Question about Streamlight 61082 BuckMasters Trident Headlamp HP, White LEDs Realtree Hardwoods Blaze Orange / Flashlights & Lighting > Standard Flashlights & Acc / 61082
The light would not go off
3 way lighting
    New Friend:
  • 57 Answers
Sounds like another Bad switch.Common lately.
Posted on Jan 12, 2013
I have got hotpoint -ultima super silent wf 865 is getting sign f-12 pl let me know the solution.
These are the error codes : I hope it helps!
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure switch stuck on empty
Nov 11, 2014 | Washing Machines
F-03
f16 N/A
f1 and f17 share the same light
Jun 21, 2011 | Indesit W 123 Front Load Washer
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
E03 error code
Error Codes
f16 N/A
Aug 09, 2010 | Siemens WTXD8300 Electric Dryer
I want to wire a 3 way switch with multiple lights between the switches. The easiest route and least wire used is power in at switch then to lights then down to second switch. would i use a 14/3 from...
You have to run the 3rd wire all the way to the switch, whether it hits any lights or not, I have seen electricians pull a single wire in to the box with the 14/2 and that would be the jumper. This will work on any lights, and the lights only need the 2 wires, It is just the switch that needs the 3 wires. Good luck.
Feb 22, 2010 | Lutron Dimmers S103PNL 1000W 3-Way, Preset...
Hotpoint wf310 set wash,it starts then after about 20 seconds the on/of light and the lights to the far left flash
you will have to check the error code number which you get as per the blinks.
f16 N/A
ignore the on off light
as per the fault mentioned you will have to check the fault in your unit and then replace that following part in your unit.
you can get required parts from
www.repairclinic.com and also from www.partselect.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 27, 2009 | Dishwashers
Hotpoint Aquarius cycle not finishing with f02 error
Dont think its pressure switch.if sticks one way machine overfills the other brings on heater with empty drum..Could be fauly rinse solonoid valve...Check with multimeter coil should read around3k ohms..good luck
Sep 29, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
I'm after some error codes please guys, It's flashing 2(Reduces Creases) & 4(Time Saver) I've been told that these 'do' mean something, but can I find out what it is....no Any help would be really...
List of the Error Codes I found on another site. I'm getting f04 light 2 (the "wash" light). Looks like you've got the opposite problem with your pressure switch stuck on full (f05).
f16 N/A
Sep 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Streamlight 61082 BuckMasters Trident Headlamp HP, White LEDs Realtree Hardwoods Blaze Orange / Flashlights & Lighting > Standard Flashlights & Acc / 61082 Logo
134 people viewed this question
Top Streamlight Camping, Backpacking & Hiking Experts
Stan Ford
Tom Chichester
Are you a Streamlight Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
