I am talking about watching and listening to Good Morning America Show on ABC - Too Much Noise interfers with hearing what news people are saying?
What more can I say. The background noise of the show is distracting and annoying to the listener/viewer.
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Check its antenna orientation. The input signal is weak.
Posted on Jan 05, 2013
Basti
  • 1447 Answers
SOURCE: Toshiba 50hp16 pop than crappy pic
Might be the bulbs.. try replacing it, or call toshiba support line/ service line.
Posted on Apr 29, 2008
SOURCE: Plazma TV buzzing noise
The transformer is resonating. Get it replaced, Don't do it yourself.
Posted on Sep 27, 2008
satavlad
  • 405 Answers
SOURCE: high pitch frequency noise coming from rear of TV
High pitch sound on LC-42D62 is reproduced by switching transformers on power supply board. To correct this problem, you will need to remove power supply unit from the TV, spray all transformers with SILICONE CONFORMAL COATING. Let it dry for 12Hrs. Then install power supply unit back.
Posted on Dec 31, 2009
SOURCE: DVD movie background sound too loud to comfortably watch!
on some dvd players and surround sound systems have a thing called DRC (dynamic range compression) you can us that and it will help it a little. i have come across the same problem but im after a digital on to run with plex or vlc on a mac. im having to route it through protools to use a compressor on there, but thats eating my resources.
Posted on Sep 29, 2010
ginko
  • 19396 Answers
SOURCE: TV won't come on, it just stays in standby mode
Hi.
The TV staying in standby and the light flashing indicates that the TV is in fault mode (often called protect mode). This happens when an internal fault is detected, and the main board set the unit in forced stand-by with the led color changing.
Before doing anything else try disconnecting TV from power for ten minutes. Restart the TV with no device connected, leave it on for a while and see how it goes. Test the TV with different devices (eg. DVD, VHS,sat box, console etc .)
In your case it looks like there is no clear indication toward a particular fault. The TV coming on at random times, may point at a defective PSU, but other failures such as defective main board, overheating, defective inverter, or faulty Timing controller (TCon) may result in the same problem.
The most common fault that may cause the symptom you described is PSU. Unless there is clear sign that the PSU is damaged, this is still far from being enough to decide that PSU is the culprit. The power supply must be tested before replacing parts. Testing is done reading PSU out on different voltages. This is an operation that must be done by a trained repairer.
The high pitched noise may be given by a defective PSU capacitor. In that case the bulged or leaking capacitor is usually easy to spot looking directly at the PSU.
To book a repair call the manufacturer at the number listed on the owners manual.
To get part price, enter model here: ShopJimmy.
Regards.
Ginko.
Posted on Feb 19, 2011
Apr 29, 2008 | Toshiba 50HP81 50 in. Plasma Television
2002 ford escape just stoped running
Could be your electric fuel pump in gas tank. you can check it by turning the key on and take gas cap off and have someone to check to see if their is a noise saying the fuel pump is working. someone has to stand by where you put gas in your car and put their ear to the hole an listen when you turn key on, do not start the car just turn the key on and if they hear a noise like a pump running then your electric fuel pump is okay, but if don't hear a noise then your electric fuel pump is not working. it is hard to explain about the noise you will hear, but as long as they hear something when you turn key on and their ear is at the opening they will know what I am talking about. I've done 4 electric fuel pumps in gas tanks on different vehicles. good luck ! would like to know if you could hear the pump running when you turned the key on with the gas cap off.
Apr 15, 2014 | 2002 Ford Escape
Lcd tv music is too loud to hear voices
hi i don't know if this will work go into the menu on the tv look for noise reduction turn it off or check your sound settings hope it helps
regards
shaun
Apr 02, 2014 | JVC LT-40X776 40 in. LCD HDTV
Hi , i got a 1994 316I bmw , n am facing a silly problem with the engine noise in the morning .. when i start up the engine i hear a knocking noise then when the car starts to warm up the noise fades...
What you need to do is find the are that the noise is coming from. Next time you start in the morning, pop the hood first. start the car and get out and listen for the noise. Is it coming from the top or the bottom of the engine. You will have to get down to listen for the bottom. Top engine noise is usually from the lifters. They get dirty and partially collapse. They do have stuff called valve medic, thats helps clean these up. Bottom end noise Is the rod /main bearings. These can only be replaced. Basically an engine rebuild or replace.
Jun 14, 2011 | 1994 BMW 3 Series
Hello, This is no joke. I just purchased a Whirlpool Designerstyle refrigerator off craigslist. The refrigerator works fine. I believe it is the ice make that makes up a lot of noise and rumbles. One...
Ok ok ok ok ok ... let me understand this ... your frig is talking to you???
Let me tell you one ... several years ago, a US East Coast state govenor resigned from office. We had been on vacation and we had made it a point to stay away from the news. On our way home, we stopped by a Big Box store to look at refrigerators. As I walked down the row, I suddenly heard something talking in a low voice ... sounded like a radio ... it was a news story ... it was a story about the govenor resigning from office. The story was coming from the refrig! I heard about the govenor resigning from office because of a particular orientation he had ... and I heard the stroy from the refrigerator!
I said all that to say this ... your refrigerator may also be radio equipped ... or it it possessed ... I think you should look for radio controls on your frig.
Thanks for making my day ... and thanks for using FixYa.com
Aug 15, 2010 | Whirlpool ET1MTKXKQ White 20.9 Cu. Ft....
Listening modes not working??
I am a little hesitant to tell you what this is because sometimes people give bad ratings to an expert when they do not get the answer they want to hear. I will take a chance here and assume you are a reasonable person and tell you what the most likely cause is. I have been reparing these type of receivers for as long as they have been making them, and every time I see this particular problem it is always something on the digital board. This is the board the the optical and coax inputs go into on the back. They also run all the audio thru this board, and when you only get the audio that you have, a problem is going to be found there. There is some good news and some bad news that goes with this, first the good news. Many times (about half), the digital board only needs to have some of the solder reflowed on a few of the IC's and it will return to normal operation. If this is the problem your repair should only cost from $90 to $150 depending on the rates of the shop. Now the bad news, if the board has a couple of bad compnents on it, it will need to be replaced. The reason that is bad news, is because those boards are very expensive, usually over $250 just for the board, if the board is even available. Many of these receivers you can not get the digital board for them. Most all of audio equipment is component level repair and there are not many technicians who can troubleshoot these boards, they are a very difficult task.
I hope this free information was helpful, and if so a "FixYa!" would be the appropriate rating. You do not need to have your receiver fixed in order to give a good rating, only that you are given the correct information.
Let me know if I can be of any more help to you, good luck with your Onkyo.
Dave
Nov 10, 2008 | Onkyo TX-SR803 Receiver
News is perpetually-how to turn that off woithout turning off ALL sound
I'm assuming that this "news type show" is a video or radio. Look for its volume control usually has a symbol like:volume%2bicon.jpeg and it has a slider to its left. Just slide it over the left side to turn the volume off.
Let me know if this helps. Appreciate if you rate it.
Thanks,
ArnWuLF
Oct 10, 2008 | Dell Inspiron B130 Notebook
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Electro Med Services...
