Question about GE JASRM24912 Remote Control
Remote Unprogrammed Good even I am have a problem is getting my remote to change channels. Can you tell me how do I reprogram remote #RM24914 to a zenith television? Thank You,
  • mikr35 Jan 24, 2009
    i lost the instructions to set the remote to the tv and now i need help programming it to a Emmerson TV
How do i reprogram my g e remote #rm24912 to a sanyo tv
Posted on Jan 20, 2009
I get a download message telling me to hit main for three seconds or skip. When I hit main nothing happens and when I hit skip the remote freezes. Cannot perform any functions and unable to change...
check your batteries to make sure they are good. if they are good you may need to default the remote and reprogram. if this doesn't fix it you will need another one
Jun 08, 2014 | Universal MX-450 Remote Control
Universal remote for RCA tv channel 1
Something missing here. There is no channel 1 on a TV set. None of the universal remote instructions I have or have seen specify that as a first step. From your post, I believe you want to use some kind of universal remote to control an RCA flat panel TV, Can you tell me the brand of universal remote you are trying to use? The answer to the last line of your post is you don't need the original remote to "reprogram". That's what universal remotes do
Jan 04, 2013 | RCA Televison & Video
I have a ge rm24914 remote and an Apex dt502 digital converter box. I need a programming code for the dt502.
You can find a list of supported devices codes for your RM24914 and other GE remotes that require a 4 digit code, here. (a list of device codes for use with GE universal remotes that require a 3 digit code can be found here instead). Additionally, the user manual for the RM24914 can be found here. You will need to download a free program called Adobe Reader to view these files.
I hope this helps and good luck. please rate my reply. Thank you.
Jun 03, 2011 | Televison & Video
Sony trinitron kv32-s15 remote willnot change channels, but, will change on/off and volume.Also, manula channel up/down willnot work
Try to change channels by manually entering the numbers on your remote. If this works then you need to reprogram your channels.
Aug 21, 2010 | Zenith ZN110 Remote Control
Lost jeep 2000 grand cherokee key and remote
go to the car dealer and tell them that you need to get a new key and remote for your car
Apr 09, 2009 | 2000 Jeep Grand Cherokee
Philips PC7225 hotel TV - can't access the menu to reprogram it.
0621 is the code- I used 2 different universal remotes(one for menu and one for scrolling) and solved my problem- when I got to cable, I selected no and was able to use all the originally unprogrammed channels
Mar 22, 2009 | Televison & Video
No freaking signal
Double check ALL your ant wire connections. Then reprogram the converter to check for stations again. If that doesn't work then reposition your antenna and reprogram again.
May 21, 2008 | Insignia Digital-to-Analog Converter for...
Programming RCR311 universal remote to samsung tv
RCA Universal Remote Control-Programming Codes
Try chicking on the web page above and see if this helps. Good Luck.
Ed
NC Electronic
Mills, Wyoming
Jan 25, 2008 | RCA RCR311B Remote Control
RM-AV2100
Either the channel up and down buttons have both broken (unlikely) or everything else is working except the remote is not telling the device you are controlling to change the channel up or down.
Since all the other buttons are working well, that also requires that the receiving end of the pair to be working well, thus ruling out problems on that end.
Solution: Reprogram your remote to support the appropriate channel up/down codes for your TV/Tuner in question.
Dec 14, 2007 | Sony RM-AV2100 LCD Touchscreen Remote...
GE JASRM24912 Remote Control Logo
157 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
