Question about Hotpoint Dryers
How to remove the covers from tcm570 to relpace drive belt
  • 108 Answers
Hi ile try to help dont know that model here goes behind kick plate you should hav about 4 screws open door there should be anouther 4 if so 1st step is to take top off to take control panel off mark were all wires go you will have a screw either side connected to front aswell
Posted on Feb 14, 2014
How to change drive belt on tor o 8-25?
disconnect the spark plug wire from the spark plug
Remove the battery pack cover, the battery and the fuse.
Remove the screw inside the battery cover and the screws that hold the belt cover underneath the mower.
Remove the screw from the battery bracket.
Flip the mower on its side to access the bottom and remove the belt cover.
Remove one of the screws holding the belt guide in place. Loosen the second screw holding the belt guide.
Move the belt guide away from the belt driver assembly.
Loosen the drive belt by loosening its tension around the pulley and pry the belt from the fingers of the bracket.
Jun 04, 2014 | Toro Garden
Change belt on snapper 722 snow blower
1. Remove the belt cover with a socket wrench. Slide the belt cover off and set it aside.
2. Remove the two belt cover stud bolts with a socket wrench to get to the auger belt guide. 3. Remove the belt guide with a socket wrench.
4. Push down on the belt tensioner pulley with your hand. Remove the old belt and set it aside.
5. Install the new belt and release the belt tensioner pulley to tighten the belt.
6. Re-install the belt guide with a socket wrench and tighten the bolt.
7. Re-install the two belt cover stud bolts and tighten with a socket wrench.
8. Re-install the belt cover and secure it with the cover bolts. Tighten the bolts with a socket wrench.
I pulled the following from a snaper model similar to yours.
The snowthrower has two drive belts, one for the traction
drive-which transmits engine power to the wheels, and
a second for the auger drive-which transmits engine
power to the auger mechanism.
Each of these drive belts are of special construction and
should be replaced only with genuine replacement belts
which match the original equipment belts. These are
available from your dealer.
Traction Drive Belt Replacement
I pulled the following from a snapper model similar to yours. Believe it should help.
1. Disconnect spark plug wire and fasten it away from
the spark plug.
2. Remove belt cover. (Located in back of the discharge shute).
3. Pull the traction drive belt idler pulley arm (See
Figure 24) away from the belt to relieve tension, and
slide the belt off the engine pulley.
4. Slip the belt off from around the traction pulley (See
Figure 29) and pull the belt out of the unit between
the auger pulley and the traction pulley (the lower
cover need not be removed for this step).
5. Reverse the procedure to install the new belt. Be
sure there are no twists in the belt, and that the belt is
properly seated in the pulley grooves.
6. Replace the belt cover.
7. Start the unit, and check the traction drive for proper
operation. See "Traction Clutch Cable Adjustment"
for adjustment procedures.
There are also several videos on YouTube on changing snowthrowr belts. (Didn't see one for your blower, but most similar and should provide a good starting reference).
May 09, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
Hotpoint tcm570
Try replacing the capacitor, you can pick them up cheap enough and only cost 5-6 online, just ensure you replace like for like do not change the rating of the capacitor
Apr 05, 2014 | Washing Machines
Change timing belt
timing belt? on a Jeep? 05 wrangler
what engine is this>?
ah the 2.4L
front cover
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove the crankshaft vibration damper.
  3. Remove the generator drive belt tensioner assembly.
  4. Remove the timing belt front cover bolts, and remove the covers.
rear cover
  2. Remove the front covers.
  3. Remove the timing belt.
  4. Hold the camshaft sprocket with Special Tool 6847, or equivalent, while removing the center bolt.
  5. Remove the timing belt idler pulley.
  6. Remove the rear cover fasteners and remove the cover from engine.
Apr 04, 2014 | 2005 Jeep Wrangler
How do i remove the timing belt cover off my 98 escort lx?
if you are only removing the timing belt cover 1st remove the negative battery cable from the battery, next remove the drive belt (alternator belt) and belt tensioner next remove the three nuts and three bolts from the timing belt cover then remove the cover, you mite have to finesse the cover a little to get it off from behind the crank pulley but it will come out .
Dec 29, 2010 | 1998 Ford Escort
Timing belt removal 94 mercury villager
Hi, Disconnect battery ground cable, then drain coolant. Remove accessory drive belts. Remove A/C compressor drive belt idler pulley (tensioner) bolts, then idler pulley (tensioner). Remove upper radiator hose bracket bolt. Loosen two upper radiator hose clamps, then remove upper hose and bracket. Remove coolant bypass hose between thermostat housing and intake manifold coolant outlet. Disconnect main wiring harness from upper front cover (timing belt) cover, then remove eight upper timing belt cover bolts, then the upper cover, Fig. 20. Raise and support vehicle. Remove right front wheel and tire assembly and splash shield. Use strap wrench tool No. D85L-6000-A, or equivalent, to hold water pump pulley while removing water pump pulley bolts. Remove water pump pulley from water pump. Remove crankshaft pulley. Remove five lower timing belt cover attaching bolts and the cover. Rotate crankshaft in a clockwise direction to align crankshaft and camshaft sprocket timing marks, Fig. 21. If timing belt is to be reused, mark direction of rotation. Loosen timing belt tensioner nut, then remove timing belt. CAUTION: With timing belt removed, avoid turning camshaft or crankshaft. If movement is required, exercise extreme caution to avoid valve damage caused by piston contact.
Take care
Jul 24, 2010 | 1995 Mercury Villager
Water Leaking from belt side of engine on a 1996 Camry.
hi, is it just water? or does it look more like coolant? if just water, and seems to only leak when a/c or defrost is used, this would likely be the evaperator drain tube letting moisture out. this is normal. but if looks like coolant(reddish pink, or possibly green) this likely means you have a leaking water pump. the water pump is driven by timing belt which is located behind the timing cover directly behind the drive belts. if/when you go to get it repaired, the timing belt should be replaced at the same time. also, you may want to have the timing belt tensioner, and timing belt pulleys relpaced at this time as well, it's good insurance for any repairs that may be needed later down the road after service. make sure to have the drive belts checked when repairing timing belt, they will be removed during repair, if they need to be replaced due to wear, re-install new ones at no extra labor charge.
Jul 08, 2010 | 1996 Toyota Camry
Ifailed to get on tdc before removing old timing belt how do I get back in time so Icanreplacebelt.
This is the complete procedure from the service manual on how to replace the timing belt start to finish, start over to assure u get it right, if u mess up the engine will be damaged
Removal for 1.6L engines : ONLY 2006 to 2009 CARS
Engine removal is not required for this procedure.
1.Remove the engine cover.
2.Remove the RH front wheel.
3.Remove the 2 bolts and RH side cover.
4.Temporarily loosen the water pump pulley bolts.
5.Remove the alternator drive belt
6.Remove the air conditioner compressor drive belt
7.Remove the power steering pump drive belt
8.Remove the 4 bolts and water pump pulley.
9.Remove the 4 bolts and
timing belt2_bing.gif upper cover
10.Turn the crankshaft pulley, and align its groove with timing mark "T" of the timing belt cover. Check that the timing mark of camshaft sprocket is aligned with the timing mark of cylinder head cover. (No.1 cylinder compression TDC position)
11.Remove the crankshaft pulley bolt and crankshaft pulley
12.Remove the crankshaft flange
13.Remove the 4 bolts and timing belt lower cover
14.Remove the timing belt tensioner and timing belt.
15.Remove the bolt and timing belt idler
16.Remove the crankshaft sprocket
17.Remove the cylinder head cover.
(1)Remove the wire harness bracket
(2)Remove the ignition coil.
(3)Remove the PCV (Positive Crankcase Ventilation) hose and the breather hose from the cylinder head cover
(4)Remove the engine cover bracket
(5)Loosen the cylinder head cover bolts and then remove the cover and gasket.
18.Remove the camshaft sprocket.
Hold the portion of the camshaft with a hexagonal wrench, and remove the bolt with a wrench and remove the camshaft sprocket.
INSTALLATION:
1.Install the camshaft sprocket and tighten the bolt to the specified torque.
(1)Temporarily install the camshaft sprocket bolt
(2)Hold the portion of the camshaft with a hexagonal wrench, and tighten the bolt with a wrench
Tightening torque :78.5 ~ 98.1N.m (8.0 ~ 10.0kgf.m, 57.9 ~ 72.3lb-ft)
2.Install the cylinder head cover.
(1)Install the cylinder head cover and bolts
Tightening torque :7.8 ~ 9.8N.m (0.8 ~ 1.0kgf.m, 5.8 ~ 7.2lb-ft)
(2)Install the engine cover bracket
(3)Install the PCV(Positive Crankcase Ventilation) hose and breather hose to the cylinder head cover.
(4)Install the ignition coil.
3.Install the crankshaft sprocket
4.Align the timing marks of the camshaft sprocket and crankshaft sprocket with the No.1 piston placed at top dead center and its compression stroke.
5.Install the idler pulley and tighten the bolt to the specified torque.
Tightening torque :42.2 ~ 53.9N.m (4.3 ~ 5.5kgf.m, 31.1 ~ 39.8lb-ft)
6.Temporarily install the timing belt tensioner
7.Install the belt so as not give slack at each center of shaft. Use the following order when installing timing belt.
Crankshaft sprocket →idler pulley →camshaft sprocket →timing belt tensioner
8.Adjust the timing belt tension.
(1)Loosen the tensioner pulley mounting bolt and apply tension to the timing belt.
(2)After checking the alignment between each sprocket and each timing belt tooth, tighten the mounting bolt and one by one.
Tightening torque :19.6 ~ 26.5N.m (2.0 ~ 2.7kgf.m, 14.5 ~ 19.5lb-ft)
(3)Then recheck the belt tension.
Verify that when the tensioner and the tension side of the timing belt are pushed in horizontally with a moderate force [approx. 49N (11lb)], the timing belt cog end is aprox. 1/2 of the tensioner mounting bolt head radius (across flats) away from the bolt head center.
4)Timing belt tension measuring procedure
(by a sonic tension guage)
Rotate crankshaft in clockwise direction to set 1st piston on top dead center (TDC) and rotate crankshaft in counterclockwise to 90° then measure the belt tension in the middle of tension side span (in arrow direction of above illustration) by free vibration method.
9.Turn the crankshaft two turns in the operating direction (clockwise) and realign crankshaft sprocket and camshaft sprocket timing mark.
10.Install the timing belt lower cover with 5bolts
11.Install the flange and crankshaft pulley, and then tighten crankshaft pulley bolt. Make sure that crankshaft sprocket pin fits the small hole in the pulley.
Tightening torque :137.3 ~ 147.1N.m (14.0 ~ 15.0kgf.m, 101.3 ~ 108.5lb-ft)
12.Install the timing belt upper cover with 4 bolts.
13.Install the water pump pulley and 4 bolts.
14.Install the power steering pump drive belt
15.Install the air conditioner compressor drive belt
16.Install the alternator drive belt
17.Install the RH side cover with 2 bolts
18.Install the RH front wheel.
Tightening torque :88.3 ~ 98.1N.m (9.0 ~ 10.0kgf.m, 65.1 ~ 72.3lb-ft)
19.Install the engine cover with bolts.
Tightening torque :3.9 ~ 5.9N.m (0.4 ~ 0.6kgf.m, 2.9 ~ 4.3lb-ft)
May 20, 2010 | 2006 Kia Sorento
Hotpoint tcm570 makes odd noise in reverse only
Neil_lewis08 - did you get the problem with the TCM570 sokved - having same problem with same dryer - only in reverse.
thanks
dave
Jan 31, 2010 | Hotpoint Dryers
Dryers Logo
79 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
