Question about LG LMX28988ST Refrigeration : Refrigerator : French door
Lmx28988 lg refridgerator freezer draw problems
Bottom freezer draw on right side is not closing all the way. it is about one inck way from closing. the left side closes
  • peter albert Jan 07, 2013
    On further checking, there is a bar with gears that roll on tracks on the right and left sides of the freezer draw. observed that the bar is not in alignment. the left side that closes is further away from the front than the right side.it appears this has to be removed and reinstall but do not know how to do this.
  • 489 Answers
SOURCE: LG bottom freezer
Sounds like the refrigerator is sitting lopsided.  Make sure that the front legs are both retracted in the up position.  If it doesn't work, then lower the front leg on the hinge side of the refrigerator.  That will cause the frame to lift the door and it should be able to close properly.
Posted on Jun 08, 2008
SOURCE: Bottom freezer door/drawer won't close all the way on one side.
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
Posted on Feb 21, 2009
  • 6 Answers
SOURCE: Bottom freezer door on our LG is out of
The easiest way to fix that is to pull the freezer door all the way out and give it a good little tug, you will see the plastic covers on the side rails there will be a little gap about one inch on each side make sure those gaps are even. Your door should be aligned
Posted on Jul 30, 2009
  • 180 Answers
SOURCE: doors won't stay closed!
Frost in the rear of freezer possibly caused by door staying open.  Door staying open possibly caused by frost buildup on ref door track.  Start by making sure the teeth on the freezer track are clear of ice and frost.  This should allow you to shut the freezer door.  Next check the freezer seal.  If it is not completely sealed it it will build up frost. It is also possible that the frost in the rear of the freezer is from a failure in the defrost cycle as the evap coils are at the back of the freezer. If this is the case your refrigerator is probably getting warmer.
Posted on Oct 25, 2009
aaronbeth
  • 110 Answers
SOURCE: the bottom freezer door doesn't close all the way
Check to see if there is anything that has fallen behind the basket or obstructing the tracks.
Posted on Jan 30, 2011
Error code listing for LG lsc27931st Refridgerator.
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
http://www.searspartsdirect.com/refrigerator-repair/error-codes/lg-bottom-freezer-refrigerator-error-codes.html
May 18, 2015 | LG LSC26905TT Side by Side Refrigerator
Water tastes bad from LMX28988 refrigerator
This is usually attributed to the filter needing to be replaced... once a new filter has been inserted it should clear up the taste problem.
Apr 19, 2014 | LG LFX21971ST Stainless Steel Bottom...
My LMX289885T/02 LG refrigerator's left door will not close without manually pushing the long bar into place first.
Guessing your talking about the heater. Sometimes the sprin comes loose, in the end probably will have to change it out
Sep 08, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
LG LMX28988ST freezer at 30 degrees
What it the reason that my fridge is freezing my food. The temp. IS set to 37 F. Why
Mar 14, 2012 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
Knocking on side of refridgerator
Where is the knocking coming from? The freezer section, the bottom of the unit?
Oct 22, 2011 | Refrigerators
Refrigiator does not air culation
tihs is either a ice blockage on the cold coil or the evap motor has failed ... hope this helps mm feed back pls .. ,,
Jul 10, 2011 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
Er if code comes on. I have let it defrost for 4 hours. Code disappears and then reappears. I would like to know how to fix it.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 22, 2011 | LG LMX28988 (27.5 cu. ft.) Bottom Freezer...
Lg side by side refridgerator ice maker
you can adjust the control for the freezer side to a colder setting think of the freezer control as a door warmer setting door open farther colder setting door farther closed the fridge control is electric that runs the compresser can turn fridge down to creat more cooling freezer or set freezer to colder setting it is a balancing
act have actually closed freezer control to coldest setting and had items freeze in the fridge side where air from freezer first enters fridge a lower temp in freezer should help ice production
Dec 10, 2009 | LG LSC27931S Side by Side Refrigerator
Water leaking out bottom of refrig/freezer
Sounds like maybe two things. Your freezer isn't closing correctly and condensation is forming, bad seal maybe. Other option is you need to clean the pan on the bottom of the fridge. Condensation gathers there and it is normal, but if you alot of crud down there it will cause water to gather. Hope this helps...
May 25, 2007 | Kenmore 50522 / 50524 Side by Side...
LG LMX28988ST Refrigeration : Refrigerator : French door Logo
35 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
