Question about Dryers
Estate dryer will not heat up
Dryer stopped heating thought it was the heating element...replaced it...and it still won't heat up...what else could it be and is it replaceable?
  • 429 Answers
Test the thermal fuses for continuity
Posted on Jan 05, 2013
  • 1028 Answers
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Posted on Jun 19, 2008
  • 188 Answers
SOURCE: dryer will not heat
Check to make sure you have 240V at the outlet. If you do, check the continuity of the element and thermostats. If still no heat, it could be the temperature setting switch, the timer or the motor.
Posted on Feb 21, 2009
  • 1314 Answers
SOURCE: Whirlpool Estate Dryer barely heating
jumps on the mony turn your breaker off first ok
Posted on Mar 12, 2009
SOURCE: WHERE DO I FIND THE HEATING ELEMENT ON A ESTATE DRYER
i have a estate dryer it blows hot air and drum turns but does not dry the clothes so it takes 3-4 rounds to dry the clothes what cold be the promblem
Posted on Mar 17, 2009
SOURCE: Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Posted on Jul 27, 2009
My Estate dryer is putting marks on my clothes that almost look like burns. With stain solution I can usually get them out but it's happening with every load now, what could be causing this? It h
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Estate Dryers
No heat
Sounds like a blown fuse, check your fusebox and replace all going to your dryer. May correct the Problem:)
Sep 20, 2012 | Estate TGDS740JQ Gas Dryer
Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
Runs but will not heat
1.loose wiring----check terminals & wiring
2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
3.defective timer---replace
4.open heat element---replace heat element
5..defective operating thermostat---test thermostat, replace if defective
6.fan or it's pulley loose on shaft---tighten set screw
7.incorrect heat or timer settings---reset timer
8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 25, 2011 | Dryers
Estate Dryer eed4300tqr the dryer does not heat at all during it 's heating cycle and how do I repair it.
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
check the continuity on all these thermal fuse and the element replace the one that has no continuty
Jan 18, 2011 | Estate EED4100SQ Electric Dryer
REPLACING HEATING ELEMENT IN ELECTRIC ESTATE WHIRLPOOL DRYER
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 27, 2010 | Whirlpool LEB6300 Electric Dryer
My whirlpool estate electric dryer stopped heating up. Everything else works fine. Is the problem the heating element ?
heatman101
May 31, 2010 | Dryers
New heating element not working
You should check to see if the "high limit switch is burned out. Some models/Brands have 2. It should be on the outside casing of the heating element.
Apr 30, 2010 | Estate EED4100SQ Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Dryer lost heat according to different cycles
the model number you have is for a gas dryer if this is an electric dryer then you can access the heating element by removing the back cover this has a small element you can remove it by taking the 1/4 inch screws from the sides of the element there could be two screws or just one remove the screws and pull the element out you con then visually inspect it but the best way is to ohm it out with a meter but your problem sounds more like a timer
Sep 18, 2009 | Estate TEDX640JQ Electric Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
