Mitsubishi VRF error code E03 outdoor unit - Heating & Cooling
  • 87 Answers
SOURCE: Error Code E03-36
pull out toner bottle from machine
shake it well
reinstall it
power off then on
code will bi reset
Posted on May 09, 2009
greenspan
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
  • 34 Answers
SOURCE: mitsubishi mr slim mn PUL18EK outdoor, PL18FK2
8 flash is a pipe temperature error.
Posted on Aug 13, 2009
  • 3 Answers
SOURCE: Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Posted on Aug 14, 2009
  • 224 Answers
SOURCE: error code e03-40
---Copy Density Sensor output adjustment-----
1. Sensor connector is disconnected.
2. Sensor is defective.
3. SPC PCB connector is disconnected.
4. SPC PCB is defective
there is a sensor in the drum unit that measures/sensors toner density on the drum. the sensor is usually dirty and needs a clean. there could be a number of causes so a technician needs to be called.
Posted on May 04, 2010
H2 error on ODU display
https://www.carrierair.com.au/installer-and-technical-support/fault-codes/
Check the links to talk to a technician or service. I find no easy access to matching a sheet of error codes with your carrier VRF on the web. I encounter codes but the sheets fail to identify the models! Those codes refer to a decrease malfunction which defies interpretation by any but an air conditioning technician. So, the most direct route to your query answer is at the above link.
Jun 16, 2017 | Carrier Heating & Cooling
E03-51 error on dp 6030
Hello Sir; the error code you indicated is corona wire problem, check the charge & discharge unit the corona wire is broken or not, replace it if it does.
Oct 06, 2012 | Office Equipment & Supplies
What does error code E6 mean? On a Mitsubishi Mr. Slim A/C
Code E6
Error detail Indoor/outdoor unit transmission error (signal receiving error).
Inspected unit Indoor.
Air Conditioning Fault Codes
Aug 01, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
P8 showing on air cond and air con is not working
P8-Abnormality in outdoor unit.
Solution:
1) Check the indoor/outdoor connecting wire in proper point.
2) Change the connection of electric wiring, if reversed phase.
3) Check the protection device, if malfunction, replace it.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Thanks.
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
What does error code p8 mean
P8 means Abnormality in outdoor unit.
Check:
1) Wrong wiring of indoor/outdoor
connecting wire
2) Reversed phase
3) Protection device is working
4) Damaged outdoor coil thermistor
Solution:
1) Check the indoor/outdoor connecting wire.
2) Change the connection of electric wiring.
3) Check the protection device.
Hope, helpful.
Feb 03, 2011 | Mitsubishi Heating & Cooling
We undertake annual maintenance contract for Sanyo VRF air conditioner at standard charter bank nepal ltd., we have found the AC dose not function as well now. The fault shows as E4 on remote control. Now...
E04Indoor seeing error from outdoor. Qty of i/d units connected are less than qtyset. Check; all i/d units are ON,
reset turn off all units wait 5min power up
Helpful?
Jan 28, 2011 | Heating & Cooling
Eo error code indoor unit runs 2-3 seconds then gives eo error code problem started when mr chipmunk chewed mr slims 12 volt wire connecting to out door unit and shorted it . Outdoor unit has bad control...
You need a professional here. Once this has been repaired, I would suggest running the wiring to the outdoor unit inside some sort of piping to protect it.
Jul 20, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Ac unit shuts down
See this document for P8 code on Mitsubishi Mr Slim MXZ30TN... It is likely you can get the fix just from following the diagnosis steps 1-7. http://www.digelair.net/pdfs/TECHLIT/MITSUBISHI/MrSlim_P-SERIES_Troubleshooting_TIPS.pdf
Jul 02, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
PANASONIC UF-8000 ERROR CODE E03-20, copy function not working.
Error code E3-20 Main Motor Rotation.
Loud clicking sound fuser unit drive gears cracked not driving
Apr 01, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
