Turned on my soniq 32" tv like i usually would and it just started flickering, not giving me a clear picture. Checked the antenna cable, wasn't the problem. Have turned it off and back on, still flic
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 3 Answers
The problem with the SONIQ L32V11 A/B/C with built in or without DVD players is the Power Save mode.This will be from the Main PCB . The power supply/Inverter Pcd is not faulty. Can be fixed by just a small mod.Here is what you have to do go to CN 4 this is a plug with 4 wires from the Power supply to the main PCB. Look at the marking on the Power PCB says Adjust/ cable marked by xxx. Trace this to the main board .Cut the wire xxx close to the plug on the main board.( xxx ) now solder this direct to center Pin of the 3.3v Reg Ic . IC number U37. This mod will over ride the voltage change in power save mode.BINGO your TV will work as good as NEW. If not sure what to do go to my web site will be happy to help all you guys out and save land fill.www.viewclearvision.com.au
Posted on Nov 09, 2013
  • Willem Amoraal
    Willem Amoraal Aug 04, 2014
    Brilliant. That was exactly what I was looking for!. Worked a treat!!
  • Ricahrd
    Ricahrd Aug 25, 2014
    Did every thing you said, and it made it worst. No good tv still has the flickering problem.
  • Televison & ... Master
  • 16,450 Answers
This is most likely a component failure on the inverter or the power supply.
Posted on Jan 05, 2013
  • 267 Answers
SOURCE: I have a two year old high def LG Plasma TV Model 42PC3D. Have so
You probaly have a bad y or z sustain board
Posted on Jun 26, 2009
  • 53 Answers
SOURCE: no sound on sharp aquos LC32D6U
The problem is the silicone grease under the audio IC has melted and is shorting the audio circuit. To fix this, you'd have to clean the melted residue off the audio IC. It is a complicated job and I suggest calling your local Authorized Sharp service center to do this repair.
Posted on Mar 14, 2008
SOURCE: Hitachi Plasma screen flickers
Got sound but the picture intermittendly flickers on and off. checked all cables and connections had the tv about 3 years now.
Thx
Posted on Sep 07, 2008
SOURCE: Television has sound but no picture
You can try unplugging the tv and wait for a couple minutes and then plug it back in... I just did this and now the television works again.
Posted on Jan 31, 2009
  • 108 Answers
The problem with plasmas is that this problem can be caused by four or more circuit boards. You have to check alot of different things to isolate which board is the problem. The unit should be taken to a repair shop because the voltages inside are "Dangerous". This can be expensive to fix, price ranges from $100-$300 a board, plus labor.
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
Gpx 32" tv/dvd player, no picture only sound
Do you have a cable provider that gives you TV service ? Or do you use a regular ("rabbit ears") antenna ?
Dec 14, 2014 | GPX 32" 720p LCD HDTV/DVD Combo
I can get a picture on my TV but it's all snowy
This could be due to a loose plug or deterioration of the aerial cable or a bad connector. Since I don't know where your aerial comes from I can't be more specific but
Have the antenna cable checked or try the tv on someone else's antenna. Snowy pictures are usually caused by a poor aerial signal (aerial = antenna),
Aug 07, 2014 | Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Durabrand 13' DU1301 TV problem: I can barely see the picture or hear anything because of intermittant snow. Sometimes the picture will roll as if we are back in the 70s. When I turned the tv on its...
Hello
The fault you describes is due to low signal strength. If tuner of the said TV is faulty, this type of snow interference will occur too. Just check for good firm connection to its antenna terminal. If it is Ok, check the continuity of the cable used with antenna. Check the orientation of yagi antenna if used outside. If all are OK, and nothing help you, just replace its tuner with same type and number. Tuner is a small metal box type component can be seen soldered directly to the main printed circuit board inside. Usullay, its one terminal will come out as antenna IN of the TV, to which you connects the external antenna or cable. You must have a concept of soldering and desoldering to replace it, and must have a knoledge in electronics too. OK.
Jul 29, 2011 | Durabrand DU1301 TV
32" 32lc7d after a few minutes, flickers, then goes dark.
There are no fans in this model but it looks like either the backlights in the screen are breaking down after they have warmed up or a problem in the inverter board, again part of the driver circuit breaking down after a period of time. They inverter boards can sometimes be replaced seperatly but usually come with a new screen which if the backlights are at fault then the screen would need to be replaced.
Feb 04, 2010 | LG 32LC7D Television
Toshiba 32'" tv wont give sharp picture
no rocket science here - my son fiddled with the cable cord attachment, until presto, the screen became sharp. Then we moved away as fast as possible, lest we shifted it and it put us back at square one.!!
Jan 26, 2009 | Toshiba 36A50 36" TV
Picture shows snow and fuzz on channels JVC AV-32980
Sounds like U have an antenna or feeder problem. Get it checked out/ check it out. If in a strong signal area, try a simple indoor antenna for comparison. If in a marginal reception area, it could be your antenna is inadequate.
Mar 27, 2008 | JVC AV-32980 32" TV
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Split screen from DVD player, cable is fine no problem
It is not clear where you say input is from cable, do you mean the Scart input to your Sony TV? Do not use Progressive scan(p), as this is not interlaced. The normal TV requires an interlaced(i) picture of 50 half frames per second giving 25 complete pictures per second to reduce flicker. Some TVs and projectors and all monitors accept Progressive scan.
Oct 15, 2006 | Sony KV-32S25 32" TV
Open Questions:
Televison & Video Logo
2,464 people viewed this question
Top Televison & Video Experts
Electro Med Services...
