Question about eMachines W3115 PC Desktop
My emachine boots,runs for a while then freezes
My emachine will start, boot up and run for 10 - 15 minutes. The cursor then freezes and the tower beeps
  • eMachines Master
  • 27,725 Answers
The beeps are possibly post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in. Open computer and reseat memory Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer. Swap memory location If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. If you have more than one stick of memory try removing all but one stick of memory and boot the computer. Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory. Try another computers memory Test all power and data leads that attach from motherboard to your hard drive IDE SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty If its a flat 40 pin ide it will be the first to fail. Check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it Restart your computer the found new hardware wizard should activate a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function Make sure all leads that are attached to your drives dvd\cd and floppy drive have secure make sure the connections and are not faulty or just replace them they could be faulty Computers need all Power and Data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error also check the keyboard for secure dust free connection ps2 and or usb
Posted on Jan 05, 2013
  • 121 Answers
SOURCE: my emachines t3604 starts up and all the fans are
Try downloading puppylinux, burn it onto a cd then boot from the cd, if everything works fine, then you need to reinstall windows.
Posted on Mar 21, 2010
  • 551 Answers
SOURCE: my emachine will not boot up
try replacing the processor.
Posted on May 18, 2010
  • 87 Answers
SOURCE: taking 7 minutes to boot up
You may have a virus infected. I would get it checked out or try to trouble-shoot yourself.
Please follow this guide for how to install a good anti-virus program that is free forever.
http://www.fixya.com/support/r5317428-actually_free_antivirus_software_windows
If this doesn't speed things up please write back.
Posted on Jul 16, 2010
damnor01
  • 1179 Answers
SOURCE: My Emachine T2865 will not boot up, and just gives
This is a problem with the RAM. It is all explained in my tip entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Thanking you
damnor01
Posted on Nov 12, 2010
igor106
  • 277 Answers
SOURCE: My emachine W3623 starts with
Remove the RAM and start the PC again. If you get the same three beeps then you're probably looking at bad RAM. If however, the PC makes no noise, or other beep code, then it's not the RAM and in that case it may be the graphics card. In this case, you'll need to do a reflow/resolder of the graphics chip with a hot air gun.
If this was helpful and informative, please give it a Thumb Up. Thank you.
Posted on Jan 19, 2011
My hard drive has system but when i try to boot from usb or cd room for new system it's freeze and doesn't start up with usb boot or cd room
You didn't provide any details on what OS you are running or trying to load, but here are some steps to verify.
1. Ensure that the procedures you used to create your bootable USB device or bootable CD are correct. These will not boot unless they have a boot loader installed properly on them.
2. While running your existing system, ensure that you can actually view the files on your USB device or CD (in case either device is not actually working).
3. Ensure that the BIOS settings set the boot priority to USB or CD ahead of the hard drive.
Nov 29, 2014 | Computers & Internet
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
I have a program which has jammed up my computer. Once windows boots up, the cursor freezes. When I boot up in safe mode, I can use the cursor, but can not uninstall a program in safe mode--help!
If you are using Microsoft OS then after booting :-
Start > Run > MSCONFIG
Untich the program which is causing the program. Apply and OK.
Restart your machine once.
Please post your feedback and Vote if the problem resolved as per your satisfaction
Sep 23, 2010 | HP Compaq Presario R4000 Notebook
Dell PC Fan Running like a race car
Hey Darrick, It seems that the fan is full of dust or gone bad. You can open the tower and use a compressed air can to clean out the fan. if cleaning it does not help call Dell sales and order a new heat sink fan.
Jul 28, 2009 | Dell Computers & Internet
Emachines m5309 won't boot
If you have a Install Cd for your version of windows, run it and select repair. If you are running vista, press F8 when the computer is booting and select System Restore (first one on list). If all else fails, re-install windows. You may or may not loose data based on the severity of the error.
good luck
Jun 25, 2009 | eMachines eMD620-5133 Notebook
Having problems starting my laptop. it starts fine but freezes within a minute or so. i try it again numerous times and it freezes around the same time each time. what can the problem be?
seems to me you have some kind of virus or spyware ! 2 solutions do bios hard drive check to make sure not hard ware falure! or do virus boot scan!
Feb 26, 2009 | eMachines W4620 Notebook
EMachine tower doesn't boot up. Only the fan is running
try replacing your ram.if your ram is bad you wont get no picture on your monitor but your puter will start.2 if you have a video card turn off you puter for a few minutes and plug your monitor to your original display.
Nov 24, 2008 | E-Machines eMachines Desktop PC
Fails to boot
You might try a Hirens Boot CD, un-zip the files, create a bootable cd from the .ISO file and boot your troubled system, select virus scan on boot.
Apr 16, 2008 | Gateway MT3705 Notebook
Emachine W1135
when ur starting the tower and it light are on and ur fan there is no problem with the power supply, i think that u rily need a new motherboard because ur board will not boot on start up..
Oct 17, 2007 | AMD eMachines Desktop System w/ 17'' CRT...
eMachines W3115  PC Desktop Logo
44 people viewed this question
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
