Question about Karcher 2500 PSI Pressure Washer
Karcher HDS650 steam cleaner. I get white smoke when the burner strikes up, it does not get that hot although it does get very warm, also it surges as if the pump has no water in it, it does work but
Works but not as it should
4 Suggested Answers
  • 32 Answers
SOURCE: repair to old Karcher steam cleaner
q services settle north yorkshire.
01729825656
damian thats me
07970636222
Posted on Jul 04, 2009
SOURCE: Steam cleaner smokes likes mad
the air fuel mix is not correct. the coil is blocking the air intake. fuel nozzle not pointing into the combustion chamber?
Posted on Dec 14, 2009
  • 56 Answers
SOURCE: Hi, my Karcher steam cleaner is working ok apart
There can be multiple problems with the burner.
Here is a link to a page for troubleshooting burners.
link
Posted on Dec 23, 2009
THERE IS TOO MUCH WHITE SMOKE IN EXHAUST PIPE OF MY TOYOTA COROLLA 2E ENGINE WHAT CAN I DO
white smoke when starting from cold is
condensation of moisture in the muffler/ tail pipe
that is normal .... till the engine warms up
heaps of white smoke when hot
suggests coolant/steam in the combustion chamber
blue smoke is oil
black smoke is fuel
Nov 23, 2016 | Toyota Cars & Trucks
My karcher isn't giving me hot water why? It's a hds 601c
Morning Chris Taylor,
You have an igniter/burner coil inside your system that has to be
functioning properly to have good combustion going inside the coils of your heater unit (very bottom).
I tried to pull the documents to see if yours was kerosene powered (like mine: not a Karcher)... but could NOT pull your HDS 601C up on the company site (Karcher.com, sorry... It's me & my new PC).
Poor water = de-lime water coil procedure
Cool water = No combustion, check kerosene, oil (burner fuel)... filter... (etc.) and check your spark!
If your air supply is insufficient to support great combustion your ignitor & fuel nozzles can get heavily built up in soot. My manual says to clean it with detergent & water... I have only ever used Berryman choke & throttle body cleaner.
All the precautions... don't hurt yourself!!
Hope this helps...
KARCHER HDS 601c ECO STEAM CLEANER BOILER HEATING COIL ELEMENT HEATER...
Operating manuals
http://www.ultimatewasher.com/download/hot-water-manual.pdf
May 01, 2016 | Karcher Garden
Is it normal for my truck to smoke on a cold day even after truck has fully warmed up? Not thick smoke light white smoke thought it was suppose to stop after truck warmed up fully
white 'smoke' may be condensation (steam)? Did it do this in the summer as well? Even with a warm engine and hot exhaust the steam will still condense after it leaves the tailpipe on cold days. Your fuel contains water at microscopic level which is vaporised as part of the combustion process.
Dec 01, 2015 | Cars & Trucks
I would like a karcher instruction manual for a HDS650 pressure washer
I believe the HDS sends spark to the ignitor any time the machine is on ( hot or cold) You should hear the crackle of the ignitor in the burner area. Perhaps the ignitor rods are not properly aligned. Perhaps your ignitor coil is bad. There are several safety switches and the thermostat that would keep the burner from firing if they are bad. There is a pressure switch that turns on and off the motor for hot or cold operation. That is apparently working. I think there is a flow switch that turns off the burner. The thermostat might not be opening and closing contacts and that will keep the burner from working. I believe there is a high temperature safety switch as well.
Jul 15, 2014 | Garden
DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
May 05, 2010 | Karcher DE4002 Steam Vacuum
Smokes bad when burner kicks on
Hey mate,
What brand of burner are you running? I am a Karcher Tech but they all work on the same principle,
Your burner is getting to much diesel/kero, most have little flow swicthes on them to tell them to pump fuel or spark when there is water present in the burner coil, if this switch is faulty or getting a faulse reading then it will tell the unit to pump fuel when it is not needed and this will cause very excessive smoke for the first few mins when the burner kicks in...
If you have the excessive smoke continuously(even after 10 mins of continous use then it is probable that your fuel pump/system is running to rich, these units need regular servicing and adjustments as fuel nozzles/components wear,
There is alot of precise adjustments and checks on these units and i would reccommend getting it checked by a qualified tech, as when there is heated fuel and spark these units can be dangerous!
Hope this helps
Regards
Brad
Feb 03, 2010 | Northstar Electric Wet Steam & Hot Water...
Dec 13, 2009 | Karcher Garden
Ravenheat he85aaa combi boiler running fault
sounds like low water pressure, check pressure guage, get unit serviced
Nov 27, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Repair to old Karcher steam cleaner
01729825656
damian thats me
07970636222
Mar 13, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
187 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
