Question about Dryers
Trouble shooting code EO F3 - Dryers
    Sergeant:
  • 475 Answers
Call the manufactor or e-mail them.
Posted on Jan 05, 2013
WHEN MY WHIRLPOOL BUILT IN OVEN MODEL RBS305PRS00 IS BAKING IT SOMETIMES CUT OFF AND YOU HEAR A CLICKING NOISE AND IT WILL DISPLAY EO F3.I CAN TURN THE OVEN OFF AND IT WILL BEEP AND DISPLAY EO F3.AFTE
That's an oven sensor error. Replace the oven sensor. If you still have the error, check the wiring and/or replace the timer/clock board.
Nov 26, 2014 | Whirlpool Ovens
Whirlpool Oven GW395LEGT6 Replaced the oven temp sensor But oven will pre-Heat and run for 15 minutes then shut off with Error code EO F3
Have you tried pulling the connectors off the control board and reinserting them. If you still have problems the control board could be the issue.
Sep 24, 2014 | Ovens
Error code E0
THE CODE IS "OE" Not EO! There is NO EO error code. Go here http://www.youtube.com/watch?v=f_-bBjx46Bc
OK? All you have to do is watch the Video and there is a review trouble shoot. You probably have a bent water Inlet Line. Or it is Kinked
Oct 20, 2013 | LG WM2688HWM TROMM SteamWasher
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3
Thanks
May 26, 2010 | Ovens
Electric kitchen aid double oven gives eo message
there should be more of a code like fo/eo or f2/eo or f3/eo or f5 /0o .. if you have # 1 = analog t digital l failure / replace control..= #2 shorted key pad / = replace control /? # 3 oven tempt sensor = repl oven sensor or fuse .// # 5 ck door /latch sw = replace component .. hope this helped . mm ( re/ck codes and see if one of thes matches your problem .. mm pls leave feed back ..
Dec 12, 2009 | Washing Machines
Getting error F3:EO
HI. This code is indicating that the Oven temperature sensor (RTD) is opened(stuck). If this is a double oven design, this will be the upper oven sensor. The solution will be to ,simply, replace the affected sensor. It is not repairable.
Dec 06, 2009 | KitchenAid Ovens
Kenmore Model 665 95781000 Stove Displays a EO-F3 code and the oven does not work WHat part work be defective to give me this fault code EO-F3?
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Sep 25, 2009 | Ovens
Oven not working on wirlpool accubake system
I have a Whirlpool Accubake System stove / oven. About 50 p% of the time I go to push the "Bake" and "Start" button, it goes to "Cal" or "EO -F2-" what ever that is. It won't let me clear it . Needless to say I am not happy with the fact that when I go to bake something, the oven doesn't work!!! Please help!
Oct 15, 2008 | Whirlpool Kitchen Ranges
WHIRLPOOL RF385PXG
If a new temp sensor doesn't fix an F3, you have a loose connection, or the electronic control is bad.
Feb 09, 2008 | Whirlpool RF380LXPS Electric Kitchen Range
Clean cycle in oven doesn't work: FO EO
Oliversmom, Im not coming up with any information on the model number posted. However on the kitchenaid the F0 E0 is default for no error. Press the cancel button to put the range in idle state. Then in this order press cancel-cancel-start. See if an error code comes up different from the F0 E0. The F0 is what is throwing this whole deal off. If it was F1, F2, F3 etc...it would make more sense. See if you have a complete model number you can post along with the error code after doing the above key dance. We'll see if we can solve the issue....Catriver..post back.
Apr 03, 2007 | KitchenAid KERI201P Electric Kitchen Range
Dryers Logo
35 people viewed this question
Top Dryers Experts
