Question about Exercise & Fitness
Changing units from km to miles - Exercise & Fitness
  • 21 Answers
You will have to get into the engineering mode on your treadmill. This can be found through the manufacturers website and under the tech doc for the unit. it will be a combination of holding a couple buttons on the console to access the deeper modes of display
Posted on Jan 05, 2013
Does distance show kilometers or miles?
On a digital display the default in U.S. is miles. Refer to your owner's manual or call dealer if you need to change it. A km is .6 of a mile, so just drive about 10 blocks (around a mile). If the odometer registers around 1 unit more it's probably miles, if it says close to 2 then it's probably km.
May 08, 2016 | Cars & Trucks
How to reset change oil soon light
Oil Life Monitor Resetting (KD, KE)
Description
The engine oil life monitor will indicate when to change the engine oil and the engine oil filter - usually between 5 000 km (3,000 miles) and 12 500 km (7,500 miles) since the last oil change. Under severe conditions, the CHANGE OIL message may be displayed before 5 000 km (3,000 miles). The vehicle must not be driven more than 12 500 km (7,500 miles) or 12 months without an oil change.
The engine oil life monitor will not detect dust in the oil. If the vehicle is driven in a dusty area, be sure to change the oil every 5 000 km (3,000 miles) or sooner if the CHANGE ENGINE OIL message is displayed.
Reset the oil life monitor when the oil has been changed.
Resetting Procedure
Press the INFORMATION SKIP button on the DIC control panel in order to display the OIL LIFE LEFT message.
Press and hold the RESET NO button until the display shows 100% ENGINE OIL LIFE.
Jan 29, 2016 | 1999 Cadillac DeVille
How do I change the mileage from kilometers to miles on my 2009 Ford Fusion?
I km = .62 miles.
10000 km = 6200 miles.
Check car manual to see if the display can indicate miles in lieu of KM's
Sep 25, 2015 | 2009 Ford Fusion SEL
At what mileage should the timing belt be changed on a citroen berlingo
What does your owners manual say?
60,000 miles/36 km
75,000 miles/45 km
90,000 miles/54 km
Not more than 90,000 miles or
6 years
If it breaks,the valves get bent
Call a dealer or stop by & ask
May 10, 2014 | 2010 Peugeot Partner HDi
Schwinn 250 Units setting
replace the batteries by new ones. and clean the contacts batteries very well.
2) adjust the Reed switch, see the diagram, test for open or fulty, clean it, and tight the conector v. well.
However you must to back to the display are small orifice, Use the point o eraser pens, and click the small switch for to change. the Km or miles or vice. versa.
Jan 20, 2013 | Schwinn 250 Recumbent Bike
Changing kilometer from mile on afg 7.1at treadmill
Hi there. I add the same problem as well. Below are the steps I used to fix my problem.
In order to switch your distance calculation between miles and kilometers, please follow these instructions:
  1. Turn on treadmill, put safety key in place
  2. Press and hold the INCLINE + and SPEED - keys for about five seconds or until machine beeps three times. En90 or Eng0 should appear.
  3. Use the SPEED + key to navigate to En93.
  4. Press ENTER once.
  5. Press START to choose unit (miles or km). The display will change accordingly.
    1. Miles: 0
    2. Km: 1
  6. Press and hold STOP or exit and replace the safety key to return to the normal start screen.
NOTE: To be sure that the treadmill is displaying your desired unit, simply press START and observe the first start speed to display. If it displays 1 or .5, it is in miles. If it displays .8 or 1.6, it is in kilometers. Also note that by changing in metrics the Lbs will also convert to Kg.
Hope this help.
Dan
Dec 25, 2012 | AFG 7.1AT Treadmill
Is it possible to change the unit of distance and speed from km to miles on a Kettler Giro GT?
Dear Sir:
Go under the display board, and we the point from some pencil, introduce in the small orifice, reset and you will have the change km vs mls or viceversa.
sincereLY. God bless you
May 03, 2012 | Kettler Exercise & Fitness
Alfa romeo 147 flashing dasboard
This is so you can set it, just set or reset the time on the clock and it will stop flashing, same thing with the km,move from km to miles and back, if you want km then set to km but if you want miles then go to miles but you must select through it, good day.
Feb 19, 2012 | Alfa Romeo Cars & Trucks
Trying to find the owners manual for 2001 saturn sc2 as well as the maintenance schedule etc provided when the car was new
Scheduled Maintenance The service shown in this schedule up to 150,000 miles (250,000 km) should be performed after 150,000 miles (250,000 km) at the same intervals.
See Owner Inspections and Services for maintenance information.
Scheduled Maintenance Mileage
Maintenance Group No.
6,000 Miles (10 000 km)
18,000 Miles (30 000 km)
30,000 Miles (50 000 km)
36,000 Miles (60 000 km)
42,000 Miles (70 000 km)
50,000 Miles (83 000 km)
5
54,000 Miles (90 000 km)
60,000 Miles (100 000 km)
6
66,000 Miles (110 000 km)
72,000 Miles (120 000 km)
78,000 Miles (130 000 km)
90,000 Miles (150 000 km)
7
100,000 Miles (166 000 km)
8
102,000 Miles (170 000 km)
108,000 Miles (174 000 km)
114,000 Miles (190 000 km)
120,000 Miles (200 000 km)
6
126,000 Miles (210 000 km)
138,000 Miles (230 000 km)
150,000 Miles (250 000 km)
5
Maintenance Requirements - Group 1 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). Maintenance Requirements - Group 2 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). • Inspect the engine accessory drive belt and coolant hoses every 12 months or 18,000 miles (30,000 km), whichever occurs first. Maintenance Requirements - Group 3 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). • Replace the engine air cleaner filter every 36 months or 30,000 mile (50,000 km), whichever occurs first. An Emission Control Service . (See footnote) • Inspect the vacuum lines/hoses every 24 months or 30,000 mile (50,000 km), whichever occurs first. An Emission Control Service . (See footnote) • Replace spark plugs. An Emission Control Service.
Oct 05, 2010 | 2001 Saturn SC
2002 Jeep Grand Cherokee Limited pre form service needs to be erased
Service Interval
When this feature is selected a service interval between 2,000 miles (3,200 km) and 6,000 miles (10 000 km) in 500 mile (800 km) increments may be selected. Pressing the STEP button when in this display will select distances between 2,000 miles (3,200 km) and 6,000 miles (10,000 km) in 500 mile (800 km) increments.
Reset Service Distance (Displays Only if Service Interval was Changed)
When this feature is selected the current accumulated service distance can be reset to the newly selected service interval. Pressing the STEP button when in this display will select "Yes" or "No."
Nov 02, 2008 | 2006 Jeep Grand Cherokee
Exercise & Fitness Logo
130 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
