Question about Campbell Hausfeld RBPW1350YL NA 1350 psi Electric Universal
PW 135000AV Dear sir or Medium, My PW 135000AV pressure washer has damage the bearing at the front of the armature. I have to take the Gear off from the armature to get access to the bearing could you tell me if the gear press on or is it screw on if it screw on is it right or left hand threads. Thank you Sham Birball.
  • David Ford
    David Ford May 11, 2010
    Who is the tool manufacturer, let me know and I will do some checking and see what I can find
  • 2,176 Answers
K after my last post did some more checking and went to the Campbell Hausfeld website and found your unit but no breakdown for this. I would suggest that you try their site and ask them to send you a PDF file on the tool. Also they have a year warranty on normal use products, so that might be an option also depending on when you bought it. Good luck and let me know if still having problems and I will try another route to help
Posted on Jan 23, 2009
DO I HAVE TO PULL THE GENERATOR OFF A LINCLON 300D TO REPLACE THE REAR MAIN SEAL?
Yes, You will have dis mantle the front of the machine, The front control panel will have to be removed, the fuel tank will have to be removed,the exciter rotor and stator will have to be pulled, the field will will have to be removed before you can remove the main armature, which has to be decoupled, then the starter will have to be pulled, the mounting baser plate will have to be removed, which will give you access to the rear main seal, whose replacement will take about 1 minute to remove and 1 minute to install, then all that has been removed will have to be installed,check the main generator field to make sure there is no oil or oil impregnated dirt on the inside covering the pole pieces or the shunts and series coils, if there is, use a pressure washer to remove it, do not use excessive pressure or solvents or harsh soaps, keep the water stream a respectable distance from the coils so as not to damage the insulation, let the generator dry on a flat surface, in ambient temperature for a few days before reassembly take care to mark the conductors in the CV unit before you remove it, mark all conductors before you disconnect any of them Take the time to study the welder before you attempt taking it apart. The Generator is very heavy, and will swing down and be damaged if you have not balanced it with a strap before removing it. The main armature must also be balanced and decoupled taking the flex plate with it when it is removed, take special care not to damage the commutator bars when moving the armature around, best storage for the armature is standing up, flat on the concrete floor of your shop I forgot to mention that the exciter armature is held onto the main armature shaft with a tapered flange, keyed washer and a 1-1/8" nut that should be removed with an air wrench to prevent any damage to the armature shaft by the use of hammers or pipe wrenches. Damage to these machines is non forgiving, and will require purchase of new parts if caution is not exercised
Oct 02, 2014 | Lincoln Electric Classic 300D...
Why is my powerstroke pressure washer overheating and stopping?
From what i understand ,you might have a bad armature
Armature partly dammed it can work for a while then will
stop when it overheat ,
Check if you have a high spark around armature , red spark
then check brushes , if brushes is good but the spring is damaged
that mean you have an overheating problem and you need to replace your armature , I hope this will help you solve your
problem ,, let me know if you need any further assistance.
May 09, 2014 | PowerStroke 1700 PSI Electric Pressure...
Bosch gsm10 noisy
Could be the Armature itself (and the both bearings) and gear wheel bearings . worn tooth worm and ring gear remember if replace armature then also carbonbrushes bearings and drive gear with bearings
Then its working again in some cases if the color of the armature is bad then also measure of the electric field and look if its whether it is still firmly mounted.
Apr 15, 2014 | Bosch Saws
Bad bearing on makita ga4530. How do I get to the upper bearing?
You have to take the gear housing apart, remove the hex-nut and spiral bevel gear on the end of the armature so you can pull the armature out of the bearing. Then remove the retaining ring, o-ring and bad bearing for replacement.
Oct 10, 2013 | Makita GA4530 4 1/2" Grinder
Milwaukee 6153-20 grinder is running extremely hot.
Your grinder is either working too hard because of broken or seized bearings or the fan is broken or detached from the armature. Take the brushes out then remove the four screws holding the gear housing on the motor housing. Remove the armature and check the fan and both bearings. If the armature bearings and fan are OK check the bearings and gear teeth in the gear housing.
Jan 31, 2013 | Milwaukee tools Milwaukee Tool 6153-20
How to replace bearings
Must disassemble the pump from the motor. The impeller has RH threads so hold motor armature (do not damage it) and turn impeller CCW to remove it from end of shaft. Hold armature in left hand and rotate impeller with right hand, turning hand on impeller back toward your body, or top of impeller toward you. Don't know how else to describe it. Once you have the impeller off everything should come apart pretty easily.
If impeller is really stuck, you will need to figure out how to hold it evenly all the way around without putting pressure on blades. Strap wrench, home made jig, something that can put more pressure on it than your hand.
You may want to remove the motor field so that you can grasp the armature while removing the impeller, do this by removing the long screws from the end of the motor.
Gently pry, tap, slide, however you can, get the bearings off the armature shaft without damaging any parts attached to it like fans, or starter centrifugal weights. Those things can be removed if needed.
Put new bearings on by sliding over shaft and seating in place by driving against the center race only. Do not drive bearing on by striking the outer race to move the inner race, this will damage the bearing.
Aug 14, 2012 | AO Smith SQ1152 Pool Pump Motor
Just replaced the brushes on a WE14 150 Quick 6 Grinder and sparks now come from the brushes
From my own experience.
Are the strips of the commutator smooth and flat?
(Not to insult you. The part of the armature that the brushes ride on)
If they aren't, the brushes will bounce up and down.
I put one end of the armature in a drill, and have a helper run the drill. The other end of the armature rests in the front bearing of the grinder head, which is fastened down. (To a bench) Then I use a medium tooth, (B astard) file to dress the commutator bars flat.
I also put medium grade sandpaper in-between the brushes, and the commutator surface to dress an arc on the brushes. (Turn the armature by hand while keeping the sandpaper in place)
Brushes come with a flat surface. Putting a radius on them to fit the arc of the commutator, gives them a good contact surface to start from.
Be sure the springs are putting pressure on the brushes. Sometimes the brush mounts need to be cleaned, or the brush will not slide through the mount like it should. The brush will again, 'Dance' on the commutator. (Bounce up and down)
Sep 06, 2009 | Metabo WE14-150 Quick Angle Grinder
How to replace main bearing in a Makita GA5000 5'' angle grinder. I removed the clip in the gear head but can't remove the gear to pull the armature. The main armature bearing in the gear head is shot.
i used to grab the armature and tap the housing off with a rubber hammer...
try tapping in opposite corners every time....
when it does fall have a cushion ready on the bench or floor to catch it...
Jul 10, 2009 | Makita GA7020 Angle Grinder
Load starts banging like it is unbalanced
Check first the machine balance, to ensure the machine is at level and well balanced and that is not the problem.
If you already inspected springs and strut, then the problem is usually the drum bearing, or the drum bearing spider that has broken.
You can superficially check if there is a problem with the drum bearing by spinning the drum with the hand to check if there is excessive play.
If you found oil under the machine, check also that the support for the motor and motor gear box under the bearing is not damaged, and any of this part is banging again the chassis, this can cause oil leak, and machine shaking.
The most common is a bad bearing.
Mar 27, 2009 | Maytag Legacy MAV208DAWW Top Load Washer
Repairing a kitchenaid 6qt mixer and replaced worm gear. parts list shows a thrust washer needs to be there but it won't fit. after a closer look it appears that I have two back bearings for the worm gear...
Hi. Go to the whirlpool.com website, for some insane reason they don't list their mixers, enter a search for mixers, then find your model #. Look for a parts catalog. Look at the "exploded" drawings for the transmission area. There you'll notice that there are Front and Rear bearing locations. This drawing also shows the correct place for the "washer". Also, the front and back bearings may look alike, but the're not. Every part needs to be in it's correct place or damage will occur when you start it up, or when you place the machine under load. Let me guess...The original PLASTIC transmission housing broke causing damage to the worm gear assembly. If this is the case, your replacement transmission housing should be made out of metal. If it isn't, call customer service and demand that they send one. The plastic housing has no place in a Premium priced mixer, especially when they advertise that the mixer can handle heavy bread dough. Finally, check the bearing seats, when the worm gear failed it may have also damaged these seats. It happened on my Kitchenaid. Good Luck!
ricardok45
Nov 22, 2008 | KitchenAid KP2671 Professional 6 Series...
Campbell Hausfeld RBPW1350YL NA 1350 psi Electric Universal Logo
139 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
