Question about Health & Beauty
How do you install the batteries in a Conair WW398WC weighing machine?
I can't get this machine to work. There are two batteries included but I don't know the eright way to put them in or if one battery is spare. It says to tap the machine once the batteries are installed but when I do this nothing happens. What do they mean by tap - a light-fingered tap or are you supposed to take a hammer to it?
SOURCE: conair ww39 glass bathroom scale won't work- batteries in wrong maybe? Help please!
Googled around until I found specifications for an unrelated brand of a similar bathroom scale. It mentioned making sure batteries were flat side uppermost in their compartment, which did the trick.
Posted on Sep 26, 2008
  • 3 Answers
SOURCE: err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Posted on Oct 17, 2009
SOURCE: replace battery
OK, I just (11/29/09) replaced the battery on Conair TH301S glass scale. You will need a CR2032 (3V) battery, a small (P12) phillips screwdriver, a flat screwdriver and a small twiser (to hold small screws).
On a stable and clean surface (kitchen table, no kids around due to small screws) lay flat upside down the scale.
1) Remove all 6 phillips screws that hold the inner frame.
2) With the help of the flat screw driver unhoock each side of the inner frame (horse shoe shape)
3) Open slowly because there are 2 wires that connect the weight sensors and lay flat on the side.
4) There is an eletrical circuit beside the display, it is being held by 5 very small phillips screws (remove them)
5) The you will find underneath a small round black box held by 3 phillips screws. Remove them, open slowly the top cover and inside reside the battery, pop it up gently with the flat screw driver.
6) Replace the battery, reinstall the 3 screws.
7) Where the display stand, remove the 4 screws of the plastic cover. Slowly remove the cover and the LCD display itself (pay attention on how the display is installed).
8) Re install the circuit board with the 5 smaller screws
9) With a QTips and alcohol clean the contacts of the circuit board where the LCD dispaly sits. Sit in place the LCD display (it will touch the circuit from above) .
10) Place the plastic cover with the 4 screws.
11) re install the frame and put the 6 screws.
12) YOU HAVE DONE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Nov 29, 2009
  • 5 Answers
SOURCE: scales not working properly- weighing too light
scale may need to be calibrated or you may have something causing the scale to be unstable or something could be binding
Posted on Mar 13, 2010
SOURCE: Problem changing battery for Conair Thinner Scale TH300
My scale is an older model, "can't locate model# in or outside" sticker on back plate is RH697. Scale was purposely setup so that no one can change the battery but a tech. Back plate had no instruct as to where battery is and the 4 small phillips screws were covered with rubber filler. I scraped off the rubber filler and opened it up, inside was a computer board which I took out (6 tiny phillip screws) to get to the battery (it was the expected 3V) the battery was front and back soldered in. That was enough for me, this company is nothing but a bandit forcing you to a tech (est. cost 45-60$) or to make another purchase. True piracy, I'm throwing it out. Make sure when buying anything that runs on batteries that the product offers ease of replacement, I am disgusted with Thinner.
Posted on Oct 10, 2010
Why do I just get an ERR message when I try to weigh myself?
The replacement batteries could be of the wrong type, defective, or incorrectly installed.
Oct 02, 2015 | Conair WW60 Weightwatchers Scale
My WW78 scale keeps giving an ERR message when I stand on it.
Usually I change the weight by weighing one foot and then weighing again with both. And then I keep repeating that until my results are consistent. Then that result seems to be accurate
Feb 19, 2012 | Conair Weight Watchers® WW78 by Glass...
My scale shows that i weigh about 30 pounds lighter than i do.
If this is showing your weight, how do you know how much you actually weigh?
Also, you should be testing on a flat, SOLID surface (bathroom tile works well).
Feb 28, 2011 | Conair Weight Watchers WW-87 Body Fat...
Looking for a battery for a conair gmt180 trimmer.
My local BatteriesPlus store assembled a custom equivalent battery with a slightly higher capacity. I didn't know they offered this free service, took the guy about 5 minutes. Because the OEM battery is soldered onto the board they didn't install it but I did it myself.
Sep 18, 2010 | Conair GMT 180 NCS Beard Trimmer
How much does the Black & Decker HPD14K-2 weigh w/battery
10 pounds according to the Amazon listing, with a shipping weight of 10.2 pounds.
Dec 17, 2009 | Black & Decker Drills
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Health & Beauty Logo
43 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
