment. Remove motor/linkage assembly remove linkage from motor and check for stripped splines on the linkage/motor. Willie
Jan 04, 2013 | 2007 Kia Sorento 4x4
My Kia Sorento automatic 2007 44k lost power and now wont go over 2000-2500 revs I don't seem now to have kick down
no check engine on possible fuel pump problem or converter plugged check airfilter and exhaust if the gas is escaping
Mar 25, 2012 | 2007 Kia Sorento LX 4x4
Replacing drive belt for Kia Sorento
You have three belts on your sorento
one for the A/C
one for power steering
And one for the alternator
to remover the power steering and alternator you need to loosen the tensioner center nut, then loosen the tensioner adjuster bolt. its easier to explain with a diagram.
to remover the alternator belt, you have to do that from under the car, which means removing the lower engine cover. the same methods applies to the alternator belt, loosen the tension centre nut, then loosen the adjuster bolt.
by they way, sorentos with the new 3.8 engine have only one belt, thats 2007 and up.
have fun
Jan 17, 2010 | 2004 Kia Sorento
Kia sorento diesel 2007. Lost of power when going
Your problem is the TPS sensor, check with your dealer, the replacement is very cheap.
Oct 10, 2009 | 2007 Kia Sorento LX 4x4
Scosche Industries Scosche Kia 07-up Amanti Din Install Dash Radio Kit Logo
128 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
