Question about Bosch 2002 Volvo V40 1.9L Professional Preferred Remanufactured
How do you set the cam to sprocket timing on a 2002 volvo v40
How to replace camshaft seal and pvc system on a 2000 volvo v40? What would be a reasonable price to pay for repairs?
If that is the T5 Engine you are going to need a Special set of Tools that hold the Cams, Sprockets and Crankshaft before starting on the seals if you are going to separate the Cam Cover from the Cyl. Head. I have done it with out the Tools but I do not recommend it. The PCV System you will have to pull the Injector Rail and the Intake Manifold to get to it.
Oct 16, 2014 | 2000 Volvo V40
RNR cam shaft adjust solenoid
Hello Pleas i have volvo v40 year 1997, i buy used radio sc 802 without code number,you can help my?serial number of the radio VO1720W0061212F,Thank you..Petr
Aug 23, 2013 | 2000 Volvo V40
I need to know how to set up the valve timing marks on 1.8 volvo s40 when the belt has broken and the sprockets on the cam have been loosened as the marks are on the sprockets which are not keyed to the...
I refer to a question asked on 15 April re timing marks but I am looking for info on the same marks on a VolvoS40 2litre Non Turbo
1997. Does this kit you talk about apply to this as well. If so where can I get it. I live in cape town south africa
Apr 15, 2010 | 2001 Volvo S40
I am changing spark plug in my 2000 volvo v40
Firing order is 1-3-4-2 (Please rate me if this helps)
Jun 04, 2009 | 2002 Volvo V40 Wagon
Need to set timing
there is a hole in the cam sprocket, when it is at about 12 oclock it chould line up with a groove machined into the head. That is tdc for cam, when lower timing cover removed, mark on crank sprocket should line up with mark on block.
May 05, 2009 | Hyundai Motor 2002 Elantra
Clock setting
Here's how to set the clock on a 2004 Volvo V40. Rotate the odometer stem to the right or to the left and hold it without pushing it in. The clock will start to move slowly then speed up. This seems to have been left out of the owners manual. Hope it helps.
Nov 28, 2008 | 2004 Volvo V40 Wagon
Bosch 2002 Volvo V40 1.9L Professional Preferred Remanufactured Logo
32 people viewed this question
Top Bosch Electronics - Others Experts
Mike
ray gallant
Are you a Bosch Electronics - Other Expert? Answer questions, earn points and help others
