Question about Daewoo Heating & Cooling
Daewoo dwc-0820frl air conditioner manual
Turns on and after a few minutes the timer comes on by itself and unit shuts off.
hotuna
  • 288 Answers
SOURCE: Coleman RV Rooftop Air conditioner
If the compressor is tripping the breaker, then its 1 of 2 things. First clean the coils and change the air filter. If the coils are dirty and/or the filter is clogged, it will make the compressor overload and the high amp draw will make the breaker trip. If this doesn't solve the problem, you need to check the compressor itself. remove the connections at the compressor, leaving only 3 posts on it. You will need a meter to check for continuity to all 3. They should all have continuity to each other. While there check the wires. Sometimes a burnt wire will come off and arc on something causing the breaker to trip, if you are lucky.
Posted on Mar 02, 2008
22yooper
  • 828 Answers
SOURCE: Daewoo (DWC-056CL) Air Conditioner
You don't have to remove the polystyrene that is inside the unit. It is part of the construction of the unit. It is part of the molded construction.
Posted on Jul 02, 2008
  • 143 Answers
SOURCE: Cleaning a daewoo
You usually grab it by the front and pull, but there might some screws holding it in.
Posted on Jul 24, 2008
SOURCE: clicking noises
make sure thisis abnormal because sme a/c are noisy in operaqtion but if not check mat fan motor bearing need lubrication or replacement
note if still in waranty let dealer check
Posted on Sep 04, 2009
dburns60
  • 410 Answers
SOURCE: i have a Daewoo Air
features Cooling Capacity 5,340 BTU/h 10 Energy Efficient Rating Cooling Area (sq. ft.) 100 to 150 Low Noise Operation Washable Air Purifying Filter Effective Dehumidifying Operation Indoor Temperature Sensing Thermostat Window Kit for Easy Installation Power Supply (V/Hz): AC 115V/ 60Hz Power Consumption: 525 W
Answer = yes regular 115 vac outlet
Posted on Aug 21, 2010
DAewoo DWC-LD1013 will not spin
The Daewoo DWC-LD1013 is a washing machine, you may wish to post your question in that category, not in air conditioners.
Jan 09, 2015 | Daewoo Heating & Cooling
THE A/C BLOWS AIR BUT DOES NOT COOL...THE COMPRESSOR COMES ON FOR A SECOND OR TWO AND SHUTS OFF..THE A/C UNIT IS NEW....CAN YOU HELP
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 28, 2011 | Daewoo DWC-084R Air Conditioner
The air conditioner cools the room but it shuts of. The power light doesn't come on while unit is on. Can I replace the plug?
"The air conditioner cools the room but it shuts of." -- Temperature reached, but does not turn back on automatically? Stops short of reaching temperature? Shuts off for a period, but will come back on only to shut off again later?
Most importantly, how do you get it to turn on again?
"The power light doesn't come on while unit is on." -- If the unit is on and the power light is not, then the power light must not be operating (is burnt out).
Actual answer: "Can I replace the plug?" -- Of course you can.
What is causing you to feel that the plug needs replaced?
:o).
Jun 04, 2011 | Daewoo DWC-056CL Air Conditioner
Ac wont come on trip plug lights for 1 sec then goes out.
QUESTION?? WHY DAEWOO?? DID YOU EXPECT ANYTHING ELSE?
Jul 08, 2010 | Daewoo DWC-056CL Air Conditioner
I am getting e3 error code every 30 minutes with my lg conditioner
E-3 Remote controller comms error. Check wired correctly, if so check dipswitch in RC. Set to Sg for 1 unit, or Gr for group then reset power
Apr 29, 2010 | Daewoo DWC-060C Air Conditioner
Cleaning a daewoo
Jul 24, 2008 | Daewoo DWC-073C Air Conditioner
Jul 02, 2008 | Daewoo DWC-056CL Air Conditioner
Heating & Cooling Logo
96 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
