My low beams do not work but my high beams do. When i turn the low beams on from inside the car only the outside (blinker) lights turn on. Ive replaced the bulbs and the fuses and i do not know what is wrong.
Im just curious if you found a fix for this issue because I'm curently having the same problem with 98 civic?
There are two filiments in each headlamp; one for low beams, and the other for high beams. It is possible that the both right and left low beam filiments burned out at nearly the same time. Otherwise, there may be a fuse, or headlight relay that is causing the problem. If all these check out good, it may be your headlight switch needs to be replaced.
Mark
