Which electronic tablets are suitable for INDESIT WIXL85 ,washing machine?
INDESIT WIXL85 SERIAL NUMBER 46471950100
4 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Indesit WIXL85 water level
On a normal wash cycle, you will see very little if any water sloshing around, this is quite normal on todays washers.
You shuold see a lot more on the rinse cycle, as it is a higher fill.
It is usual to more less fill the compartment with powder, unless you are only washing a few items, then half fill it.
Hope this helps.
Posted on Dec 19, 2009
barkencoa
  • 3463 Answers
SOURCE: I HAVE AN INDESIT WASH MACHINE WIXXL 86 AND
Afraid not, as the progs will not be compatible, and even if the plug on leades fit, it will not give you same progs.
Posted on Feb 13, 2010
blueextc3221
  • 15935 Answers
SOURCE: indesit washing macine displaying error code F-11
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
The message flashing says 'door' what do I do?
You have a problem with the door switch interlock.
Indesit WIDE 146 (DE) Washing Machine Spares ' eSpares
www.espares.co.uk > Home > Washers & Dryers > Washing Machines > Indesit
  1. Cached
Items 1 - 10 of 60 - Universal stacking kit suitable for most washers and dryers measuring 60cm across More information. In Stock. Stock Number ES187394.
Get Indesit Washing Machine Spare Parts ' eSpares
  1. Cached
  2. Similar
Genuine Indesit washing machine spares including Drum lifters, Indesit ... Start your Indesit parts search by selecting your washing machine model number from ...
Indesit Washing Machine WIDE 146 (DE) Spares - indesitspares
www.indesitspares.co.uk/washing-machine/wide-146-de.../catalogue.pl?path...
  1. Cached
Indesit WIDE 146 (DE) Washing Machine Spares ... Fits models with serial number from 30127.0001 Please Note the above serial number changes does not ...
Indesit Washing Machine IWDE 146 UK Spares - indesitspares
www.indesitspares.co.uk/washing-machine/iwde-146-uk-f084074/catalogue.pl?...
  1. Cached
Indesit IWDE 146 UK Washing Machine Spares ... This part fits the following models: WIL133UK, WIL133UKCO, WIXE127UKV & Does Not Fit Mod. .... If you have just replaced the door seal on your appliance then you may need this retainer ...
Indesit Ecotime IWDE 146 Built-in Washer Dryer - White
www.indesit.co.uk/appliances_i/Washer_Dryer_IWDE_146/pid_F084074UK/42.do
  1. Cached
  2. Similar
Rating: 8.5/10 - ‎19 votes Indesit Ecotime IWDE 146 Built-in Washer Dryer - White, ... News & Offers; Service & Spares. Service · Spare Parts ... IWDE 146 reviews · Ask-an-owner ...
Washer dryer no wide 146 Google Search
Mar 24, 2017 | Washing Machines
How to take out water pump
There are two ways of fixing drain pump depending on serial number of appliance. One easy mounting with three screws and the other is using the anchor tab where you should turn the drain pump counter clockwise and remove.
25602824-2cx31aa5jn1eijqkorrs11s2-4-2.jpg Also, follow this link:
http://www.espares.co.uk/advice/0/2308/indesit-washing-machine-pump-replacement-and-f11-error-
Dado
Mar 23, 2015 | Indesit Washing Machines
Dishwasher cloudy glasses
I do not have enough information to be able to answer with hundred percent certainty.
From my experience, the most common problem is the improper handling of the appliance. Driven by overwhelming commercials we often pass from detergent to tablets. The largest number of tablets contains rinse aid that we already have in the dispenser. Practical adding a double dose of rinse aid resulting in poor washing results and glasses look like washed in milk. The solution is to open the dispenser and put the dosage rinse aid to minimum. In electronic dishwashers new generation is even possible to completely exclude the dosage rinse aid if you are using tablets.
Dado
Aug 26, 2014 | Indesit Dishwashers
My indesit washing machine doesnt seem to be washing clothes they come out still dirty after a 40degree wash and sometimes dont smell nice. I put a tablet in the drum & loads of conditioner &...
indesit washing machine doesnt seem to be washing clothes they come out still dirty after a 40degree wash and sometimes dont smell nice This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
And don't forget to like us on facebook
Aug 15, 2011 | Washing Machines
I need ford radio code
Post the SERIAL NUMBER found on a label on the radio casing
It normally begins with M xxxxxx
Mar 24, 2010 | Indesit W 123 Front Load Washer
I HAVE AN INDESIT WASH MACHINE WIXXL 86 AND ELECTRONIC MOTHERBOARD IS NOT WORKING ,WILL A MOTHERBOARD FROM INDESIT IWD7085 MATCH?
Feb 13, 2010 | Indesit W 123 Front Load Washer
Hope this helps.
Dec 19, 2009 | Indesit W 123 Front Load Washer
Hi there where can i download an operation manual for an Indesit WIL103 washing machine thanks
Hi
In your browser bar type in---- indesit user manuals
In the drop down list click on------indesit- manuals-user guides-handbooks-indesit service
In the search box type in your model number, and down load instructions.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
