SOURCE: computer displays black screen with blinking cursor
Its seems its not booting correctly. Just Insert Windows CD and fix the windows. Another solution is to press (I think) F1 or F11 or F12 (depending on the model) when booting the machine. It will take you to recovery mode. Use it to restore the boot section ONLY.
SOURCE: black screen, blinking cursor in top left hand corner
Could be a number of issues, incl unseated processor or a faulty hard drive. First off I would remove mains & battery, remove covers from underneath and reseat any memory or processors you can find - by reseat I mean just take out and put back.If this fails, I would look to price up a new hard drive before condemning the machine.
SOURCE: black screen with blinking curser in left top corner
Hold the power button down and let it fully power off then boot it back up. If you get a prompt saying Windows did not shut down normally, select Last Known Good Configuration.
SOURCE: Black screen , loud alarm noise
The problem of your laptop is in the RAM just clean the RAM by wiping an eraser of the printer or a rubber. To remove the RAM open the back of your laptop where the RAM was inserted.
SOURCE: black screen with a little
that in fact is called the "prompt" or "cursor prompt" sounds like you havent got an operating system,Try F2 whilst booting to go into bios pages to configure boot sequence.Navigate with "tab" and arrow keys,,,save an exit ,,or restore to factory defaults etc--good luck!
Davey Snake!
