Question about Toshiba Satellite U305-S5097 Notebook
Builtin webcam not being recognized ...i accidently changed some setting when it asked for camera type I clicked the option listed which was different than the builtin webcam and now the computer wont read it.
How to use skype 6.0 with logitech c-310
Launch the Logitech QuickCam or Webcam software on your computer. Verify that you see yourself Logitech Webcam software window. Close the software window. Sign in to Skype. Click the "Tools" menu and select "Options." Click "Video Settings," check the "Enable Skype Video" and "Start my video automatically when I am in a call" boxes. Select your Logitech QuickCam from the drop-down list. Your webcam should display video in the window. Click "Audio Settings" if your QuickCam has a built-in microphone and select it from the microphone drop-down list. Check the "Let Skype adjust my audio settings" box in "Audio Settings" so Skype recognizes your microphone. Click "Save" to save the options for your audio and video settings. Skype will close the options menu.
Jan 19, 2013 | Logitech C310 Web Cam, Skype, Computer...
How do i enable my builtin webcam on dell latitude d630 laptop?
Please just follow the below steps to fix your problem
1.Turn on the D630 and insert the drivers and utilities disc into the disc drive on the side of the laptop.
2.Click the "Start" button in the lower left corner of the screen, then click "My Computer."
3.Double click the disc icon to launch the Dell drivers and utilities disc.
4.Click "Drivers" at the top of the screen, then click on the driver for the webcam.
5.Click the "Extract" button, then follow the prompts from the installation wizard. You may be prompted to restart your computer.
6.Click the "Start" button in the lower left corner, then select the "Control Panel" option.
7.Click the "Performance and Maintenance" icon, then click "System."
8.Select the "Hardware" tab at the top of the screen, then click the "Device Manager" button.
9.Click the "+" symbol next to "Imagine devices," then right-click on the "Webcam" option. If there is an "Enable" option, select it.
10.Launch a program, such as Google video chat or Skype, then navigate to the "Settings" page and verify that the program recognizes your webcam
Thank you for using Fixya.
Aug 11, 2011 | HP Pavilion dv9000z Notebook
How do use my Canon GL2 as a webcam on skype using XP or Windows 7? I tried hooking it up to both Laptops ( 1 with XP & 1 with Win.7. It did not recognize it. Do I need a certain driver? or do I have...
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver W7
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick also
select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
you might need to downloads this driver if you cant find or don't have one
http://download.cnet.com/extrawebcam/3000-2348_4-10840198.html
ExtraWebcam is the software that enables you to use Canon PowerShot and EOS series cameras as regular webcams for video conferencing, video recording, remote area monitoring and other webcam tasks. It supports any Windows software that take a standard video capture source as input such as Skype, MSN, AIM, Yahoo Messenger as well as online services like Ustream, Veetle, YouTube. You only need to select ExtraWebcam video source, connect your camera via USB and power it on, the rest will be done automatically - search for a connected camera and taking control over it.
if you need more help with this post a reply
Aug 10, 2011 | Computers & Internet
My cam not working
Hello!
I would like to hear more details, so please write again and describe your problem.
I also recommend you to try following:
1. Uninstall your camera:
  1. Start>Control Panel>Programs>Uninstall a program
  2. Scroll down and find your camera in the list of programs, click on it
  3. Click "Uninstall/Change
  4. Confirm uninstalling
  5. Restart your computer
2. Reinstall the camera:
  • Insert your camera CD and plug in/connect the camera to computer. If the program starts installing automatically, then just wait and confirm if prompted. After the installation is complete:
  • restart computer, plug in the camera-it should be automatically recognized and work fine.
A. In case the installation does not start automatically, follow these steps:
  • Click on Computer (on your desktop OR start>computer)>double click on DVD RW Drive (OR when the CD inserted a pop-up window appears, so click on "Open folder to view files")>double click on icon marked as ".exe" which is executive file. The installation will start, and you only confirm/continue/allow if prompted.
  • After the installation is complete, restart your computer, plug in the camera-it should be automatically recognized and work fine.
3. I also recommend you to visit this link, because I suspect your camera driver is not compatible with your Operating System since there is a short list of Operating Systems compatible with your camera.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCGAUVC10&LOC=3
  • select your Operating System (if not listed, then my suspicions are true and you can only contact support on the same site to possible link you to update downloads for your camera drive. If your Operating System is listed then follow the steps below:)
  • select the device (camera)
  • you will get a list of possible downloads and I recommend you to download the "utilities" one as I assume u do have the drive (if you don't have the camera drive at all and that is the reason for it not working, then download the drive from the same site and follow installation steps from 2.)
  • Run the downloaded drive-it should update your camera's drive.
4. In the end, check following:
  • Start>right click Computer>Properties>choose Device Manager in the left pane and see if there is any item marked with yellow triangle or something similar (just making it different than others)
  • Now you have two options: 1. right click on the item>Properties>Check for solutions, and then wait until you get the report from Microsoft;
2. right click on the item>Uninstall and close it. Then run Windows Update and install updates. Windows Update you can find when click on Start and in the search pane type Windows Update, click on it when appears, choose "Check for Updates" and wait until the program finds updates, install updates and restart computer.
Please, let me know how it worked with you, and feel comfortable to ask any questions if you have.
Regards!
Jun 22, 2011 | Sony PCGA-UVC10 Webcam
My eyeshot builtin web cam is not working when i am on skype
Did you try uninstalling your Skype? Maybe your Skype version is an old one (recently they launched the new version). Also, if you Skype tried to update automatically and was interrupted it can cause issues.
My suggestion is to uninstall your Skype using Revo Uninstaller, then go to official Skype website and download the latest version which you will install. They try if it works.
Other thing that might be causing the problem is your camera. Please, go to your Skype now, choose tools>options>video settings and see if Skype recognizes your cam (it will appear in drop down window). If your cam is not listed let me know to find you a solution, but first try uninstalling Skype.
I would also like you to tell me the error message you get.
Jun 17, 2011 | Logitech Webcam
Canot view my web cam in yahoo.
Instructions
  1. 1 Open Yahoo! Messenger and then click "Messenger," "Preferences" and then select "Webcam." Choose the option "When I show my webcam, change my status message to," and then enter whatever you want your status message to be in the text field. Then click "OK" to finish changing your status settings.
  2. 2 Choose "Webcam" from your Yahoo! Messenger "Preferences" menu and then click one of the following options, "Always ask my Permission," "Allow everyone to view my webcam," or "Always allow the following people to view my webcam." If you choose the latter you can select, from your friend's list, the people who you always want to allow to view your webcam. From there you can also select "Ignore other view requests," if you don't want to allow anyone else to view your webcam. You also have the option to either choose or not choose to select "If I am in a chat room, allow people in the chat room to view my webcam," by clicking the box. If you want to remove anyone who is viewing your webcam, you can select, "Who's watching me?" to remove their name from your viewers list.
  3. 3 Click "Webcam" from the "My Webcam" options in your Yahoo! Messenger "Preferences" menu, and choose "Statistics. From there you can figure out how much bandwidth you are using, as your connection mode, frame rate, image size and image capture type.
  4. 4 Select "Messenger," "Preferences," and "Webcam" from Yahoo! Messenger, and then click "Camera Settings." Move the slider under "Broadcast my webcam with," to select the between faster-speed transmissions or higher quality images. You can also change image size from this option as well as brightness and contrast. Click "OK" to finish.
Dec 13, 2010 | Radio Shack VGA PC Camera Webcam
How does the camera assistant software for toshiba work?
Step 1 : Open Yahoo! Messenger and then click "Messenger," "Preferences" and then select "Webcam." Choose the option "When I show my webcam, change my status message to," and then enter whatever you want your status message to be in the text field. Then click "OK" to finish changing your status settings.
Step 2 : Choose "Webcam" from your Yahoo! Messenger "Preferences" menu and then click one of the following options, "Always ask my Permission," "Allow everyone to view my webcam," or "Always allow the following people to view my webcam." If you choose the latter you can select, from your friend's list, the people who you always want to allow to view your webcam. From there you can also select "Ignore other view requests," if you don't want to allow anyone else to view your webcam. You also have the option to either choose or not choose to select "If I am in a chat room, allow people in the chat room to view my webcam," by clicking the box. If you want to remove anyone who is viewing your webcam, you can select, "Who's watching me?" to remove their name from your viewers list.
Step 3 :Click "Webcam" from the "My Webcam" options in your Yahoo! Messenger "Preferences" menu, and choose "Statistics. From there you can figure out how much bandwidth you are using, as your connection mode, frame rate, image size and image capture type.
Step 4 : Select "Messenger," "Preferences," and "Webcam" from Yahoo! Messenger, and then click "Camera Settings." Move the slider under "Broadcast my webcam with," to select the between faster-speed transmissions or higher quality images. You can also change image size from this option as well as brightness and contrast. Click "OK" to finish.
Dec 29, 2009 | Toshiba Satellite A205-S4617 Notebook
Skype does not recognize my built in webcam
You need to check the Video Settings in Skype.
Start Skype - click on Options - Video Settings, select the WEBcam that is is installed on the laptop (if it is not listed then the WEBcam driver is not installed) and under Automatically Receive Video from - select Anyone or Only people in my contact list.
Jul 15, 2009 | HP Pavilion dv6000z Notebook
Labtec webcam just has a black image
Normal 0 Double click on this site
http://www.labtec.com/index.cfm/service/listing/EUR/EN,crid=68,crid2=1764
to down load Labtec Camera Drivers.
Then
Disconnectthe Camera from the USB port and reinstall the CD or Downloaded softwareprogram. When the program asks you to connect the camera to theUSB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera’s have to besetup on the program they are to be used with. Just installing the cameraon your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order forthe Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Yourfriends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
Hopethis helps. Bud
Mar 19, 2009 | Labtec Webcam Pro
Logitech quickcam
Reinstall the software and watch for the langue selection and select English.
Also download the latest drivers here.
Normal 0 To get the latest Microsoft Web Camera drivers, double click on this site
http://www.microsoft.com/hardware/download/download.aspx?category=ICE
then select the necessary items as listed below, such as
  1. Select type of product. (Web cam)
  2. Select your product (camera model).
  3. Select your operating system. (XP, Vista etc.)
  4. Select your operating system langusge. (United States English)
Then do this:
Disconnect the Camera from the USB port and reinstall the CD or Downloaded softwareprogram. When the program asks you to connect the camera to theUSB port, do so and it should work.Then to use it on the Web, do this.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/bd ) set it up as follows:
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://messenger.yahoo.com/download/bd ) set it up as follows:
Hopethis helps. Bud
Mar 15, 2009 | Logitech Webcam
Toshiba Satellite U305-S5097 Notebook Logo
103 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
