Question about Samsung LE32B450 32 in. LCD TV
Blown up The tv picture went grainy and blured then went bang
    Top Expert:
  • Samsung Master
  • 74,106 Answers
It sounds that the LOT {Line Output Transformer] to your TV has damaged. Contact any experienced service technician to get it repaired.
Posted on Jan 05, 2013
TV went bang now no power
The capacitors on the power supply need to be replaced. When you take apart the TV, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video on howto replace capacitors.
Oct 20, 2014 | Samsung Televison & Video
Free tv repair advice
Potentially so, however I would get the TV fully checked over by a professional if it has been subject to a surge. If a component further down the line caused the initial surge replacing the blown cap will only result in another bang as soon as you plug it in.
Mar 21, 2014 | Televison & Video
I have an LG 50PS8000 plasma tv which is nearly 2 years old. For the last few months its has occassionally been getting a red haze over the entire screen which either dissapeared on its own or went if you...
I've also had a popping noise on our 50" LG plasma TV, however the picture has not gone, but has turned grainy and colors are weird. Can this also be a blown fuse or a more severe problem (ysus board or similar)?
Apr 08, 2011 | LG 42LC2D 42 in. LCD HDTV
Color went in and out, no i only get fair black and white picture often grainy
I'm assuming here that this tv is being used for analogue reception because on digital you either get a perfect picture or when the signal is weak enough, nothing at all (common when trying to use rabbits ears or in poor reception areas). Assuming analogue then, when the signal is weak (grainy or snowy picture) the colour (called chroma) is automatically turned off because grainy colour is unwatchable. This is normal. Solution, a better aerial to provide a stronger signal.
Jan 20, 2011 | Akai PDP4206EM Television
Replaced the convergence ICs
If you replaced both ICs you may have a blown resistors usually the 1.8 ohm 1 watt resistor or the other ones next to it will be blown if you still cant do alignment after repalcing ICs
Jun 21, 2008 | JVC AV-48WP30 48" Rear Projection...
Grainy pictures
grainy pictures are possibly casued by a very high ISO (sensativity) setting, you should be on 100 or lower for best normal shots. Higher settings are for low light and custom shooting in strange lighting or aperature/shutter speeds. Try full auto setting.
Mar 03, 2008 | Canon PowerShot S3 IS Digital Camera
No picture
hi richt2,
This problem could be 2 things,
The first one, could be an easy fix, which is the picture cord going from the `box to the tv could be in the wrong slot, make sure if they are color coded they are in the cirrect spaces. The obvious problem could be a faulty cord.
Try rearranging the cord placement.
Then try a new cord.
Dec 29, 2007 | Microsoft Xbox 360 Console
2000 27" Sony Wega
Sony has a code for those blinks indicating the problem area. Count the blonks till the pause then google Sony blink codes for the area to fix.
Jul 03, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
KV-XJ29M50 29" TV-Loud thumping sound on startup
Symptoms are not related,what you hear is the high voltage turning on and that is normal if it only does it for less than a second,the grainy picture might be intermitant,dont turn it off,when the picture is grainy tap the side of the set to see if it racts and if it does you know you have a loose conection.This could be outside because of a loose ground on tha cable or inside in the tuner.
Sep 22, 2006 | Sony KV-XJ29M50 29" TV
Samsung LE32B450 32 in. LCD TV Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
