Question about Drive Geo Power Wheelchair
I have a Pronto M91 chair and I need to know where the reset button is on chair and where are the fuses located??
When plugging in charger, the pre stage yellow and red... then both red top red one blinking 3 times... ty
How do I get my pronto m91 out of charging mode?
The M91 has an onboard charger. When unplugging the charger power cord from the wall outlet does not stop the chair from being in the charge mode, The charger has to be unplugged from the wheelchair wiring harness or main control module under the plastic body parts. The on-board chargers fail like this sometimes.
Jun 06, 2014 | Invacare Supply Group Invacare Pronto M91...
What does 7 times flashing mean is wrong on pronto m91
Seven blinks is most often the joystick. A Invacare Remote Programmer can be plugged in to the joystick to verify this.
May 28, 2014 | Electric Mobility Invacare Pronto M41...
Invacare pronto m91 wheel chair not getting any power to the switch. Is there a fuse somewhere?
Hello,Download:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 as A PDF File.It is full of info & you can diagnose your problem to select part required.I hope i have helped,have a nice day,Colin
Apr 02, 2013 | Invacare Pronto M91 with SureStep
Is there fuses in the M91 Pronto Onboard charger
I had this exact same problem after having my M91 in the shop. The repair man said that the onboard charger was bad, so he sold me an offboard charger to charge through the arm. That didn't change anything. I finally took it apart myself and discovered that there was a cord leading from the onboard charger to the batteries that the repair person had left unplugged when he installed my new batteries.
What I'd thought was "fast draining" of the batteries was actually the batteries self-charging overnight (which they will do a little bit if you let them sit). Of course, this might not be your problem, but I'd say at least look at it as a possibility.
Aug 23, 2012 | Invacare Supply Group Invacare Pronto M91...
The Pronto will not keep a charge so I replaced the batteries. Now the red and green light flash while charging and there is no power to the chair
Mckinzie the lights will flash when charging because of the inhibit mode. After you unplug the charger and turn the chair on do you get any lights at all on the battery indicators? If not lift up the seat and check your battery cable connections the neg cable from the rear battery should be connectd to the positve side of the front battery and the rear neg should plug into the small connector of the other cable. Make sure then that the large double plug is connected to the double plug going to the controller. while the seat is up then turn the chair on to see if all the lights come on. If not check that all your connections at the battery posts are tight. Also check under the two red positve battery post covers the two fuse links to make sure they are not blown. If all of this checks out the chair should come on and operate correctly Hope this helps
Aug 28, 2010 | Invacare Supply Group Invacare Pronto M91...
One red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
May 15, 2010 | Invacare Supply Group Invacare Pronto M91...
I need help with electric wheel chair batteries for a Pronto M91
after fully charging the batteries I plug in the control and it flashes once and then it is dead and the batteries are in recharge mood?
Oct 24, 2009 | Electric Mobility Pronto M91 Power Chair...
Pronto 91 fully charged batt but only gey 3 flashes off red light
Batters won't hold charge and work properly it sat up for that long. replace batterys
Aug 27, 2009 | Invacare Supply Group Invacare Pronto M91...
Can't charge Pronto M91.
Hi Bob. Unfortunately in most cases this means that the batteries have gone so flat that they cannot be “revived”. The best thing to do is take the batteries to a local battery dealer and have them checked. You may need to replace them. Another possibility is that because the batteries are so flat, the charging circuit hit a wobbly trying to resuscitate them and popped a fuse button. A simple reset may help. Happy scooting. Regards Chris… info@mymobility.co.nz
Jun 21, 2009 | Invacare Supply Group Invacare Pronto M91...
Batteries won't charge w/ on board charger-+
sounds like blown fuse which is at rear of chair. may be underneath rear cover. this fuse wont keep the chair from working, however, it will keep the charging from working.
May 29, 2009 | Invacare Supply Group Invacare Pronto M91...
Drive Geo Power Wheelchair Logo
23 people viewed this question
Top Drive Health & Beauty Experts
Colin Taylor
ray gallant
Are you a Drive Health and Beauty Expert? Answer questions, earn points and help others
