Question about Proform Pro Form Elliptical Console 252257
Stop loud beeping from elliptical
My Elliptical beeps extremely loud whenever you slow down on your work out. I think it is a motivational thing- however it is so loud my neighbor hears it and has complained to my coop board - how do i stop this noise so I can execise again??
4 Suggested Answers
  • 12 Answers
SOURCE: plugged in a wrong adaptor and my elliptical started smoking
usually when you let the smoke out your done, but if it seems to be OK, I would just run (ellipe) with it. The board is probable damaged but working, you might of burned a few contacts, sniff around. You can take the covers off and look but if they are burned bad you might just finnish it off. How long it lasts can't be determined, but it is just a matter of time before it goes.
Posted on Mar 13, 2009
SOURCE: My Proform elliptical is not working
clarification: when I get on the stepper there is not resistance. I'll get to a point when my feet will bascially fall right around....like something is loose or broken
Posted on Feb 10, 2010
ercupa190
  • 12223 Answers
SOURCE: my proform 2605 elliptical the right foot pedal is
Detachthe ends of the pedals from the crank axles. Spread a layer of machine greaseover the crank axles, then reattach the ends of the pedals.2
Removethe bolts connecting the pedals to the swing arms. Detach the pedals from thearms, then spread a layer of machine grease over the axles on the swing arms.On some models, the bolts may also serve as the axles. Reattach the pedals tothe arms.3
Removethe bolts connecting the swing arms to the elliptical's upright. Detach theswing arms from the upright, then spread a layer of machine grease over theaxles on the upright. Reattach the arms to the upright.
Posted on Nov 30, 2011
Life fitness x5 keeps on beeping
A beeping sound occurs whenever the timer reaches zero or a new program is selected. You can turn off the beeping sound by pressing and holding the GluteToner key for seven seconds and then a beep will sound to confirm the change in settings.
We hope this helps! :) If any further assistance is needed, feel free to visit us online at www.sportsmith.net or by phone at 888-713-2880 we would be happy to help in anyway!
Jul 25, 2015 | Exercise & Fitness
How to stop steady beeping of treadmill
Paul, simply unplug the machine from your wall, witch is recommended from the factory.
Nov 18, 2014 | Exercise & Fitness
My Schwinn 428p Elliptical is stuck on level 1 Rest of computer seems up be working
Either motor or brake....cable unlikely. Make sure the console buttons beep and check above.
Jan 20, 2014 | Exercise & Fitness
Nordictrack elliptical CX1055 stopped beeping. The unit used to make a feedback sound when a button was pressed. This was in the form of a beep. The unit has not been jarred or mistreated, it just stopped...
follow this troubleshooting steps and fix it.
God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
  • 2 Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
  • Sponsored Links
  • 3
    Do not be concerned if you see small particles left on the guide rails. Over time, the roller wheels gradually wear down. When this occurs, they leave residue on the rails. Because this is considered to be normal wear, all you need to do to fix the problem is wipe the rails off with a damp cloth.
  • 4
    Minimize the risk of receiving erratic readouts on the monitors by avoiding outside interference. For example, gripping the heart rate handlebars too tightly can affect the monitor. Similarly, the heart rate grips can be rendered less effective when there is too much vibration. Consider not holding these monitors throughout the workout to minimize vibration. The readouts also can be affected by jewelry. To minimize errors, take off rings and other jewelry before working out on an elliptical machine.
  • Read more: http://www.ehow.com/how_6149016_troubleshoot-elliptical-machine.html#ixzz2gTKOfuoB
    Oct 01, 2013 | Nordic Track Nordictrack Cx1055 Elliptical...
    Ironman 530e elliptical
    Try a different category for your question. Not likely to get help in the sewing machine community.
    Mar 23, 2017 | Sewing Machines
    Life Fitness 9100 Elliptical Squeaks
    You can use the link below to purchase a suggested form of lubrication. You may end up needing to replace a bearing or bushing.
    Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
    Nov 24, 2012 | Life Fitness 9100 Elliptical Cross Trainer
    Monitor diplays E1 and won't stop beeping
    Fitness Quest Eclipse 1175e Elliptical Trainers were recalled on December 11, 2007 for a fall hazard. During exercise, the foot pedal crank can break. After receiving 190 reports of the crank breaking, the company is offering a replacement product or credit toward other Fitness Quest products. If the pedal falls off, be sure to save it; you will need the right foot platform to claim the replacement or credit.
    Owners should stop using the elliptical trainer immediately. Owners can receive a replacement with another Fitness Quest product or credit.
    Eclipse Recall Instructions and Form (PDF)
    Questions? Contact Fitness Quest at: (800) 321-9236 between 8:30 a.m. and 8 p.m. ET, Monday through Friday. Or, e-mail productrecall@fitnessquest.com.
    The Fitness Quest Eclipse 1175e Elliptical Trainer was sold at major sporting goods chains, such as Sports Authority, Modell's, Dunhams, and JC Penney stores in the United States from September 2006 to October 2007. Sale prices were $290 and $450.
    E1 errors are usually lubrication/resistance issues. Has the unit been oiled/greased recently?
    Jan 10, 2009 | Fitness Quest Eclipse 1100 Hr/A Elliptical
    Proform Pro Form Elliptical Console 252257 Logo
    24 people viewed this question
    Top Proform Exercise & Fitness Experts
    Ross Metcalfe
    Ross Metcalfe
    Matt Olenzek
    Matt Olenzek
    Electro Med Services...
    Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
