Question about Toys
My air hogs heli twister banks right on take off but the trim controlls are centered
My air hogs heli twister banks right on take off for some reason. The trim can be turned left or right and controlls the in air banking but mine is centered but the heli still takes off with a bank to the right making the heli unusable because it just crashes into things. The left and right controlls are different in a way that you hold them down to turn the heli in the direction you want but I don't touch them on take off. Please find a solution so I can fly it again.
keithheavili
  • 410 Answers
SOURCE: bmw 330ci m sport automatic 2001 makes a clinging
Explanation:
According to my research and the BMW master mechanic, basically your oxygen sensor is getting an abnormal reading. The abnormal reading will result in the sensor being unable to adapt beyond its +/- 10% threshold to adapt for the fuel/trim mixture. Therefore, either your car is going to run too lean (not enough fuel) or too rich (too much fuel).
Problems:
1) Either your pre-cats oxygen sensors are bad.
2) Fuel pressure regulator
3) Leak in the air intake /vacuum system
I would think that it is probably your oxygen sensors. Replace that and you should be good to go. Thanks for rating my response and for using FixYa!
Posted on Jun 30, 2009
bschilz
  • 2049 Answers
SOURCE: Diagnostic failed code reads PO172B Fuel Trim
Basically this means that an oxygen sensor in banks 1 and 2 detected a rich condition (too little oxygen in the exhaust).
A code P0172 may mean that one or more of the following has happened:
· The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters can cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
· There could be a vacuum leak
· There could be a fuel pressure or delivery problem
Possible solutions include:
  • Inspect all vacuum and PCV hoses, replace if necessary
  • Clean the MAF sensor. Consult your service manual for its location if you need help. I find it's best to take it off and spray it with electronics cleaner or brake cleaner
    Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
  • Inspect fuel lines for cracks, leaks, or pinches
  • Check the fuel pressure at the fuel rail
  • Check the fuel injectors, they may be dirty. Use fuel injector cleaner or get them professionally cleaned/replaced.
  • Check for an exhaust leak before the first oxygen sensor (this is unlikely to cause the problem, but it is possible)
Posted on Oct 07, 2009
Molson02536
  • 3854 Answers
SOURCE: I have a 2006 kia optima codes are showing trim malfunction
Bank's is the left or right side of the engine. Bank 1 would be where the #1 spark plug side is and Bank 2 is where the #2 spark plug side. This term is used to better describe which side is which on an engine so as to not get confused to which side is which on a engine.
Thank you for using FIxya, what ever code's you have as a trim malfunction. It's indicating a Lean or rich condition on both sides of your engine, try cleaning your MAF sensor and inspecting it for any wire damages. This should fix your trim problem on both banks.
Posted on Mar 25, 2010
  • 1796 Answers
SOURCE: I have a Mercedes s500
Hi!!
What all this codes have in common is that every single one of them can be caused by a vacuum leak, so carefully check for cracked, loose or disconnected vacuum hoses, wiring to the coils, fuel pressure regulator, fuel injectors, specially on cylinder 2.
  • PO100 - Possible causes are wiring harness failure, air leak or defective hot film MAF sensor
  • PO130 - Vacuum leak
  • PO170 - PO173 - Possible causes are air ingress (leak), fuel injector failure, pressure regulator failure or mechanical wear of engine. Inspect and repair as necessary.
  • PO300 - possible causes are vacuum leak, wiring harness failure or ignition coil defective.
  • PO302 - If limit value for misfire "harmful to TWC" is exceeded, the MIL flashes immediately. If too many combustion misfires occur in one cylinder, the cylinder is switched off (cylinder selective fuel shut off). After the affected cylinders are shut off, the MIL changes from flashing to continuously lit until next time the engine is started. If combustion misfires are recognized, the fault code P0460 or P0462 is set if fuel tank level is too low (fuel reserve indicator light is on). Combustion misfires due to a shortage of fuel are recognized by means of this additional information.
NOTE:After cylinder cut-out system is turned off, the system monitors (through misfire detection) if all intake and exhaust valves are open again.
NOTE:Misfiring may be caused by many faults in the fuel injection system. Usually a misfiring fault is stored with faults pertaining to other components. An engine mechanical fault could also cause a misfire condition.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Dec 03, 2010
SOURCE: engine light on code is
Lean reporting on both banks
If the O2 sensors are at 100,000 miles,
replace the front 2 closest to the engine.
If not very old, you will have to look for vacuum leaks
or a long list of other possibles
Posted on Mar 03, 2011
How to correct trimming problems did what the insteuctions said and keep having the same spinning counterclockwise problem
Just bought the air hogs helicopter with the crane. Had the aircraft constantly spinning clockwise, no matter how much I turned the trim control counter clockwise the aircraft still rotated. I then turned the trim control in the opposite direction until I noticed the aircraft had stopped spinning, and used the rudder control to fine tune forward flight. So, get the aircraft to hover and turn the trim button in the opposite direction until you see that the aircraft spinning slows right down. If you continue to turn the trim control in the same direction the aircraft will increase its spin, so just dial back the trim.
Dec 29, 2012 | Air Hogs Havoc Heli Helicopters
My helicopter has no lift even when fully chargered. The props are spinning but it just stays on the ground.
i got a new model havoc heli and the trim buttons did not help at all... in the end I took a motor/prop off of an air hog styrofoam plane I had that was identical to the havoc heli tail rotor and swapped em out.. Problem solved... there was some sort of error with the tail rotor
Mar 22, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
My son's helicopter just spins around and won't lift up anymore. It has been sitting for about a month, but worked fine before that. Any solutions? Could the blades have been bent? They don't look like...
replace batteries with new ones and then you let it spin while you trim it out by pushing rotor button ,for heli that spins clockwise push trim button on left side and a heli that spins counter clockwise push trim button on right side continue pushing the corrective button until spining slows and eventually your sons heli will fly straight again these instructions are in the owners manual
Nov 28, 2010 | Air Hogs Havoc Heli Helicopters
How do i fly my spin master air hog rc helicopter all it does is go in circles
If you trimmed your heli but it still can't work, try using the direction knob to trim it instead. When it goes clockwise push th knob leftwards and hold, and vise versa for anti-clockwise. Or, push and release repeatedly in the direction mentioned till it flies straight. Tested on around 6 air hogs helis and works each time. If you still can't trim you might try it after turning it off or contact the service centre.
Feb 05, 2010 | Spinmaster Air Hogs RC Reflex Micro...
If its a Reflex twin rotor Heli use the trim wheel on top to counteract the spin and at least stabilize the craft at hover. Then use the right/left froward backward fans to control flight, (right joystick on the controller). These fans are not very powerful so don't expect alot from them other than turning the craft right left and reverse. Seems there is too much down draft from the rotors to effectively move the Heli forward. Not a real good design. The Sharpshooter is easier to fly but uses the batteries in the controller as a charger so they don't last real long.
Air hog havoc goes up and down just fine, no steering control
The steering control only makes the copter rotate.
But if the heli is properly balanced a right turn should get you some forward motion. A left turn should just make it spin back to the left.
Adding weight to the front of the copter will give it continuous forward motion. Then you will lose the ability to hover.
If you visit the Air Hogs website (www.airhogs.com), select "need help" and then Havoc Heli, then crash course, the video will show you how it works.
I also find that climbing makes the heli spin left and descending makes it spin right. So full right for initial startup, then a little right when climbing, and a little left when descending helps to smooth things out.
Keep in mind that this is a very small and cheap helicopter. It took me a while to get used to flying in circles to the right but with practice I have been able to get it to go somewhat where I want it to. I can take off and land from the coffee table without crashing.
Jan 15, 2010 | Air Hogs Havoc Heli Helicopters
Spins out of control wont trim out
Have you tried checking the back tail? It comes down right under the rotor. If it is ripped, DONT TAPE IT! Taping will just ruin the weight balance and ruin it. If it is ripped, return it and exchange it, dont try and fix it.
Jun 01, 2009 | Air Hogs Havoc Heli Helicopters
I CAN'T QUITE TURN GOOD YET.
Keep hitting the right trim button till the turning stops.
May 16, 2009 | Air Hogs Havoc Heli Helicopters
My Havoc Heli is really hard to control and I need help.
You have to keep tapping the right trim button. Keep tapping it until it stops spinning. If the spinning stops and it just turns, Use the the left right moving analog un til it flies straight.
Mar 15, 2009 | Air Hogs Havoc Heli Helicopters
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
