Question about Precor 9.21 Treadmill
How do I fix an ERR70 message on the display of my 9.21 treadmill.
I get an ERR70 message when starting my machine. It had been shut off for a couple of months. The machine is likely from the late 90'ies. How do I get it to start normally?
  • Precor Master
  • 914 Answers
Precor Error 70, LPCA Not Read Probable Cause Incorrect or missing software in the LPCA
Corrective Action Test with a known good LPCA Precor Error 70 LPCA Not Read AMT12 Only
Posted on Sep 09, 2014
How to correct Tread climber TC5500 error code NIPP COMM (Belt Shut Down).
If you wiah to get some details about treadmill error codes and solutions then check the following link
http://electro-medical.blogspot.com/
Oct 02, 2016 | Bowflex TreadClimber TC5500
Bad relay message and circuit breaker is pushed in and stuck
reset the machine and follow the step and fix it.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 21, 2013 | PaceMaster Exercise & Fitness
Machine shuts off- says LS
follow this steps and fix it. God bless you
Plug Treadmill into wall outlet and press
START.
Display lights up; TREADBELT DOES NOT MOVE "L5 / LS ERROR"
Is red SERIAL lamp on the motor control
board lit?
Is the yellow RLC lamp on the motor
control board lit?
1. Unplug the treadmill from its
2. Wl alk on the belt manually. (push belt)
3. Does the yellow MOTOR lamp light while pushing?
Is yellow MOTOR lamp on the motor
control board lit?
1. Loose wire connection to motor, capacitor, or choke.
2. Loose brush holder screw on motor. (Check Both)
3. Failed drive motor. Part # 70014 (110V), 70125 (220V)
NO
YES
NO
YES
5.1
5.2
5.3
5.4
5.5
NO
1. Check wiring harness connection between
upper and lower board. Part # 70083
2. Replace display board. Part # 70076
YES
Enter Open Loop Speed mode:
WARNING: NEVER STAND ON THE TREADBELT IN THIS MODE.
1. Turn off the treadmill.
2. Press FAST and START simultaneously and release both buttons once the display lights up.
3. Hold the fast button until the display reads 99.
Short in capacitor, motor, or motor
control board.
NO
Turn treadmill off. Disconnect drive motor wires from lower control board (Mtr + and Mtr -)
terminals. Power up in OLS mode (FAST & START). Bring displayed speed up to 99.
Measure across the Mtr + and Mtr - terminals with your voltmeter (DCVolts). You should
measure at least 90 vdc on a 110V treadmill and 180 vdc on a 220V treadmill.
If you are not getting dc volts out of the lower board, replace it.
If you are measuring the proper dc voltage out, replace the drive motor.
Sep 19, 2013 | Bowflex Exercise & Fitness
E 7 error code is displayed on my SportsArt 1210 treadmill. When keep it turned off for a long time, then the machine works fine but if I switch if off and back on again, E 7 is displayed and nothing...
i have the same treadmill with an error 10 message. i have the booklet that came with it and it says that an error 7 message indicates(too much to write). I can fax the error message page and the wiring schematic to you. my email is srt8ght1999@yaho.com. not posting my number here.
Jan 05, 2011 | Exercise & Fitness
Treadmill powers off when pressing Incline Increase "br 1" error
You may have a beltand deck problem. Test by the following procedure:
without the poweron stand on the walking belt, push the belt in the, direction it normally turns. If the belt is very difficult to turn (on most treadmill this means that you have high belt/deck friction I first apply silicone lubricant between the belt & deck to see if that clears up the problem. Most problems originate from the belt and deck 75 to 85% of the time
Jun 13, 2010 | Spirit Fitness Z500 Treadmill
Fet error message
The FET error message is caused by the driver transistor on the motor controller has shorted out. Unfortunately, the fix is replacing the motor controller.
Oct 13, 2009 | Life Fitness T3 Treadmill with Advanced...
Tredmill error code e1
Trimline treadmill starts up then code E2 comes up, and the display shuts down.
Any ideas???
Apr 02, 2009 | Nautilus Tr300 Treadmill
Precor 9.21 Treadmill Logo
103 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
