Question about Canon EOS 40D Digital Camera
Err 99 when use internal flash
Last night, my Canon 40D fell on the ground, it still worked good until I tried to use the internal flash, the flash could not pop out, instead, it just remained half open and made a lot of noise. then there was an err 99 msg showed on the LCD.
I tried to remove battery, but it was still there.
If I kept flash fully open, the flash still worked. However, when I closed it and tried to pop it out again, same thing still happened. I have to restart.
I have no idea about what has happened. The camera is still with in warranty, however, it is a man-made mistake (fell on the ground). I am not sure if I send it back to Canon and ask for repair, how much it would cost.
thanks
  • kayalvin Jan 23, 2009
    Err 99 Shooting is not
    > possible. Turn the power switch to and again or re-
    > install the battery.) I get this message all the time.
There is a Canon Help line on the Canon web site which will help you. They are excellent
Posted on Feb 04, 2009
Error code 99 on a 40D?
Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Apr 17, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Got Error 99 on my 40D. Have done all the obvious: remove battery, replace battery, check lenses, SD cards. Have talked with several people who tell me it's "common" with 40D. Any assistance you...
Welcome to Fixya
Thanks!
Mar 27, 2011 | Canon EOS 40D Digital SLR Camera Digital...
My Canon 40D suddenly came down with the dreaded Error 99 for no apparent reason. I have tried all the usual, battery, memory card, lens, but no luck. Even on the bulb setting the shutter won't stay open....
Welcome to Fixya
Thanks
Jan 30, 2011 | Canon EOS 40D Digital Camera
Err 99 keeps coming up
It is due to some kind of electrical (contact) failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
May 16, 2010 | Canon EOS 40D Digital Camera
I receive Err 99, it says to re install battery or
It is due to some kind of electrical contact failure.
May 14, 2010 | Canon EOS 40D Digital Camera
''err 99'' code appearing fairly often recently on Canon Rebel XT
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 19, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon 40d error 99
Try the following diagnosis steps: -
Mar 12, 2009 | Canon EOS Elan 7ne 35mm SLR Camera
Err 99 on canon rebel xt 350 d
The Err 99 problem occurs due to dirty contacts between the body and the lens. I recommend cleaning the contacts. You can then turn Off the camera and then remove and reinstall the batteries to reset the camera to get the problem fixed.
Jan 15, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err99 40d canon body only
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Oct 28, 2008 | Canon EOS 40D Digital SLR Camera Digital...
Canon EOS 40D Digital Camera Logo
102 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
