Question about Altec Lansing Muzx Mesh MZX106 In-Ear Earphones - 3.5 mm Stereo Mini P
Does someone knows how to dissemble Altec Lansing Muzx Mesh MZX106 because my left side wire has been cut
  • Altec Lansing Master
  • 17,093 Answers
Buy new ones, they are injection molded and cant be fixed
Posted on Jan 05, 2013
Left side no sound
Check the device with another pair of headphones if you have them.
Make sure your balance control is in the middle.
Make sure the plug is all the way in.
Wiggle the cord to try to find an open in the wire.
If you've checked all and there is still no sound on the left, I would say an open in the wire somewhere is the culprit. If they aren't old, perhaps you could contact Altec Lansing for a warranty repair or replacement? You may be pleasantly surprised at their customer service, if you're nice, and patient.
Jul 30, 2017 | Altec Lansing Audio Players & Recorders
7 WIRES , WHAT COLOR GOES TO WHICH PIN? 2 BLACK , 1 GREEN, ONE YELLOW, ONE WHITE, 2 ORANGE, ONE HEAVIER THAT THE OTHER
Hi Jerry
What Model....?
Using a mobile phone camera would have helped in this situation.
Before taking things apart
I'll be very surprised if someone has the same speaker system in bits somewhere
An electronics guy would trace the wire back to it's source to decide what it's being used for.
Good Luck
Review Altec lansing BXR1220 Speakers 8
Altec Lansing Avs300 PC Speakers Sub
Sep 13, 2015 | Altec Lansing Audio Players & Recorders
Ah i have altec lansing acs 45.1.the problem is i dont know how to wiring.can u pls help me.ynx
ok first plug run a1/8 two sided head phone jack[male] from the computer to sub woofer you should have two imput jacks makes no differance ok the left sat speaker has a 6 pin din plug round looking plug insert into subwoofer and then plugac cord in the wall you should be good togo "note right sat speaker is attached to the left good luck
Nov 16, 2010 | Altec Lansing ACS 45.1 Computer Speakers
I have Altec Lansing 221, good sounding speakers but the connection cable from the speaker to computer shorts out. Any idea for a replacement cable? Thanks
I would disconnect the power before doing anything! then go to radio shack and buy a cable with the correct plug on it. Then i would cut off as much as possible of the old cable to the speaker, but leave enough room for splicing effectively. Then i would cut open the radio-shack cable and connect the wires of that cable to the remaining wires of the old cable still attached to the speaker. red is left, black is right, and the un-cased wire is negative. Try to figure out what is what on your old wire so that you can splice everything together accordingly. I hope this is not too confusing!! Good Luck!!
Jun 11, 2009 | Altec Lansing 221 Computer Speakers
Altec Lansing IMT702
http://www.youtube.com/watch?v=ztxvAAKhwU8
May 06, 2009 | Altec Lansing Inmotion-IM600...
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Altec lansing AVS 500 IC
The amps are 8-pin CHN 4558CN [K1D142] and 8-pin PHIL TDA8199 [LD8136] The Voltage Regulator is a 14-pin LM324N There is a 3-pin LM7812CN 12-volt regulator... They are in the sub-woofer housing which is held in place by tape so it can be pried off if done with care. Hope this helps. If you have all the cables and wires in place I would appreciate knowing the connection sequences (someone cut all the wiring to the set I have.)
Jan 22, 2009 | Altec Lansing 621 Computer Speakers
Altec Lansing ada885
Same issue showed up for me today very randomly...
HD comes on and off for no reason and sound cuts in and out. This fix worked for me:
1.Disconnect the left speaker from the sub woofer.
2.Take the 4 screws out on the bottom of the left speaker. (They are under the rubber matting you can just poke holes through it)
3. Remove the bottom plastic assembly from the speaker
4. Cut the 4 wires to the headset chip. Careful not to cut any others to the speakers themselves!
5. Unscrew and remove headset plug chip
6. Reassemble and plug left speaker back into sub woofer.
No more HD issues =)
Apr 04, 2008 | Altec Lansing ADA 885 Computer Speakers
How to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Jan 04, 2008 | Altec Lansing ATP 3W Computer Speakers
Altec Lansing Muzx Mesh MZX106 In-Ear Earphones - 3.5 mm Stereo Mini P Logo
51 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
