Question about Dacor ECS230 Epicure Electric Double Oven
Double oven ECS230BK Dacor lower door wont close completely
Can it be adjusted .and if so can you advise
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
  • 29 Answers
SOURCE: Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Posted on Sep 22, 2008
SOURCE: Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Posted on Nov 20, 2008
barkencoa
  • 3463 Answers
SOURCE: Oven door isn't closed tightly on both sides.
If it is a door that lifts up and down, then the only solution is to replace both door hinges, as they are not normally adjustable, it is the springs that are weak.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
  • 3 Answers
SOURCE: Dacor double oven, lower oven works fine, upper
I had the same problem after auto-cleaning my oven just before Thanksgiving. The cause was overheating...and the tripping of a heat sensor switch.
The switch (reset button) is located about 3 inches behind the door locking mechanism.
Removing the front panel (4 screws) that the door lock sticks through exposes the switch. Just push the little red button & your are back in business!!
Posted on Nov 27, 2009
My ge double oven326b1230p001 the top door is not closing properly and the light keep on,please advise how to close top door
Oven Range Door DIY Repair - YouTube
? 2:50
www.youtube.com/watch?v=6YFTYWsiO1M
Jan 22, 2011 - Uploaded by ApplianceAdvice Watch Queue. TV Queue. __count__/__total__. Find out why.Close ... This video explains how to remove an oven door on many higher end ovens, such as GE, Kitchen Aid, Kenmore, Whilrpool, Dacor, ... Top comments ... fell off and the screws fell down into the oven door and I did not know how to fix it.
Aug 08, 2015 | GE Ovens
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
ECD230 dacor oven, th bottom door isn't sealing all the way, you can feel heat escaping. Is there an adjustment to make?
jenn air had some issues with there hinges wearing fast in prior years on there ovens and then you have the ones the kids use as a trampoline sometimes or the heavy turkeys laying on the door while it is opened... there really isn't any adjustment for the door the hinges bolt inside and are held in one place by a few screws ...they are replaceable as welll as the door gasket on the unit... hope this helps you out some... alot of the appliance sites out there will be able to assist you with parts such as www.sears.com then click the parts direct link up top have your model number usually inside unit either on door or inside where door closes... some units between door and cabinet area... good luck to you
Jan 13, 2011 | Dacor ECD230 Epicure Electric Double Oven
Both oven doors do not close properly. lights stay on & can't heat properly with doors not closing tight. is there an adjustment for these doors?
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Jan 04, 2011 | Jenn-Air WW27430P Stainless Steel Electric...
Dacor double oven, lower oven works fine, upper oven doesn't turn on at all
Nov 14, 2009 | Dacor ECD230 Epicure Electric Double Oven
Moffatt double oven 4175 lower oven door springs broken
My problem was not with an Amana single oven but aMoffatt double oven ! However I have now decided to buy new.
Oct 31, 2009 | Amana AEW3530DD Electric Single Oven
Thanks.
Jan 05, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor Double Oven
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Lower oven door
here is my video might help you.
Mar 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Dacor ECS230 Epicure Electric Double Oven Logo
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
