Question about Coffee Makers & Espresso Machines
Insert milk container on DeLonghi Magnifica 3500 Espresso Machine
Even though my milk container is inserted machine still says insert milk container and will not make a cappuccino.
2 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: Delonghi Magnifica Rapid Cappuccino machine.
Hi Alan,
This posting is back on the unsolved boards again. I cannot see what anyone else has told you and I don't know what you have tried. So, I'm starting fresh....
If your control panel is not reading that you have inserted the container, then one of several things could be wrong.
I imagine you have already checked and cleaned all the parts involved and made sure that the lids are sealing and the container is seated properly. Clean around the door to be sure it closes securely.
If all of these things are in proper order, then it could be that the control panel has gone bad. Is there a reset button somewhere on your machine? Have you tried to go through the descaling/cleaning procedure and restart the machine?
If none of this works, I would suggest contacting DeLonghi to talk to a technician. Here is a contact page I got from the internet: http://www.delonghiusa.com/index.php?texts&pid=3
You may have already found the contact site, but if all else has been checked and found to be ok, I think that is your only recourse now.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 05, 2011
Magnifica ESAM 3500 milk temperature low
This is factory preset and cannot be altered. You do need to use the "clean" function on the milk frother unit to ensure the boiler and pipes heat up enough also.
May 15, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
Changing the Magnifica ESAM 3500 milk temperature
This is preset and cannot be altered.. Do ensure you preheat the milk frother before use.. by activating the "clean" button on the frother jug
May 15, 2014 | DeLonghi ESAM3500 Espresso Machine &...
Initial set up of delonghi ESAM6700 and it will not go past insert water spout stage. Even when spout inserted it does not recognise and we cant continue setting up the machine as it simply reads insert...
OK, I can answer this one... the same thing happened to me. It would not recognize the water spout. No beep when inserted, but it would beep if you inserted the milk container. Looking into the receptacle, I saw that the switch for the milk container is offset to the right, and the switch for the water spout is offset to the left. All I had to do was carefully bend the lower tang on the water spout that activates the switch to the left a little bit. It looked perfectly straight, but was just offset to the right enough to miss the switch.
Hope this helps someone.
May 08, 2011 | DeLonghi Prima Donna Avante ESAM6700...
Insert used coffee container this is what my
just take tray out refit bucket ..make sure theres no old coffee in the way vacuum old dust out of unitof machine... now refit tray and slam door ... bsc appliances 07779933829 postal serrvice too
Jan 12, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Milk frothing problem on a Magnifica 3500
Had the same prolem replaced the coupling where the jug clips in. Item 111 - part number 5532123200 coupling. If your not technically experienced then you may need to take it to a service agent. Had to fairly well dismantle machine to complete repair.
Apr 07, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi Magnifica 3500 not frothing
use cold low fat milk and keep the milk container in the frig.
Make certain that when washing water come out of both holes.
Jul 09, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
My delonghi magnifica is having a problem with milk..steam is coming through but no milk..can you suggest what the problem may be?
There are 'o' rings on the pipes (on machine - not milk container) where the milk container fits into. replace or clean them - should work like new.
Jun 21, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Milk container won't fit onto front of machine
We had the same problem & worked out that it's because the actual milk container is too cold & has contracted from being in a cold part of the fridge. We moved the milk container to the door of the fridge ( it's a little warmer than the rest of the fridge) & it slotted in perfectly the next morning!
May 02, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
