Question about LG LMV2053 Microwave Oven
Our Expert microwave buld blew and now...nothing
We tried to replace the buld under the unit, and it broke off in the socket. we got it out, and now the unit will do nothing at all. no lights, no nothing. the fuse is fine and our main breaker is fine. we have seen that you suggest repairing the board and when we search for you on yahoo...we find nothing. please let us know where to go and what to do...the search on yahoo does nothing for us. we have a 2001 year "Expert" (distributed by LG)microwave model number exv1511b
    Problem Solver:
  • 18 Answers
Have you checked the 10 amp internal fuse. It is located where the pwer lead enters underneath the cover
Posted on Jul 10, 2007
SOURCE:
Has stopped working. light gone off at same time. plug fuse has not broke. any ideas ?
There is a fuse inside the microwave also.It is a ceramic fuse,usually 15A.It has to be replaced with another ceramic fuse of the same rating.Bear in mind,the fuse blew for a reason,so if it is the interior fuse replace it after a search for a fault.
Dec 17, 2014 | Microwave Ovens
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
Have a Whirlpool RMC275PD microwave. Light bulb
no, no, no,,,its far to dangerous for you to open up the case of your microwave to change a light buld,,,
dont even think of going in there,,,
inside your microwave there are 1000,s of volts stored up in a capacitor if you tuch it you could kill yourself
have you ever seen a police stun gun working,,
it realy hurts you,,,,,
inside your microwave is the stun guns big brother
it dont just stun you,, it could kill you,,,
thats why you dont go inside it ok,,,
the light buld can be changed from inside the case normaly if it cant be, then drop it in the shop for a repair or use it with out a light in it,,
dont try and kill yourself just for a light buld
Oct 31, 2009 | Whirlpool RMC275PD Microwave Oven
Exact same problem - Needlenose slipped and spark in the socket
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You have a short in one of the door safety switches
There function is prevent the oven to work whit the door open
some are normally close and some normally open when one of then don’t work properly causes a short and blow the main fuse check the all and replace the faulty one but be careful and don’t test the microwave
Whit the cover removed.
Note:
if you have a blown fuse buy several emplacement fuses because my take several trays to fix the problem and you will need more than one fuse.
Jun 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
Turntable, lights and fan inop
I'm guessing that nothing is working...is that right? If so, first guess is the breaker or an internal fuse. Nearly all units have them. You don't say what fuse you checked. Unplug the unit, remove the bulb and see what is in the socket. Next, open the breaker and then turn it back on. This will reset it. Something caused this.
Dec 19, 2007 | Magic Chef CMV1000B Microwave Oven
GE SpaceMaker JVM XL1800
Sounds like the ERC board failed. It maybe covered under warranty, check that first cause a new ERC could cost around $150-$200. Anything electric can cause the .."what the*^&% just happened syndrome.
Dec 09, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Buld replaced, now microwave does NOTHING
It sounds as if an internal fuse has failed. You will need a qualified repairman for this, as ther are no user serviceable parts inside, but there are INSTANTLY LETHAL voltages present, even when the unit is off & unplugged.
Jun 28, 2007 | LG LMV2053 Microwave Oven
LG LMV2053 Microwave Oven Logo
186 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
