Panasonic toughbook..cf-53 bios password to remove
I have a CF-53. While I was in the BIOS, I had loaded the default BIOS settings. After rebooting, I realized my BIOS was now password protected!! WTH?? I called Panasonic Tech Support at 800-527-8675. The tech was VERY knowledgable, and when I explained the situation to him, he said that didn't seem normal and that Panasonic doesn't normally password protect the BIOS. On what seemed purely like a hunch, he suggested typing in "password" - Voila! It worked!!
Thanks Panasonic Dude!!!
Posted on Apr 03, 2013
    New Friend:
  • 3 Answers
The only way to remove the bios password is by removing the CMOS chip and read or swap it with one from another Panasonic CF-53 motherboard. Here is the location of that chip. It is usually has a bit of green or purple paint on it.
Panasonic toughbook..cf-53 bios password to remove - panasonic-toughbook-cf-53-bios-password-vqhs5npjtw4miumnsdowhxnk-4-0.jpg
Posted on Jul 03, 2016
  • 2 more comments
  • Stefan
    Stefan Aug 21, 2016
    Hello. Same problem here, do you have a 25q128 dump for CF-53 without password?
  • David Guay
    David Guay Feb 16, 2017
    Yes I do. Can send it in binary.
  • David Guay
    I managed to clone the MX25L but the 25Q128A is way harder
  • John Nick
    John Nick Apr 02, 2018
    Good day. can you send bios binary. Thanks
2 Suggested Answers
elix0411
  • 3530 Answers
SOURCE: panasonic toughbook cf-52 has bios
Welcome to Fixya
Bios password cannot be removed by just reseating the cmos battery. You might need to short the board to reset the bios password. Please take not that this is a critical job you need technical expertise in doing this.
Follow these steps:
  • Remove Laptop Battery
  • Remove Memory Cover
  • Spread spring clips to outside and
  • pull out RAM memory
  • Remove clear vinyl label opposite RAM memory slots
  • In the upper left corner you will see JOPEN1 with a white silkscreen square
Inside the square you will see what looks like the letter T over a U. Using a metal paper clip short the U to the Silver 1/4"post connecting the motherboard to the laptop case and hold it for 25 -30 seconds. Place back your RAM memory, put in the laptop battery and test start laptop. you should see a selection of F1 or F2 for setup. Using the F2 gets you into the Bios menu where you reset the time and date. Then Tab over to the SECURITY setting tab and change your passwords. Then hit F10 key
Thank you for using Fixya!
Posted on Feb 23, 2011
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    Clear / reset BIOS password on a Panasonic Toughbook CF-53
    You can usually reset the BIOS password by unplugging the CMOS battery and all other power sources.
    Then turn the computer on with power plugged in (not the CMOS battery though).
    After computer has booted up, turn off again, plug CMOS battery back in and password should have reset.
    Tutorial on how to do this can be found under soloution 2 of this link:
    http://www.wikihow.com/Clear-BIOS-Password
    Nov 28, 2013 | Computers & Internet
    CF-T7 bios password
    I was remove the cmos battry but same password pleas how can i remove the bios password of panasonic cf-t7
    Oct 05, 2012 | Panasonic Toughbook Cf-t7 Laptop Computer...
    BIOS PASSWORD??? HELP!!!
    Try typing "Biostar" in as the password. If that doesn't work, we have another option.
    The first step would be to try removing the CMOS battery (the coin shaped battery inside the computer that keeps the clock working). Disconnect the laptop from any power source (AC adapter), and remove the main laptop battery. Third, you will have to remove the bottom plate of the Toughbook. Search YouTube for a disassembly video for your model of tough book. Once you've removed the bottom plate, you should be able to see the internal components. Connected to the system board by two wires will be the CMOS battery. After disconnecting the CMOS battery (carefully!), hold down the power button on the laptop for about ten seconds, then let the computer sit for a few minutes to ensure that it is completely devoid of power. You will then need to reinstall the laptop battery (the main, brick-shaped one — not the CMOS) and boot up the laptop. If all goes according to plan, you should be able to access the BIOS and turn off or remove the bios password. Now you can reassemble your Toughbook. Power off, remove the battery, reconnect the CMOS battery, and reattach the rear plate, and you're good to go!
    Nov 22, 2017 | Panasonic Computers & Internet
    I have panasonic toughbook laptop cf-73 and i forget bios password now what i do?
    RESET BIOS JUST REMOVE BATTERY AND DISCONNECT FROM POWER .. ALSO DISCONECT BIOS BATTERY TO RESET BIOS , AND BIOS PASWORD
    Nov 25, 2010 | Panasonic Toughbook CF-73 Notebook
    Bios password for panasonic toughbook cf 71
    just clear the bios, by removing the jumper and put in its place again
    Sep 29, 2009 | Intel Motherboard
    Cf-28 superuser password
    goto bios setting see thast the password is there if yes then open the cpu and cleaar the jumoer setting and remove tha the cmos battery n plug it that will solve th e problem
    Jun 19, 2009 | Panasonic Toughbook 29 Touch (P/N...
    BIOS password
    Its in the motherboard.... remove the c-mos battery and then place it again...it will reset the bios password..
    Jun 12, 2009 | Panasonic Toughbook 50 Notebook
    On boot up a safeboot apears and asks for password i bought this secondhand and its been trouble from day one anyone out there please help also bios has had a password done as well so cant get into that...
    if you are able to open motherboard then simply remove CMOS bettry for 10 sec and put again then password will reset...if you dont open motherboard then ask me?????
    Apr 03, 2009 | Panasonic Toughbook CF-51 Notebook
    Computers & Internet Logo
    11,482 people viewed this question
    David Payne
    David Payne
