Shower cuts out after few minutes
Do i need to check for limescale build up in the shower box unit?
  • 7,627 Answers
Wrong category
Posted on Jan 06, 2013
When I use the shower, the unit defaults to level I heating. Why is water not hot enough?
it probably has an anti-scald control in the shower line that lets cold water in to prevent burns
If so that unit has a wax bulb that sometimes fails and the default fail setting is cool water
have a plumber check it out
Dec 25, 2015 | Water Water Heaters
Hi, I have a Triton Spellbing Shower in my Loft. It comes up with 'CS' and a 'showerhead' symbol in red on the LCD display. Do I just remove the head from the shower and clean out any limescale or is...
Yes take the head and soak it in a lime,rust,calcium cleaner, they sell one at the dollar store in a brite yellow bottle for a few dollars called awsome all purpose cleaner
Mar 07, 2011 | Home
I have a Bush IN632 steam iron which is not generating steam. Can anyone point me in the correct direction as to what the fault may be?
took mine apart found that the base unit had limescale build up to such a level that the whole water chamber was full of limescale. Need a special security screwdriver
Jan 30, 2011 | Oreck TS100 Iron
Triton Ivory 2, 8.5 kw electric shower flow has been getting porgressively weaker. Mains pressure if fine. Shower head is clean.
there could be a blockage on cold water connection which may have a filter which needs cleaning or the heating tank inside the shower could be blocked with limescale try cleaning the filter you cvould also check the shower hose for blockages or kinks
Dec 09, 2010 | Home
I have a triton dart shower which is operated by turning a flow control block. This is so hard to turn that I sometimes struggle and my family require my assistance. It is just as difficult to turn off...
I can't offer you a solution but will say that I have the same problem with my Triton Dart. I have put it down to a build up of hard water inside the valve but not sure. Think I'm going to have to contact Triton under their warranty although they do say that they will not cover faults resulting from limescale.Great
Nov 09, 2010 | Home
I have a newly installed Bosch hot water heater. After installing, it seemed to be working fine. It is in a small weekly rental unit. If anything, the unit is over-sized for the demand. Now that it is...
these units need lots of flow to start and run. Set the temp on the unit lower and the people in the shower will have to use more hot and less cold which will make the unit more stable.
Jun 01, 2010 | Bosch & Tankless LP Hot Water Heater
We have an accessible curbless shower in our second home. At the moment no one's in a wheelchair; we made it accessible for possible future needs. The shower pan doesn't drain as well as it should, so when...
build it out of what ever u want thats water proof and use silicone to put in place just put bead around out side so when u want to remove it- use a razor to cut around and its out of the way
Mar 10, 2010 | Home
The shower no longer cuts off completely leaving a constant drip from the shower head. I disassembled the valve body and discovered an unusual plastic split plate gate valve system inside. It appears to...
If the Shower or any tap keeps dripping then its from were the cut off of water comes from and if 2 taps then its either the seal and the seat needs recutting so the answer is to get the plumber out to recut the seat
If a mixer tap then you will have to get a replacement unit.....sorry
Sep 24, 2009 | Home
I have a Triton topaz 100i shower, recently the water would not heat up, when i opened it the thermal cut out was in pieces, i have now replaced this, but now, no water comes out at all. If i short the...
its the thermal cut-out... when there is something like limescale that causes the temp to get over 50c - the thermal cut out is
activated... it has to be replaced... which u can buy it from triton or get an engineer out to replace it
tip... make sure u clean the shower and shower heads often with a limescale remover....
Apr 22, 2008 | Heating & Cooling
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
