Question about Saws
Hi i need a parts diagram/exploded view of saw blade for a macallister 1800 circular saw with laser eye .i lent it to a friend and on its return the blade on the spindle spins freely . i saw someone e
The blade in it is a 30mm bore with a 20mm reducer,sits on the shaft fine.but when you but the top washer and tighten nut it will not clamp the blade seems to me that ther should be a small washer at the base of the spindle to raise it all up so it will clamp down tight .any one have any suggestions please
    Champion:
  • 304 Answers
MAke sure there is not two reducer washers on the machine, sometimes the old one gets stuck on the back flange and when you fit the new blade it does not clamp properly.
Posted on Jan 06, 2013
4 Suggested Answers
  • 30 Answers
SOURCE: Craftsman circular saw. The
Depending on your budget, I suggest replacing the item. It sounds like your bearings are bad, which means tearing apart the case and replacing them (which don't cost much). There are two bearing encasements so you would need to replace both. If you're up for the challenge, give it a try! The bearings can typically be found on the manufacturers website.
Posted on Aug 30, 2010
HansPP
  • 2510 Answers
SOURCE: cannot tighten blade on old craftsman circular
Is the washer/spacer in the blade too thick and you are perhaps tightening up on that instead of the blade. Also check the threads on the bolt, see if the bolt turns all the way in without the blade in position. It may be jamming up before gripping the blade.
Posted on Jan 24, 2011
  • 36514 Answers
SOURCE: circular saw motor turns when tightening saw blade
Insert a tool such as a screwdriver across the blade guard and against a tooth to prevent blade rotation, then tighten the blade nut. Be sure to remove the wedging device before operating the saw
Posted on Dec 29, 2012
Replacement laser for macallister circular saw
Fixya does not sell replacement lasers.
Oct 20, 2016 | Saws
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
How to reinstall saw guard on Mac Allister MAC185LS?
Never heard of this brand of saw. A Google search indicates that MacAllister only makes big earth moving equipment. Otherwise, most saws have an appropriate washer and retaining clip that holds the guard on. And you'll need the original spring to return the guard to the closed position every time you use it. Then there are two shaped washers that fit on the armature that have a 5/8" shoulder to fit a normal saw blade. Finally there is the nut that holds everything on. Hope you didn't lose all these parts. If you did, go to eReplacementparts.com and and enter your make and model. If they don't have what you need you might be plum out of luck. But a new saw.
Oct 03, 2014 | Saws
Washers that hold blade in place
Go to eReplacementparts.com. Enter your make and model and find your part.
Sep 12, 2014 | Master Mechanic 13-Amp 7-1/4-Inch Circular...
Motor runs, saw not cutting
Hi
If motor is running and the blade is not turnning the motor pinion gear is damage.
Go see this link for parts diagram.
http://www.ereplacementparts.com/skil-5500-f012550000-714-circular-saw-parts-c-130_160_843.html
Feb 07, 2011 | Skil 5500 01 7 1/4" 120V Circular Saw Kit...
Can't tighten circular saw blade, actually when it tight the blade is blocked and if I loosen it, is too loose.
You need to use the correct (reduction) ring adapter for the cicular blade you intend to use: the adapter 'washer' needs to be the exact size for the middle blade hole and the motor shaft. If ensure, as it is a lethal tool, ask your friendly hardware shop handyman for advise and direction.
Hope it helps.
Sep 27, 2010 | Ace Hardware Power Glide Circular Saw with...
I need step by step on putting blade guard back on Makita LS1013
Go to Makitatools.com and in the header type in your model number and just follow thru till you can download a parts breakdown with exploded view of the guard. Just lay parts out in the order you see them and its not hard to reassemble. Might I ask what happened to guard? If you stilll have problems let me know and I will help. If I have helped you with your request would you please rate this response accordingly. Thank you.
Sep 12, 2009 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Stopped working suddenly
I don't get any hits on a search of Ryobi's parts site, but here's a link to an after market tool parts supplier that has a schematic that shows an exploded parts view and parts list.
I hope you find this will help you to solve your problem....Good luck!
http://www.toolpartsdirect.com/cgi-bin/noframes.cgi/ryobi/TS260
Mar 13, 2009 | Ryobi Circular Saw W/Dual Laser
Saws Logo
134 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
