Question about Pool & Spa
Hydropool Spa H575 heats up ok then when it shuts down "FL" (flow switch) reads out - when reset it will come back on
  • 990 Answers
SOURCE: Pool Heater Mis-reading Temp.
Your temp sensors are on the heater, a small tube that slides into the water manifold, usually on the left side. On the remote it will be in one of the pipes coming from the pump or the filter. If it is after the heater you should move it to between the filter and heater. It will be a tube that is in the pipe with a stanless steel clamp holding it in place.
To find out wich one it is you will need to remove the remote from the system by takeing the wires that go to it from the wireing inside the heater and wire nuting the wires in the heater together. If the heater runs normal then it is the sensor for the remote if not it is the sensor for the heater. Let me know how you do and if need be we can get a little more specfic for your system. good luck.
Posted on Mar 29, 2010
  • 366 Answers
SOURCE: How do you replace a flow switch in a spa, or hot tub
turn off the power to the spa. remove the cabinet under the topside remote to expose the equipment compartment. You should see the flow switch, it's usually a threaded 3/4" plug with a single grey wire coming out of it. Most of them are threaded into a tee or a special transparent fitting. If the water level in the spa is above the flow switch, you may have to drain the spa down unless you're very fast about getting the new switch in. Unthread the old switch and thread the new one in. Follow the wire on the old one to the spa pack. You'll have to remove the screws on the cover to expose the circuit board. Follow that wire into the spa pack to see where on the circuit board that it is plugged in. It may be good to run the new wire to have in place as soon as you unplug the old one you can install the new one with no question as to where it plugs in.
Reinstall the cover on the spa-pack and turn the main power back on. Make sure that the arrows on the new flow switch are facing the correct direction (direction of flow). Once you have the spa on and it starts back up, run everything to check for leaks and proper operation. If the flow switch was the only problem, all your faults should be cleared and you should be in good shape. If there are no leaks, you can reinstall the cabinet panel.
The new switch should already have teflon tape on the threads, if not, use teflon tape, apply the tape in the direction as if you were threading a nut onto the threads. You only need a few wraps of teflon tape, too much can crack the fitting you threat the new flow switch in to.
Posted on Nov 07, 2009
  • 366 Answers
SOURCE: I have a Jacuzzi spa that has a FL on the read out.
the FL code is usually an insufficient flow fault. you may have a dirty filter or a faulty flow switch/sensor.
Posted on Dec 28, 2009
Ian  Hot Tub
  • 77 Answers
SOURCE: over heating
Try turning the power off and back on again.
If this doesn't solve the problem you have further issues.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
thepool
  • 78 Answers
SOURCE: i have a Raypak Digital Millivolt pool/spa htr which stopped heat
Don, I suspect the error message is the cause of your problems. A flow error is either real (low flow) or not (bad flow switch). Either way, you get the error code displayed. Always take the filter out of the equation first to make sure it's just not a dirty filter causing the issue. A sand filter can be placed in the "bypass" position or a filter cartridge could be removed. Restart the pump and see if the error code goes away. If it does, clogged filter, real flow problem. Clean / replace the filter. If it does not go away, locate the pressure switch, pull off the two leads and jump them together. If the code goes away, false problem, bad switch. Replace it. Rob
Posted on Apr 22, 2010
Jandy Spa haeter flashing FL 0 code, what can I do to fix it?
showing no flow check the filters make sure in spa mode if heating spa check pressure switch and safety circuit
Jun 21, 2014 | Jandy Pool & Spa
Hydropool hot tub
Check your filter. It may be clogged. This will restrict flow and prevent the pressure/flow switch from actuating. The heater will think that water is not flowing and not allow the burner to produce heat.
Jan 31, 2014 | Pool & Spa
Control panel and no pumps
do you have the control box cover off? some have a safety switch that will shut the tub down if the cover is removed..find this button and tape it down.. check the rest of the switches for proper operation..either from remote or on the unit..its a process of elimination thing.. I have been doing this for 4 days on our tub.. its finally heating now..only thing is the air blower is not working..
Jan 05, 2014 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
Spa Heater problems- Balboa VS-501 controls #54356.
Use a high quality external temp probe and make sure the temp sensor in your system is correctly reading the water temp.
If the water is truly 110 then you may need to replace the board completely.
Jun 20, 2017 | Pool & Spa
What does the "FL" code
Fl stands for FLOW error code. This means that either the pump is not pushing enough water, or the pressure switch that senses water flow through the heater is not functioning. This are inexpensive and easy to fix yourself if it is just the pressure switch. Look on or near your heating element for a small disk switch with two wires coming out of it. Remove and replace this part.
Feb 15, 2011 | Qca Spas Dream Series Dream Master Hot Tub...
When my spa runs thru its heat up cycle and gets to temp it shuts off and shows FL on my temp pad. I have to shut power off to spa and reset it all before it will start again.
Thank you for posting your question here on Fixya.com.
Generally speaking, an FL error, or any error with FL in the message, deals with flow switch failures. The switch ensures there is enough system flow so the heater will not over-heat the water. It may be the switch itself is bad but you should first check for system problems that will cause this switch to open.
Assuming your pump is on and any valves in your pipes are set correctly it could indicate something is restricting water flow too much and needs to be cleaned to fix your flow rate and allow the heater to switch back on.
Start at the skimmer(s) baskets and then the pump strainer basket if so equipped. You should also clean your filter(s). If your cartridge(s) are older, washing them off may no longer return them to a clean enough state to allow enough water to flow. At start up there is enough flow to close the switch but as the water starts to circulate they quickly load up. The switch remains closed until the system shuts off the first time but then will not re-close until the system has settled enough. At least that is one possibility.
If nothing changes after this maintenance you should replace the switch. You do not need to buy the exact same part; only one rated to operate at the same voltage and that has the same method of connecting it to the pipe well.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Dec 14, 2010 | Plumbing
My jacuzzie starts and stops wen it is runing i have a fl code
FL is a flow error, you may not have enough water going over filter housing. Jets are they open?
is your heater fitted with a pressure switch? when on FL locate pressure switch wheel and turn all the way anti clockwise until it stops then slowly wind back until you hear a click reset in control box - you have reset pressure switch.
If you have done this and still show FL or heater is not fitted with pressure switch then your LOW speed on pump maybe faulty (new pump) or heater maybe scaled up with lime scale and reducing water flow through heater - remove scale from heater, flush through and increase ANTI-SCALE
Adam Miller
Service Manager, Canadian Spa Company, UK
Aug 07, 2010 | Jacuzzi Pool & Spa
Dec 27, 2009 | Pool & Spa
It heats the pool but the hot tub gets warm for ten min then the heater shuts off ???
ARE THE TEMPETURE SET HIGH IF YES THEN THE FLOW VALVE IS BAD . WHAT ABOT THE FLOW TO THE SPA CHECK THE PRESSURE READING WHEN SWITCH FROM POOL TO SPA IF VERY HIGHT THE JETS MAY BE PLUG MAKING THE FLOW TO SLOW FOR THE HEATER TO WORK OK
Dec 01, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool & Spa Logo
493 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
