Doesn't turn on unless I repeatedly hold the power button until the lights turn off and do it again usually takes around 4 times is this serious enough to return it or is this a simple fix?
This could be a software problem. If you added anything or got an update. Try powering it off and then start it again and when it starts select safe mode by pressing F8 immediately BEFORE WINDOWS starts. Then select restore and see if it lists any dates that you can set it back to that you know it worked in.
SOURCE: laptop doesn't start when power cord is plugged in
more than likely the charger is bad
Testimonial: "Can't say for sure if this is the solution until I change the charger, but it sounds logical ans is sure worth a try. Thanks! "
The battery might be nearing the end of it's useful life and needs to be replaced. The battery only lasts for so long then it has to be replaced.
Buy a battery on ebay base on your computer's Make and model, not the model of the battery.
SOURCE: how to fix ibm lenovo 300- g500 doesn't turn on
Try another cord? Another outlet? Has the AC jack been damaged due to a pull on the cord?
