Question about Keurig B60 Coffee Maker
Coffee maker will not work, now it says to descale?
How do I descale when it is already dead?
  • 1,511 Answers
Say goodbye to the unit as it is dead as reported and can no longer be revived.
Posted on Jan 31, 2014
SOURCE: Coffee maker makes cream curdle
Run two or three reservoirs full of plain water through the machine to rinse out the descaler, which is acidic.
Acid curdles milk.
Posted on Nov 21, 2008
  • 3 Answers
SOURCE: pump starts then stops. I have cleaned all holes.
Mine would only very loudly pump a partial cup after about two years of use. I tried everything, including descaling. Even held my mouth different ways. I took it apart three times, the last time intending to glue all the rubber hoses. By accident I discovered a plastic "filter" in the intake line just below the water reservoir. I removed it, cleaned it out on both sides with a toothbrush, put it back in, and now it works like new. The filter is easy to get to if you take the bottom metal plate off: 5 screws for that, then two screws in the filter unit directly under the reservoir. You get to it from underneath the coffee maker. Pull the black cover back to expose the plastic hose, then pull the black filter out.
It is easier to do than to describe.
I have not seen this fix anywhere on the net, but I can verify that it works.
Posted on May 20, 2010
espressonist
  • 1711 Answers
SOURCE: what do I use to clean and descale my keurig
You can use white vinegar and follow instraction below
http://www.fixya.com/support/r5544114-keurig_home_brewer_instructions_de
Posted on Aug 17, 2010
SOURCE: keurig b70 coffee maker stops brewing mid cycle
coffee maker stops brewing half way through brewing.
Posted on Nov 23, 2010
heatman101
  • 43501 Answers
SOURCE: How do I descale my Keurig coffee maker
Check out this tip about how to descale your Keurig coffee brewer
How to Descale your Keurig Coffee Brewer
heatman101
Posted on Feb 23, 2011
Why does it keep repeating 'descale' command when it has been descaled already?
If the commend repeats amd wont let you use your coffee maker, even after you've prceeded to descale it, you have got aproblem.
Ask dealer or manufacturer (through Contact page of website. Look for nearest authorized repair service
Oct 05, 2015 | Coffee Makers & Espresso Machines
How to descale machine talea giro plus
Many times if you perform once more descale the problem can be solved so here is a video that can help to repeat the descale
Aug 28, 2012 | Saeco Odea Giro Plus Coffee Maker
Can you descale a coffee machine with white vinegor ?
Yes. A 20% solution of white vinegar will descale any coffee maker. I prefer to run straight water for 1 cycle after this process to ensure no vinegar aftertaste remain. I've been using white vinegar to descale my coffee makers for years and it works great.
Aug 09, 2011 | Philips Senseo HD-7810 Coffee Maker
Coffee maker is on. will not make coffee,will not take more water. just sits there like it is dead. descale light came on first. cannot descale because it will not take or give water. help olease.
I would first empty out any water that is in the machine, and get the grounds out. Then, the machine up with a 50/50 mixture of distilled water and white vinegar. You may need to let this sit in the machine overnight because the vinegar needs time to work it's magic. Then turn it on and run this mixture through, if the machine is descaled enough to run. If it doesn't, do it again. The key to descaling is the vinegar, but like I said, it needs time to dissolve the scale. If it works, then run a couple of pot's of just water to get rid of the vinegar smell. Give it a try!
Feb 13, 2011 | Keurig B100 Coffee Maker
How do i get the red light to go off on my coffee maker i already descaled it
You have to ensure the descaling function runs completely to the end. Occasionally the water tank will be empty BEFORE the descaling program has finished, in which case you should refill it and let it continue descaling.
The light wiill automatically go off once the descaling program has been fully completed.
Mar 20, 2010 | Braun Tassimo Espresso Machine/Coffee...
How do |I get the red light to shut off? I have already descaled etc. Thank you
You have to ensure the descaling function runs completely to the end. Occasionally the water tank will empty BEFORE the descaling program has finished, in which case you should refill it and let it continue descaling.
Sep 25, 2009 | Braun Tassimo Coffee Maker
My Keurig one-cup coffee maker heats the water but does not dispense it. I'm guessing it needs cleaning/descaling. How do I do that? Lee Laidlaw
There is a post on descaling already but I think the unit just doesn't have enough water in the resevoir. See several of my other posts on how to fill the machine.
Jan 24, 2009 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
47 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
