Question about Vizio L32 32 in. LCD HDTV
Download manual for Vizio 32" hdtv model E32-AO
Model E320-AO
    Top Expert:
  • Vizio Master
  • 75,571 Answers
Check this link to download it.
Posted on Jan 05, 2013
SOURCE: Vizio L32 HDTV 10A won't turn on
I bought my 42" plasma Vizio 17 days ago and this problem just happened to me. We were watching and it just went off and it won't come back on. The tv clearly has power as the yellow light is on, but this tv simply won't come on. I called Walmart to verify I could return (I can) and they said they have two others that were returned sitting in back. I imagine this is going to force Vizio to do something soon, I can only imagine how many of these things are going to start failing in the years to come.
Posted on Aug 17, 2008
SOURCE: VIZIO TV MODEL L37 HDTV CODES FOR THE REMOTE
I found the codes online at DishTV
505,627,775,758,756,885,864
Posted on Apr 11, 2009
  • 17 Answers
SOURCE: Power board for 32 in. Vizio
Yeah Shopjimmy has over 20,000 parts for vizio! I bet they would have a power supply for your tv. their website is www.shopjimmy.com
Posted on May 07, 2009
  • 8457 Answers
SOURCE: hdmi on vizio hdtv input says not support
Ur board is shorted it cost alot to replace the board for just the HDMI port to use.Must change the board or use the S-Video port.
Posted on Aug 17, 2009
1joester2
  • 74 Answers
SOURCE: I have a Vizio hdtv 32
I would guess the power supply went bad. The Vizio parts store sells the replacement for $82. Cheap fix for a decent TV.
Replacing it only requires a moderate mechanical skill. Removing the screws from the case is the hardest part. Remember to unplug the TV before you attempt this repair, or contact a local repair shop. They may only charge a small fee to install it for you.
Posted on Dec 19, 2009
Testimonial: "Thanks I thought that might be the problem.... Do you have a web address for the vizio parts store?"
My vizeo e320-ao has sound but no picture. is it the backlight
T'Con board fault. Check and replace it if you can. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 10, 2017 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Suddenly won't come on
Main power supply regulator board fault.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Jul 27, 2014 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Vizio E320-A0 ... no signal
It would appear your signal board was damaged so it will require replacement. . If you purchased s extended warranty on the set it may be covered under the accident provision. If not you can go to Vizios site with the model no and locate the replacement board . If your capable you can order it and change it your self or contact a local servicer to assist or replace the set which may be more economical
Mar 06, 2014 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Do you have to have a HD cable to hook up a PS3?
There are two ways you can connect your PS3 to your VIzio. First, you can do it with HDMI cable. Here the HDMI output from PS3 goes to HDMI input of the TV. Second, you can do it with the AV multi out cable.Here the multi output from the PS goes to AV input of the TV. After doing this please select the source accordingly. Good luck.
Dec 30, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
Can't download manual
http://store.vizio.com/documents/downloads/hdtv/E320iA0/UM_E320iA0.pdf
Check to make sure you have Adobe Acrobat X Reader or some other PDF reader installed before you attempt download and read this file.
Oct 16, 2013 | Vizio E320-Ao 32 Class Led Hdtv - 720P,...
How to download manual for model E329-A1
Check your model number. There appears to be no Vizio with that number. If it is a E320-A1, here's the manual: http://store.vizio.com/vo320e.html under the support button.
Sep 11, 2013 | Vizio L32 32 in. LCD HDTV
Where can I download an owners manual for this vizio tv?
You can get the manual on the link below. If this is not your model Then please give the correct model # so I can get you the correct manual.
http://vizio.com/documents/downloads/hdtv/L32/Manual.pdf
Jun 10, 2011 | Vizio L32 32 in. LCD HDTV
Lost my users manual for Vizio L32 in. HDTV LCD TV. Where can I download/consult another?
You can download a manual for the VIZIO website.
http://www.vizio.com/downloads.aspx
Enter your tv model number and click on the manual/guide link returned.
Feb 24, 2009 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
657 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
