Question about Aiwa HV-MX1 VHS VCR
Will Aiwa HV-MX1 Playback Extended Play (EP) Speed?
Manual only states "will play PAL signal on Standard Play (SP) or Long Play (LP) modes".
  • J. B. Jan 08, 2013
    Unfortunately, I do not have the Aiwa HV-MX1 VCR to try, I'm looking to buy one, but before I must be sure it will playback on EP mode. The manual does not seem absolute. It was translated into many languages and English was not the original one, but Japanese.
    Thanks for any assistance.
  • Aiwa Master
  • 5,126 Answers
Probably not then, but you could try a tape recorded at EP.
Posted on Jan 06, 2013
nfandres
  • 168 Answers
SOURCE: aiwa mx100 (al system vcr)
if your vcr is a multisystem, select the proper system in your vcr for the video to be played. but if not, you cannot play your PAL in your NTSC vcr. good luck!
Posted on Feb 26, 2007
  • 275 Answers
SOURCE: Aiwa vcr HV-FX 7800k
If you are asking 'why ' does this VCR have 2 speeds, it is to help you locate a certain portion of the movie fast. If you are asking 'Does' this VCR have 2 speeds, the answer is YES.
Posted on Mar 29, 2007
  • 3422 Answers
SOURCE: tape an catridge stuck
locate the motor that powers the cassette carriage. If there is a worm gear in the mechanism, you must hand cycle somewhere between the motor and that gear. Once again, the shaft or pulley that comes out of the motor is usually the best place."
Here is the site which tells how to eject the caste when it is stuck.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 08, 2008
  • 120 Answers
SOURCE: AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
Posted on Jan 15, 2009
SOURCE: Aiwa HV-MX1: tape won't eject from VCR and it switches off.
Turn over the VCR. Unscrew the base. You will see the 3 belts. Turn the rightmost belt clockwise or anticlockwise (don't remember) but you will see the tape hold mechanism moving down. Once it is all the way down, you can eject the tape out.
You may need to replace one or all 3 belts. This is being caused by belts being loose.
hope this helps.
Posted on Apr 09, 2010
I recorded an event but when I recorded an event but when I replay it the little cassette jumps or skips. What is causing this to happen?
standard play" (SP) quality. Other speeds include "long play" (LP), and "extended play" (EP) or "super long play" (SLP)
https://en.wikipedia.org/wiki/VHS
mismatch of recorded vhs speed to play back speed could be cause
Oct 06, 2015 | Video Cameras
My plug has been changed how do I get ep off of my unit
Which plug did you change? "EP" stands for Extended Play. A VHS recorder has three speeds. EP is the slowest. A standard 2-hour tape will record for 2 hours at the highest speed (SP), 4 hours at the middle speed (SP) and 6 hours in EP. There is a trade off. The faster the tape moves past the recording/playback heads, the higher the picture quality and visa versa. So EP gives you long recording time at a cost in quality.
I doubt that the unit being in EP mode has anything to do with the cable. You did not say what brand and model recorder you have, but in general, the speed is adjusted with a switch on the front panel (older models) or via your remote control.
Jun 22, 2015 | Televison & Video
Changing sp mode to ep
Are you asking how to change the record speed to extended play? This is usually given as a choice when programming a recording. You use your remote to scroll through various options on the input screen and you should find that you can choose between sp/ep/lp (standard, extended and long play)
Apr 08, 2015 | Televison & Video
I no longer get a video signal out when I play a PAL tape when in the NTSC conversion mode. I do get the PAL signal out on my NTSC TV which I of course cannot view. Audio out works either way. What...
Hello
Please give me the brand names and model numbers of both devices you use with now. How are the confujured? I mean, the interconnection between them. Without any of these informating, it will be very difficult to assist you. Send me these. OK.
Oct 16, 2011 | Aiwa HV-MX1 VHS VCR
Can I use this machine to play an NTSC cable input on a PAL tv.
Typically you wil need to set the ouput to pal to match the tv but it will do what you want.
Mar 16, 2010 | Aiwa HV-MX1 VHS VCR
VCR LP/EP compatibility
Vdumitre -
No, not usually. If you've recorded a tape at LP and put it another machine that doesn't have LP, it usually won't play properly. Some machines that have only SP/EP will do this, but they are got scarce as more manufacturers dropped the LP speed. Your best bet is to buy an older one from a thrift shop or a garage sale, making sure that it will play LP. Then, copy your older LP tapes to SP or EP (Run the OUT from the LP unit to the IN on the SP/EP unit, and choose "record from line in", "aux", or "rear input").
Thanks,
videoman7
Aug 05, 2009 | Sony Televison & Video
Vcr recording speeds
Yes. SP is "Standard Play" and LP is "Long Play", while EP/SLP are short for Extended Play/Super Long Play respectively.
Jan 19, 2009 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Camera plays in fast forward-like speed
Though I don't know the details of your camera and the tape you are playing, one explanation could be that the tape was recorded in "extended play" EP rather than "standard play" SP. Some VCRs and some cameras are incapable of playing back in EP, a mode where the tape moves at half speed so you can record more on the same tape. The result is that the tape playing back at regular speed appears twice as fast and fast forward will be even faster.
Unfortunately, unless your machine can be manually set to play back in EP (usually it is automatic) the solution is to play it back in a machine that can handle EP.
Dec 04, 2008 | Electronics - Others
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
VCR Help
SP means Standard Play. Generally that is the Normal speed at which a VCR Records or Plays back a tape. SP is automatic, as it is the Standard setting. If you wish to record more picture than the normal 120 mins on a tape, then you choose LP (Lond Play) oe EP (Extended Play).
Nov 20, 2007 | Sansui VHF6010 VHS VCR
Aiwa HV-MX1 VHS VCR Logo
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
