Question about Samsung SD 616E (729507925578) Internal DVD Drive
Samsung SD616e internal dvd
I have a dell computer dimension 8300 with a Samsung Sd 616e internal dvd. When I install a dvd nothing happens. If I install an audio cd it plays. I have blown air thru the dvd , used a cleaner disc to to the lens and I have uninstalled and re installed the drivers several times. Also when I troubleshoot this Samsung dvd unit it comes up stating " unit is working correctly ". What else is there left to do if anything. What could be the problem ?
  • 6 more comments
  • Anonymous Dec 06, 2007
    dvd room does not work
  • Renegades59 Feb 26, 2008
    will not read DVD or CD new disk. will not open cd
  • Anonymous Mar 02, 2008
    putos americanos de mierda
  • Alvin Minton Mar 10, 2008
    I have a Dell 8400 about 3 yrs old with the Samsung 616E dvd rom drive. It does not recognize neither a cd or a dvd it will eject from the my computer screen but does not play. I've check all cables which are ok. From device manager I right click on the drive I'm told "device is working properly" news to me!! Help!!
  • sflowers Apr 23, 2008
    I am new at this. Been told all I have to do is put DVD in 8300 and it works. But it doesn't. Maybe all I need is instrutions on how to run it.
    flowers64blooming@gmail.com
  • fraric2 Feb 05, 2009
    My dell dvd is doing the same thing.
  • Anonymous Feb 19, 2009
    after reinstalling this device it shows a message : code 39 ?
  • Anonymous Mar 29, 2009
    same problem as the rest of you with my dell dimension.
    but like that one poster said.
    drives are so cheap these days, can get another cd/dvd rom for $20 or less.
    since no one has a solution this seems like the easiest fix. :)
  • 48 Answers
I could have you try a bunch of stuff and go through a bunch of hoop and hurdles but seeing how cheap DVD drives are today it is just less hassle to just replace it with a new one. Really easy to do. Seeing as how you know how to install and remove drivers and all.
Posted on Jun 29, 2007
  • 59 Answers
2 Things One if you choose to buy another one this site is recommended very highly click the below link http://computerequipment.at/gogocommunications Secondly You say your trying to put a dvd in the drive, What do you want it to do ? I guess your on about AutoRun Yes ? Simple just switch it on!
I am unable to write cd with samsung 616e combo drive
Hi likeme2299
Unless you would succeed with other cd's from another manufacturer or updating the firmware , your drive is defective and is probably not worth reparing .
Best regards ,
fanaudi .
Sep 12, 2011 | Samsung SD 616E (729507925578) Internal...
I have a dell dimension 8300 computer/ windows XP OS with a Samsung Sd 616e internal dvd Rom Drive. When I insert a dvd or CD nothing happens, except a whirring sound of continuous spinning. Also, when I...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Dec 06, 2010 | Samsung SD 616E (729507925578) Internal...
Samsung SD 616E drive not recognized by PC
Check in the BIOS if the interface/port to which you're connecteing has not been disabled. Most bios ' access by pressing del shortly after startup before Windows has started loading. Others access by pressing F1 or F2. (It should indicate what is needed at the bottom of the screen at startup).
Jul 26, 2010 | Samsung SD 616E (729507925578) Internal...
Windows cannot load the device driver
you need to right click on the device, from the view with the yellow triangle, and update the driver or roll back the driver.
failing that , download driver max and it will find the driver for you.
Sep 24, 2009 | Samsung SD 616T Internal DVD Drive
Media player says that it cant find the burner
I guess you have a Read-Only drive - ROM. You need a CD/DVD RW drive for burning.
Dec 31, 2008 | Samsung SD 616E (729507925578) Internal...
Samsung dvd-rom 616E won't play sounds
I decided to check to see which video player programs were already on my computer. I have a Dell, so there were several that came preinstalled.
Did I mention that Windows Update had installed several new fixes recently?
My toolbar no longer worked like it did last week, that was a clue.
2 of my programs were no longer in the programs list, Interplayer and Power DVD were missing.
I went to the Power DVD site and downloaded the latest update.
Now my DVD player works fine.
I don't know why RealPlayer or Media Player didn't work, even with the updates.
I don't care, as long as something works.
I could have tried Winamp too but Power DVD worked and I didn't try anything else after that.
It doesn't have to be a problem with the hardware, but could be the software.
Nov 23, 2008 | Samsung SD 616E (729507925578) Internal...
DVD/CD - RW Combo Drives
Any brand should work as long as you have the correct drivers.
Either IDE (internal) or USB (external) will work.
May 02, 2008 | Computers & Internet
Samsung SD 616E Internal DVD
mmm! thats very strange! your drive could be damaged internally or have you checked all internal connections Ie: checked that the IDE or Sata cables are connected, By the way i will only recommend you do this if your technically minded.
you can do one of the following
1, have your system checked fully by a local engineer or
2, buy a new Drive if all other parts of your system is working
Dvd-roms / recorders are cheap enough now just to throw away and replace.
I can recomend a shop that i have personally been shopping with for the last 15 years and they really do know what they are talking about,
you can visit them at the shop if your local or shop on line, they even take Paypal as payment
Check em out HERE
ENJOY
May 01, 2008 | Samsung SD 616E (729507925578) Internal...
Samsung SD 616E Internal DVD not working
I have the same problem, wont read anything in the drive. It is a master and there is no slave dirve so its not that, jumpers etc checked, drivers, cables. Just wont work.
Dec 14, 2007 | Samsung SD 616E (729507925578) Internal...
Dvd burning
VSO ConvertXToDVD does what you want. It costs $40. If you buy it now you'll be able to upgrade to 3.0 when it comes out. WinAVI Video Converter, DVDSanta, and Avi2DVD are also recommended, but I have had the best experience with the first program.
Nov 07, 2007 | Samsung SD 616E (729507925578) Internal...
Samsung SD 616E (729507925578) Internal DVD Drive Logo
1,040 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
