Question about Dell Latitude D630 PC Notebook
My dell d630 works great but when i connect the VGA port to my sceen it does not work. do i need a driver or is this a hardware issue?
I have a dell d630. when i connect the to a screen with a VGA cable the screen does not appear. i have used diffrent VGA cables and diffrent screens but still no visual on the screen. would this be a driver issue or a hardware issue?
    New Friend:
If you attach the VGA and just the projector(or external screen) is not working and your computer still works, it could be a settings option. Connecting it then going to Start>Control Panel> Hardware and Sound>Connect to a projector. Make sure "computer only" isn't marked.
Hope i could help
Posted on Jan 05, 2013
freetek
  • 5568 Answers
SOURCE: dell latitude d600-vga
The flickering may not be caused by a corrupt driver, it could be the impending failure of the fluorescent back light of the display or its high voltage supply.
Trying driver replacement though is the first thing to try.
If the original driver is corrupt, you can try the following;
- Right-click on My Computer
- Left-click on Properties
- Click on Hardware tab
- Click on Device Manager
- Locate and open Display Adaptors
- Locate the video listing for your
- Highlight and delete this
- Reboot the computer
If Windows does what it should (no guarantee on this!), it will 'find' a 'new device' and install the driver for it.
Posted on Aug 23, 2008
leecom72
  • 4806 Answers
SOURCE: Ethernet port not "active"
Hi there.
Restart the PC and go into the bios to make sure the on-board LAN is enabled, if it is try as jery says and try another ethernet cable.
Post back please and good luck
Posted on Apr 21, 2009
leecom72
  • 4806 Answers
SOURCE: taptop connect to TV audio preoblems
Hi there.
If your TV supports a VGA cable it should also support computer audio in. You need to purchase a mini stereo cable and plug it in to the headphone socket on the laptop and run it to the computer audio in on the TV,just using the VGA cable alone will not produce any sound.
Purchase something like this for the audio >>>>>>
Good luck and thanks for using FixYa!!
Posted on May 23, 2009
  • 7 Answers
SOURCE: Connecting Dell Inspiron B130 PC Notebook to HDTV
Youll need a regular VGA cord and a 3.5mm to RCA conversion audio cable from Radio Shack like the one below. http://www.radioshack.com/product/index.jsp?productId=2428708
forget going the HDMI route, it isn't worth the money youd have to spend on a converter. once you got your cables hooked up, consult this: http://www.microsoft.com/windowsxp/using/setup/learnmore/northrup_multimon.mspx
Posted on Jul 17, 2009
  • 356 Answers
SOURCE: Connecting latitude D630 to Sony Bravia
Disconnect all cables and reboot your computer.
Turn off your hdmi TV as well.
When computer is already on, connect the VGA/HDMI cable to your computer and the other end to the TV.
Turn TV on then press Fn+F8 ONLY ONCE.
Posted on Jun 03, 2010
Unclear lettering & numerics
1: Resolving Laptop LCD Lines,
Fuzzy, Color, or Blurry Issues
Verify that the BIOS and Video drivers are the latest available from Support.Dell.Com Website, for more information refer to Dell Knowledge Base article, "How to Use the Drivers and Downloads Website"
Test the LCD in the System Setup (BIOS).
To enter the computer BIOS Setup Screen perform the following steps:
At the first text on the screen or when the Dell logo appears, tap <F2> until the message Entering Setup appears.
Note:
Some older Dell computers use an alternate key sequence instead of to enter System Setup. These key sequences include:
<Ctrl>+<Alt>+<Enter>
<Delete>
<Fn>+<F1> (laptop computers only)
<Fn>+<Esc> (laptop computers only)
If you observe the same issue on the setup screen, it is not an issue with the Operating System, it is a hardware issue, Contact Technical Support/font>.
Run the Laptop Built-In Self-Test (BIST).
To run the Built-In Self-Test perform the following:
Turn the computer off.
Press and hold the D key while pressing the power button. This will start the BIST.
The screen will display multiple flashing colors. Look for lines, distortion, or any other video issues you have observed.
The laptop will restart when the test is finished.
Click the following link to see an English-only video of this test How to Run LCD BIST Video .
If the LCD BIST passes, proceed to Step 4, otherwise Contact Technical Support.
For information on Beep Codes/Error Codes refer to Dell Knowledge Base article, Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers
Connect to an external monitor (if available), for the different types of external monitor ports that may be available on your computer refer to (Figure 1).
Display Port
Display Port is a new digital standard for connecting monitors to computers and has the capability to provide a scalable digital display interface with optional audio and high-definition content protection (HDCP) capability. Display Ports usually resemble USB Ports with one side angled.
A Display Port cable should be used if Display Port connectors are available on both the computer and the monitor.
DVI
Digital Video Interface (DVI) is the digital standard for connecting monitors to computers. DVI connections are usually color-coded with white plastic and labels.
DVI cables provide a higher quality signal than VGA cables. A DVI cable should be used if DVI connectors are available on both the computer and the monitor.
VGA
Video Graphics Array (VGA) is the analog standard for connecting monitors to computers. VGA connections are commonly color-coded with blue plastic and labels.
A VGA cable should be used if DVI connectors are not available on either the monitor or the computer.
Once it's connected, press and hold down the FN and press F8, this should display the screen on the external monitor.
When the external monitor does not work or you did not have one to test with, Contact Technical Support.
When the external monitor does work it may be an issue with the Operating System. Verify that all the drivers are the latest available from Support.Dell.Com Website, for more information refer to Dell Knowledge Base article, "How to Use the Drivers and Downloads Website". When that does not fix the issue the Operating System may need to be reinstalled, for more information refer to Dell Knowledge Base article, "How To Restore or Reinstall Microsoft Windows on a Dell Computer".
Check for visible damage to the LCD. To identify any damage not visible to the ***** eye, ensure you run LCD BIST on the system (refer to Step 3).
If the LCD has damages which is not covered by any applicable statutory warranty, limited hardware warranty and/or Dell-branded service, including Complete Care / Accidental Damage service, there may be a cost incurred by you for the replacement of parts.
Oct 04, 2012 | Dell Computers & Internet
D630 screen is black once it starts up it illuminates but stays black
You must detect what parts is failure
Screen display, inverter board or lamp
Follow these step.
1.- Connect an external monitor (at VGA port) and check the image in external monitor
If show clear image. The failure may be the inverter board or the lamp backlight
Inverter boars is more easy to replace.
You can buy an used cheap price on
http://www.ebay.com/itm/Dell-Latitude-D630-Inverter-Board-K021048-00-/260809995144?pt=LH_DefaultDomain_0&hash=item3cb97cb388
Replace and your screen will work again
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Dell Latitude D630 PC Notebook
Is it possible to hook my dell D630 to my sharp LCD/HD tv?
If your TV has a VGA port then yes, otherwise you will need to purchase a special adapter that tends to not work well and be expensive. -Alex
Aug 15, 2011 | Dell Latitude D600 Notebook
DELL D630 NOT WORKING
1. Disconnect all external devices (printers, USB hubs, USB drives, etc...) and
then boot up. If this corrects the issue then add the devices back one at a time until you
discover the piece of hardware causing the issue. Then get any updated drivers or software for the device.
2. Use the"Last known good configuration" from the Windows Advanced Options menu. If this option resolves the issue then look for any updates or software installs
that may have caused the problem.
3. Boot to Safe Mode from the Windows Advanced Options menu.If you can get into safe mode then the issue could be driver or software related. From within Safe Mode run a System Restore.
4. Perform a Clean Boot as needed
Mar 14, 2011 | Dell Latitude D630 PC Notebook
How do I hook up a flat panel tv w/hdmi to a dell d630 laptop. I tried vga cable from laptop to hdmi input in tv .no sgnal
You are going to suffer from quality issues because vga is the best connection for video out the D630 has. You should be able to hook the vga up directly. this gives around 480p i think. If you don't have that input, then look for vga converter boxes.Don't forget to change the display in graphics properties so that the video actually gets sent out.
Nov 12, 2010 | Dell Latitude D630 PC Notebook
MY D630 LAPTOP DOES NOT WORK IN DOCKING STATION
When powering on the D630 from the Docking Station, press F2 to go into Setup. Scroll down to the Docking Section, and check the Dock device info for the status. If it shows undocked, then try changing the below settings to: Hot Undock, Enabled Silent, and Universal Connect Enabled. Save these settings. Make sure you update your BIOS to A16 from http://support.dell.com under drivers and downloads section. If still not recognized after this, check the dock port on the D630 for obstructions or burn markings on the pins. try cleaning with rubbing alcohol and qtip swab. I have seen a few cases like this and ultimately the motherboard was the issue and needed to be replaced.
Dec 20, 2009 | Dell D/Dock Expansion Station Docking...
Speakers installed but not working on laptop
Many times what happens is during Microsoft updates this audio card PC driver gets lost.
You may need to go to Dell's Web site to locate your specific Model's audio card driver and then reload it.
Worth a try!
Blessings,
A/V Media Guy
Nov 22, 2009 | Dell Latitude D630 PC Notebook
Dell Latitude D630  PC Notebook Logo
175 people viewed this question
Alun Cox
