Question about Dell W4201C 42 in. Plasma HDTV
Horizontal lines running through screen
First, noticed when we would turn tv on, would make loud buzzing sound, now these squiggly lines are on the screen, but, buzzing noise went away
Hori line
Posted on Feb 02, 2009
White, squiggly lines on TV screen
This fault is technically called 'retraced lines'. There are many reasons for this fault. It will be best to contact any service technician. If the screen voltage to CRT is abnormal [higher than normal]; this kind of fault can occur. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
One among the post have details about this fault "Retrace lines with picture".
Mar 03, 2015 | Televison & Video
53" sony projection -picture washed out w/ green horizontal lines
It sounds like your Green CRT ( picture tube ) is shorted. That's the one in the middle. Sony had issues with there tubes in those years. Sorry for the bad news. Even if you could locate the tube, it will be a matter of time before the Red or Blue does the same.
May 03, 2009 | Sony KP-53S65 53" Rear Projection...
I have a KV27FS210 sony wega trinitron tv. It turns on and has a single horizontal line across the center of the screen then buzzes shows a continuous zigzag line from the top to bottom of the screen with...
The single horizontal line is a problem with the vertical circuit. Look for a small flat id attached to a heatsink that should be marked LA7837 or something similar. Try resoldering the pins of this IC first. If that does not resolve it, replace the IC.
Keep us posted.
Dan
Feb 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Screen has has horizontal white lines and a loud buzz with ps3.
it could be that your rca cables are damaged, you can try using different ones, or it could be that you have a setting to use rca cables turned off in your settings of the ps3.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Horizontal grey lines on TV
Sound like you have to turn down the G2 (screen)controls. They are turned up too high.
Jan 01, 2007 | Panasonic PT-56WXF95 56" Rear Projection...
Dell W4201C 42 in. Plasma HDTV Logo
277 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
