Sony vaio laptop shutting down while plugged in
While my sony laptop is plugged in charging, open and on, it will randomly hibernate or go to sleep by its self i bought the laptop brand new and its done it since day one
  • 7,627 Answers
If it's left on for a period of time, specified by the power settings, it will dim the display, Hibernate, Sleep, etc. In the Control Panel, Power settings, Advanced Power setting , Change to High Preformance, adjust Hibernate and Sleep to Never, adjust advanced power setting to your specs. Shut down and unplug laptop , remove battery, when not in use, if you use on AC most of the time remove battery.
Posted on Jan 05, 2013
  • 2 more comments
  • nicklasbpalm
    nicklasbpalm Jan 05, 2013
    all that is set like that and ive tried taking the battery out while its plugged in, it doesnt do it after a certain amount of time just randomly when ever it wants, sometimes after a half hour sometimes it will do it after 2 min, and will even do it another 2 min after you turn it back on, ive noticed the power supply block get pretty hot but the laptop dont feel hot, ive also tried the underlaptop cooling station, didnt help at all either, but it only does it when it is plugged in to the ac adapter
  • max carson
    max carson Jan 05, 2013
    I would suspect it getting hot and shutting down, on battery the laptop will shut down or reduce settings to conserve battery. Make sure the fan and vents are clean. It may be a sensor fault or a component failing. It's difficult to be presise. The "brick" or transformer will get hot, Is it a replacement?
  • nicklasbpalm
    no its the original, my only guess is internal parts that have to do with the power
  • max carson
    max carson Jan 06, 2013
    I would say your on the right track. Go to Sony support websites and forums , there may be a hotfix/patch that address the issue or is a re-ocurring problem.
5 Suggested Answers
RPFinney
  • 385 Answers
SOURCE: Sony VAIO VGNCS215J Logging Off Problems
Update the O/S
Check your power options in control panel,
Adjust for your lifestyle.
Hope this helps
Regards
Posted on Apr 19, 2009
  • 62 Answers
SOURCE: My laptop screen will not shut off
if u r using vista sure check the shutdown button.
or press once power button it automatically shutdowns
or hold power button until it shut down
when u close the door it only standby..
Posted on Oct 24, 2009
itsourcer693
  • 34 Answers
SOURCE: sony vaio, windows vista...problem is battery error
Try unplugging the power supply from the computer. Turn it off and then after 2 mins restart it. (Plug it back into the computer)
Posted on Jan 05, 2010
  • 4044 Answers
SOURCE: I just bought this brand sony vaio new laptop and ...
You need to register the Vaio and if you are using the MS office that came on the computer you will need to go through the purchase and registration process. The version they put on computers today is a 90 day temporary trial that requires you to purchase a product key to continue using it. You can go to Walmart, Target, Best Buy and purchase the software there to get your key if you prefer. It will cost the same.
Posted on May 23, 2010
Sony vaio PCG-7142L keeps freezing
Can check if the battery is low ... or is not (or cannot) holding a good charge ... when you unplug it (from the charger) ... when this happens ?
If that is the case, it may "freeze" while it is busy trying to store the contents of your memory before it shuts down (or hibernates). Does it shut down (or goes into hibernate if you let it continue to "freeze") for a while ? If so, then it's your battery.
If the battery doesn't hold a good charge, the laptop will run only a short time (while unplugged) before it has to shut down due to low battery. And if this is the case, consider getting a replacement (new) battery. And follow the initial charging instructions (for a new battery) to lengthen the life of the battery.
Apr 03, 2014 | Sony VAIO Computers & Internet
Toshiba satellite pro does not fully shutdown
In Control Panel, select Power Options, you didn't post your OS?, set to High Performance, open Change Plan settings, set Computer Sleep Never, open Change Advanced power settings, scroll through the settings, set Sleep and Hibernate to Never, open Power Buttons and Lid, set to shut down. Now the red X on the Battery Icon usually means the battery needs replacing, it's not charging. Shut down the Laptop unplug, remove battery, plug in , reboot.
May 12, 2013 | Toshiba Satellite Computers & Internet
My sony vaio vgn-nr32s has a onboard vga problem,when i heat the board, it will come up and in three days the screen will go blank again.pls what will i do?
First, do you leave the laptop plugged in and on all the time? If so , Why? If you shut down and unplug when not in use your machine/battery will last longer and avoid any power surge issues. Make sure the fan and vents are clean and free of dust, use a can of Compressed Air to clean. Also, Open the Control Panel, select Power Options, select High Performance, set plugged in settings to Power Button: Shut Down, Sleep Button: Sleep, Close the Lid: Shut Down, open change plan settings/advanced power options, look through the advanced settings select Hibernate to Never, set other settings to your preference. Use this procedure: http://www.dotnetcurry.com/ShowArticle.aspx?ID=158
Mar 18, 2013 | Sony VAIO Computers & Internet
When laptop charging in off position and if i connect usb pen drive, ext. HDD, etc. these are on and flashing
Is the laptop off or Hibernating? Sleeping? Open the Control Panel, Power Options, Set to High Performance, open Advanced Power settings, set Hibernate and Sleep to Never. Shut down the laptop at the Start Menu. If the AC cord is plugged in the battery will charge. Nothing else should work.
Jan 16, 2013 | Lenovo 3000 C200 CM 520 1.6G 512MB...
My sony won't shut down. it will only hibernate
Go to power options and uncheck hibernate mode.
May 10, 2012 | Sony VAIO TR2A Notebook
My Vaio doesn't go to sleep/hibernate when closing the lid
Maybe the little sensor or pin that sticks up and is pushed in when you close the lid is broken and the software doesn't realize the lid has been closed.
May 02, 2012 | Sony Computers & Internet
The sleep and hibernate buttons are grayed out. Running XP SP3 and on a Sony Vaio VGN-T150
install the keyboard drivers, go here:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVW600G
Go down to the keyboard section and download that piece of software and install it. That should take care of the sleep and hibernate buttons not working.
Dec 30, 2009 | Sony VAIO PCV-W600G PC Desktop
My laptop screen will not shut off. I have a Sony Vaio about 6 years old. When I power down the screen shuts off while everything is shutting down but then when everything is off the monitor turns a light...
Oct 22, 2009 | Dell Inspiron E1405 Notebook
Update the O/S
Hope this helps
Regards
Apr 19, 2009 | Sony VAIO VGN-CS215J/W Notebook
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
