Question about Dryers
Wwa7304vkl motor hums but does not start
Washer fills with water does not pump out, spin or aggitate. there is a hum for a few seconds when motor trys to start then nothing. timer goes through all cycles
    Sergeant:
  • 475 Answers
Motor is going out on your machine.
Posted on Jan 05, 2013
  • 1314 Answers
SOURCE: GE Dryer DWSR473GV0WW periodically just hums when turning on switch
might have a dead spot on the armuture or lint in the motor and or the centrifcal switch try taking it apart and cleaning the motor if that doesnt work replace the motor
Posted on Feb 15, 2008
  • 91 Answers
SOURCE: kenmore dryer hums but will not rotate
PRETTY OBVIOUS REPL/ MOTOR
Posted on Jan 03, 2009
SOURCE: Maytag LDE313 Dryer drum won't start
Sure sounds like a winding problem. Initially when you press start and hear the dragging of the motor sound, this is the start winding going out. Part number is 303358 and your cost is around 120.00 in new or about 60 in good quality used. Good Luck in your decision. If I can help further, I am here...
Waiting to hear from you,
Eric Campion
Posted on Feb 14, 2009
  • 93 Answers
SOURCE: Our Kenmore clothes dryer is not starting.
its sounds like you have a broken belt or a bad door swith open the door rotate the drum manually if it feels verry easy to turn that means your belt is broken if not you can check the wires then replace the door switck thanks from gilles
Posted on Mar 15, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag SDE4606AYW electric dryer won't start.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
dghj53
Posted on Sep 29, 2010
Kenmore model 110 it will aggitate but will not spin or drain and the motor hums
Eric, it sounds like there may be something stuck in your drain pump motor, or the drain pump motor itself is locked up. If the washer still has water in it, it should not spin.
Nov 30, 2017 | Kenmore Washing Machines
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
My Kenmore washer won't spin, agitator is locked up, motor hums..
agitator won't turn, it fills up water and hums
Jun 13, 2009 | Washing Machines
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Whirlpool LSQ9549lW0
sounds like something is stuck in the water pump. look under the machine and you will see the water pump front and center of machine.
Jul 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag neptune mah3000aww
re original issue, see if R11 is burned. if so, need to change R11 resistor and associated triac, and probably wax motor so it won't do it again. temporary fix just cut out R11, door won't lock. if your model won't spin that way, depress actuator for microswitch from door wax motor. instructions on web.
Jan 19, 2008 | Maytag Neptune Washer
Dryers Logo
Top Dryers Experts
