Question about Nextbook Tablets & eReaders
My new nextbook is making strange static noises even with the volume down
Next7p12-8g is the model
How do I do factory reset on nextbook model NX17A8116R
NOTE: Doing this will clear the data on your tablet, so it is suggested you not choose this option unless you have to, or aren't worried about losing anything on the tablet.
To "Hard Reset" the tablet...
1. Make sure that the tablet is actually powered off.
2. Press the "Power" and the "Volume Up" buttons, together, until you see the start-up logo on the screen.
3. Once you can see the logo, release the buttons and allow the device to enter the "System Recovery Mode".
4. Next use "Volume Down" button to get to the "wipe data/factory reset" option When in recovery mode the "Volume Up" and "Volume Down" buttons are how to can navigate and highlight what option you need.
5. Once you have selected the "wipe data/factory reset", press the "Power" button to select that option.
6. On the following screen, repeatedly press the "Volume Down" button until the "Yes - delete all user data" option is what is selected.
7. Then press the "Power" button to hard reset the tablet.
Feb 25, 2018 | Nextbook Tablets & eReaders
My son's tablet is less than 4 months old and it keeps shutting off even when fully charged. It is a 9 inch nextbook and was purchased at Walmart.
Hold the volume UP botton down when it is OFF, then while holding that button down press and hold the power on button and keep both pressed for about 10 seconds. Then release.
Feb 23, 2017 | Nextbook Tablets & eReaders
I forgot my password for my nextbook tablet. serial no.yfg0414022138.How do I log into my tablet or reboot it to factory settings?
Press and Hold the Volume Up and the Power Button until the Recovery Console appears. Choose Hard Reset.
Dec 14, 2016 | Nextbook Tablets & eReaders
How can I do a factory reset on my nextbook 7
Simple video on how to hard reset Nextbook Android Tablet. Power off device, select volume up and then power, hold power for 5-7 seconds and let go without releasing volume up. When u get the android menu scroll down to wipe data navigating with the volume buttons and then to wipe data.20 Aug 2013
Nextbook Android Tablet Hard Reset - YouTube
https://www.youtube.com/watch?v=TM-Ir-stVL8 https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=How+can+I+do+a+factory+reset+on+my+nextbook+7
Nov 25, 2016 | Nextbook Tablets & eReaders
How do I do a factory data reset on a nextbook 11
Simple video on how to hard reset Nextbook Android Tablet. Power off device, select volume up and then power, hold power for 5-7 seconds and let go without releasing volume up. When u get the android menu scroll down to wipe datanavigating with the volume buttons and then to wipe data
Sep 29, 2016 | Nextbook Tablets & eReaders
NEXTBOOK 8 ,WITH WINDOWS 8.1, WENT INTO REPAIR LOOP, AND HOLDING POWER BUTTON AND VOLUME BUTTON WONT BRING UP MENU . NEED A FIX BAD
press power, press home button + volume at the same time a menu should appear in top corner , once that shows leave go of all three buttons then with volume press down and when you reach the heading you need press power . YOU DO THIS ONCE YOUR NEXTBOOK 8 IS TURN OFF ( make sure battery is in ).
Dec 23, 2015 | Nextbook Tablets & eReaders
How do I get into the nextbook if I forgot my password
NOTE: This procedure will reset your device. Any changes you have made since you last backed up your device will likely be lost.
To Reset you Nextbook:
  • Hold power button and volume down until a menu appears.
  • Using the volume buttons, select Wipe Factory settings" (or something to that effect..may vary depending on your model)
  • There will then be a list of no`s and 1 yes. Using the volume buttons select Yes. Then select reboot.
Once rebooted, follow the instructions to reconfigure and then restore your apps from backup.
These instructions were gleaned from various articles found on the internet. Hope this help.
Jan 25, 2015 | Nextbook Premium 8 Se Android
Nextbook has no sound
hi there.
see if this link helps you out.
Nextbook has no sound Google Search
Nov 19, 2017 | Tablets & eReaders
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Sep 20, 2012 | Nextbook Tablets & eReaders
Tablets & eReaders Logo
120 people viewed this question
Top Nextbook Tablets & eReaders Experts
D. E. Hev
Tom
Dustin
Dustin
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
