Question about John Deere 2E Leaf Blower Operators Manual
What is the Gas/oil mix ratio for a John Deere model 2E blower?
harlan301
  • 205 Answers
SOURCE: manual for john deere leaf blower
you have to order the Manuel from john deer or a john deer dealer
Posted on Oct 12, 2009
#1 Taper
  • 1040 Answers
SOURCE: bh30doesrunverygood
Check the fuel lines for cracks/breaks. If they are o.k., then:
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Posted on Dec 04, 2009
  • 5 Answers
SOURCE: Is there a vacuum attachment for BH30 john deere
Yes, it has a vacuum attachment; suction tube and bag.
Posted on May 13, 2010
bbap
  • 71 Answers
SOURCE: I have a John Deere 2E leaf blower. Lately it has
The H (High Speed) and L (low Speed) should not typically need adjustment. What happens is the diaphragms get stiff and do not operate efficiently. If the unit is over 5 years old and/or the fuel is not completely drained with the unit run dry at the end of the fall, then I would suggest replacing the diaphragms within the carburetor. This along with spark plug change, air filter cleaning and a check of the muffler to insure it is not clogged is considered a basic tune-up.
Posted on Sep 27, 2010
  • 85 Answers
SOURCE: what is the spark plug gap for a john deere BH30
if you have the manual it will tell you the type and gap for it
Posted on Feb 07, 2011
What kind of fuel does a john Deere BH 25 gas leaf blower use that is a 2 stroke. And what kind of spark plug is used?
Spark plug is NGK BMR7A gap is .025 Fuel is any gasoline mixed 40 to 1 with 2 cycle oil.
Aug 26, 2016 | John Deere Garden
What is the fuel/oil ratio of a john deere BH25 leaf blower?
The BH25 that I use from my friend runs on STRAIGHT gas, it is 4cycle. Do NOT put a fuel mix into it!! It has separate oil system.
Nov 24, 2012 | John Deere Garden
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Need gas/oil mixture for a John Deere BC 1600 trimmer.
Some of the new machines have a 50:1 Mix ratio, but all of the older ones I've seen are 40:1 which is 3.2 oz oil/Gallon gas. The John Deere machines appear to be similar to the Homelites, just different brand names on them.
Oct 09, 2010 | Garden
What is the correct gas/oil mix for a john deere weedeater?
4 oz generic 2-cycle oil to a gallon of fuel for a 32:1 ratio. It using JD Exact oil the ratio is 50:1 using 2.6 oz of JD Exact oil.
I hope this helps you.
Jun 17, 2010 | Garden
I have a John Deere hand held blower. I can't get
Your adjustments to the carburetor may make it worse.
Plus if the fuel mixture is over 30 old, I would replace it.
Manufacturers have told us this year any gas over 30 days old is considered bad gas and needs to be replaced. I would try some fresh gas(from the station) and some new 2 cycle oil at 40:1 Ratio(3.2 ozs 2 cycle oil to 1 gal of gas).
Good day.
Nov 07, 2009 | Garden
Manual for john deere leaf blower
Oct 12, 2009 | John Deere Garden
What is the mix ratio for the troybilt 25cc blower?
Troy-Bilt products now are usually produced by Mtd, the ratio being 40:1.
However since John Deere made yours I'm 99.9% sure it should by 32:1.
In any case any power equipment you own (including Dolmar or Stihl) that takes an oill/gas mix benefits in the long run from using the richer 32:1 ratio. It protects the piston and cylinder much better, giving your equipment longer life. Do not use the "one mix for all" that you find at retail stores as it has been my experience it really isn't "one mix for all". Seen a lot of scratched pistons and broken rings from people using that.
Jun 17, 2009 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Gas oil ratio
normaly 20 to 1
but with some of the newer oils you need to follow the instructions on the the oil bottle the newer cleaner fuels are now mixed at 50 to 1
Nov 24, 2008 | Homelite Consumer Products MightyLite...
John Deere 2E Leaf Blower Operators Manual Logo
69 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
