Question about Scotsman Refrigerators
I have a scotsman cu3030 and the water overflows in the ice bin
SOURCE: scotsman EC 105 - Bin full!
change the sensor ................
Posted on May 14, 2008
TheMobilian
  • 8220 Answers
SOURCE: scotsman 500 cm3 ice machine
Remove all molex connections and check for corrosion. Clean the connections and retry.
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: Ice maker feeding too much water and overflows
I have the GE Profile TFX24PR that exhibited the same symptoms. I had water leaking, making ice in the bottom of the ice bin, as well as under the ice bin. I also discovered ice down the back wall of the freezer.
A technician replaced the ice maker, which did not solve the problem. He put the original back and replaced the valve on the back. That too did not solve the problem. I took matters into my own hands.
I discovered that the ice maker water fill tube that comes in through the back of the freezer wall was leaking. Water would run down the outside of the tube. Some of the water would go into the ice maker, some would go into the ice bin and some of the water would also run down the wall of the fan housing where it passes through a hole in the fan housing. The big problem was the water running down the wall of the fan housing. From there it ran onto the cooling coils, where it would freeze, causing the freezer to go into extended defrost. My freezer and fridge would warm up and I had some food spoil.
If this looks like it may be your problem, you may want to enlist some help for this; it is tedious, time consuming and requires working in the confined spaces of the freezer.
After disassembling the fan housing I was able to access the fill tube. It just pushes in and is prone to wear, especially after fourteen years. I just reversed the ends of the tube and pushed it back in for a snug fit. You may want to consider using a sealer. Everything is working fine now; lots of ice in the bin, and no stray ice or water.
Posted on Apr 03, 2009
SOURCE: ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Posted on Jul 23, 2009
  • 33 Answers
SOURCE: Scotsman Ice Maker CME 256
descale bin level sensors, check for corrsion on wire harness. if does nt work. replace . bin level sensors
Posted on Aug 26, 2009
Scotsman ice maker making more water than ice
Check water inlet valve to make sure it is not letting water seep through causing water to overflow water sump tray and dumping into bin. and the machine will not produce much ice.
Oct 19, 2014 | Kitchen Appliances - Others
Scotsman ice machine
Check the dump valve if water is seeping through the dump valve then the water inlet valve will be adding water to sump all the time to replace water lost. Now if water is running over sump into ice bin then look at water inlet valve.
Jul 17, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Check the water inlet valve water seeping through valve should be running over into bin. Replace or rebuild valve. the machine should have slowed down on production of ice also.
Jul 17, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How do i get a service manual?
The bin sensor eyes need to be cleaned or replaced. First remove the front cover then remove the white plastic ice deflector shield. Now you should be looking at the evaporator plate look down you will see the water sump tray full of water in that tray is a black plastic grate that when the ice is harvested it drops and hits the tray keeping it from falling in sump tray PULL it OUT. now just behind the sump where the ice falls through opening on the left and right sides is where the ice full bin eyes are you can pull them out side ways there is plenty of wire so you can pull them up to where you can clean them with a soft cotton cloth with scotsman cleaner. Now for a manual goggle scotsman service manuals you can get a PDF file.
Apr 28, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Water keeps running
where is the water running on the ice head or is this a remote water cooled condenser? If water is running all the time at the ice head into the sump tray and overflowing into the ice bin then check the water inlet valve ether rebuild or replace valve but make sure the water low sensor is not calling for water when the sump tray is full of water.
Jan 12, 2014 | Scotsman Cooled Modular Contour Cuber...
Scotsman ice machine water runs continually never shuts off. It will make ice but really racks up water bill. It is as if the float never senses the reservoir is full. What is my problem?
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
Jan 12, 2014 | Scotsman Ice Machine, Cuber, 1930 lb....
Scottman cu3030 max harvest-retrying, flashing code #2
The machine will try to harvest 3 times before it shuts the machine down. Is the ice thick enough to open the curtain door? if the curtain dose not open the magnet switch then the machine dose not know it has harvested the ice and will keep trying to harvest. Is the ice coming off the evaporator plate during harvest or is it hung on the plate? if hanging on the plate then system needs to be cleaned. is the harvest assist plunger working?
Oct 30, 2013 | Scotsman Refrigerators
Scotsman DCE33A-1WB not draining
Check that Ice cubes are freeezing completely before dumping into tray.
Check that spray nozzle isn't inadverdantly clogged and spraying water everywhere.
Check that water inlet solenoid is actually closing and not leaking water into bin.
Check thermostat for the bin not working properly, frozen over or something.
Oct 31, 2012 | Scotsman Refrigerators
Refrigerators Logo
48 people viewed this question
Top Scotsman Refrigerators Experts
john h
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Scotsman Refrigerator Expert? Answer questions, earn points and help others
