Question about TORK Hardware & Accessories
Tork timer is making a ticking noise, how to fix
3 Suggested Answers
SOURCE: does this timer make any
Every mechanical device makes some noise.
Plug-in timers generally are NOT noisy because the switch and trippers are plastic.
Direct-wire timers that are made of metal are noisy when the switch clicks on-off.
Posted on Feb 18, 2011
  • 5089 Answers
SOURCE: Tork Timer 1101 Noisey!!
Spray gears with WD40. And blow out timer with air. Turn off power: WD40 vapor is highly flammable accelerant.
Do not spray WD40 on live electric connections or hot surface.
Install timer on non-wood surface so sound does not resonate sound like a wood violin.
You can also buy replacement clock motor #101 for about $48.
http://waterheatertimer.org/Tork-timers-and-manuals.html#1101
Or buy the T1101M replacement mechanism for $59 and screw into current box, or buy whole new T1101 with the box for about $53 and just use the new mechanism.
Or replace with new Intermatic T101 timer for $45 at Smarthome.
Crossover wiring:
Tork L&1 to Intermatic 1
Tork 2 to Intermatic 2
Tork x to Intermatic A
Posted on Sep 04, 2012
Kenwood oil filled heater timer starting making a ticking noise. Is there a way to fix it?
Most of these model are not repair able but seems like thermostat problem
Feb 03, 2015 | Kenwood Heating & Cooling
TORK 1101 Timer will not keep proper time?
Clean up the timer with compressed air and WD40.
If problem persists, then bad #101 120 volt clock motor probably
http://www.amazon.com/dp/B00AQZ78TU/?tag=waterheaterti-20
Clock motors and trippers can be replaced on Tork series timers.
Gene
Oct 27, 2014 | Hardware & Accessories
Crossover wiring:
Sep 03, 2012 | TORK Hardware & Accessories
I have a GE15350 mechanical timer i am not sure how to -Fix ya
Question is not complete.
Copy following link to view 120Volt GE15350 timer manual and example wiring.
http://waterheatertimer.org/GE-timers-and-manuals.html#15306
To set current time, rotate dial until correct hour lines up with the word time located on lower right of timer dial.
GE timers are made by Tork. Tork P47 trippers attach to timer dial as shown following link:
http://waterheatertimer.org/images/Tork-1102-3-500.jpg
Jul 13, 2012 | Hardware & Accessories
No display stop working. it controls a fan lite, the lite is on in a dimmed mode, no fan function.
Question posted under Tork SS720 timer.
I don't have repair for defective timer that worked before and stopped working.
If this is new timer, then add a comment and explain wiring in exact detail, and include what you mean by 'dimmed' mode.
Timers have 1 year limited warranty.
Timers are affected by line noise, and generally cannot be connected to a dimmer.
SS720A timer is robust 120Volt single-pole 7-day programmable timer, rated for 15Amp up to 1 HP.
The larger the amp load, the shorter the lifespan for electrical devices.
Last step troubleshoot for programmable timer is to reset timer and reprogram.
Reset timer by pushing in reset button for several seconds.
If functionality is not restored, then timer has gone bad.
Tork SS720 is identical to GE15071 timer sold at Home Depot.
Buy another timer, and return defect in new package.
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
http://waterheatertimer.org/pdf/SS720A-Tork-In-wall-manual.pdf
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Aug 19, 2011 | TORK SS720A 7 Day In Wall Digital Timer
Tork pool timer dial, spins freely, not keeping time or switching on or off. Do I need a new one or can I fix it?.
Timer is not 100% identified.
120Volt Tork 1101 timers can be fixed with repair parts.
Generally, plug-in-outlet timer has gone bad, then it cannot be fixed.
Open following links to identify timer and then add a comment.
Add a comment for more help
Upvote the help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 09, 2011 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
My 2002 Range Rover makes a loud ticking noise when I start it and when I accellerate or stop it gets louder its not over heating and not loosing any power.. what should I get fixed?
Could be your lifters are loose(Tappits) have a mechanic tighten them down for you, but they have to be at proper tork , If the ticking noise is really loud you also could have a broken connecting arm on one of your pistons, that is very bad, some vehicles can be driven for awhile with that noise, but if it is that your motor is done!
May 02, 2011 | Land Rover Range Rover Cars & Trucks
Is there an instruction booklet available?
Instructions for tork timers:
Tork makes several timers that look similar.
Link above has photos of each type with manuals.
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
I have a noisy TORK model1101 24hrtime switch there is a broken spring in there and it won't switch OFF is it repairable or do I scrap it and Hunt for a new one? If you cant give me and answer with...
Fixya answers questions.
NSI is responsible for Tork.
http://tork.com/tork/elecmech.aspx
Electro-mechanical timers make audible click noise when timer turns on-off.
T1101 spring is the time-carryover for power outage.
Buy another Tork T1101 and swap out insides without changing box:
Take photo of wiring before making changeover.
http://www.weisd.com/store2/tork/torktimer1.php
Replace Tork with Intermatic T-101 120V timer
T101R for weathertight
Amazon for T101
Aplus sells T101R
For help wiring T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Nov 13, 2010 | Hardware & Accessories
How to set a tork timer?
Tork makes a page-full of timers.
Rotate dial until current time lines up with arrow, then set the pins as shown in photo below
1) If timer plugs into wall receptacle, it has pins around the dial.
2) If timer replaced a wall switch it also has pins around dial.
GE and Woods and Tork and Intermatic each make similar timers.
Pull and push the pins to set times.
The wall-switch type timer also has a switch >>> move switch to Timer
Up-vote if this information helped. Thanks for the feedback.
Oct 15, 2010 | TORK 401A 24 Hr Mechanical PlugIn Timer ...
Hardware & Accessories Logo
24 people viewed this question
Top TORK Hardware & Accessories Experts
 Kenneth
Kenneth
rgbypoet
Andrew Taylor
Andrew Taylor
Are you a TORK Hardware and Accessory Expert? Answer questions, earn points and help others
