Question about Palm Treo 500 Centro
Palm does not support Windows Vista 64
I have a Palm Centro Smartphone. I upgraded to a new Dell desktop which came with Windows Vista. I tired to install the software for my phone and it would not run. It seems that Palm does not support Vista 64 (ridiculous) so I am told that if my desktop does not have bluetooth (it doesn't) I need to purchase a dongle to sync my phone to my computer. Is there any other fix?
  • Russ Andrews
    Russ Andrews May 11, 2010
    If your PC does not have Bluetooth...and you do not have a sync cable...what method are you using to sync these?
  • 47 Answers
Unfortuantely no.
Posted on Sep 28, 2009
Putting contacts on the SIM card
When I migrated from my Palm Centro (best smartphone ever) to my current BlackBerry, I did the following: 1) Export Palm contacts from the Palm Desktop software to CSV (comma separated values or tab-delimited text) format. 2) Import the CSV file to your Google Contacts account. 3) Wirelessly sync Google Contacts to your new phone using the free Google Sync app (link below). 4) Verify data was transferred appropriately.
Google Sync works with iPhones: http://www.google.com/mobile/sync/
You should be able to follow the same process for your Palm Calendar by exporting your Palm Calendar from the Palm Desktop software to a file (save the exported file to your desktop, or an easy to find location on your computer), then import the Calendar file into a NEW Google Calendar, not your primary calendar (in case there's conflicts or problems, you can delete the secondary Google calendar without losing your primary Google calendar items). Google Sync should allow you to choose more than one Google Calendar to sync with your iPhone.
Apr 25, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
Copy Contacts from Palm Centro to SIM Card
Google Sync details: http://www.google.com/mobile/sync/
You should be able to follow the same process for your Palm Calendar by exporting your Palm Calendar from the Palm Desktop software to a file (save the exported file to your desktop, or an easy to find location on your computer), then import the Calendar file into a NEW Google Calendar, not your primary calendar (in case there's conflicts or problems, you can delete the secondary Google calendar without losing your primary Google calendar items). Google Sync should allow you to choose more than one Google Calendar to sync with your new phone.
Dec 29, 2009 | Palm Treo 500 Centro
How do i tranfer my contacts from my palm centro & another palm centro?
First, make sure you backup all of your data, including data in any 3rd party apps.
Sync your first Palm Centro with the Palm Desktop software to save the data.
Verify the sync settings in the Palm Desktop software to make sure when you begin syncing with the new Palm Centro, the settings for each application (contacts, calendar, memos, etc.) are one-way sync to the device, or you might end up overwriting the data in your Palm Desktop software with what's on the new Palm Centro.
When you sync your new Palm Centro with the desktop software the first time it will ask you to name the new device. If you give it the same name as the old Palm Centro, all of the data will sync to your new Palm Centro.
Search your computer for a folder with the name "Palm" in it to try and locate the name of your old Palm Centro, so you can name the new Palm Centro the same. When you locate that folder on your computer, it would be a good idea to simply make a copy of that folder as a total backup.
Dec 22, 2009 | AT&T Palm Centro Cell Phone - White
How to sync Palm T3 to (Dell) 64 bit laptop via Bluetooth
if you are using 64 Bit operating system you may use following procedure
1) Start > Run > msiexec /unregister
2) In regedit, find the following key:
HKEY_LOCAL_MACHINE\
SOFTWARE\Microsoft\Windows\CurrentVersion\Installer
3) Change MsiExecCA64
From this: C:\WINDOWS\system32\msiexec.exe
To this: C:\WINDOWS\SysWOW64\msiexec.exe
(This assumes a default Windows directory.
Change to reflect your configuration if needed.)
4) Restart the Windows Installer service
(Control Panel > Administrative Tools > Services)
5) Install Palm Desktop!
To go back to the previous settings, just reverse the change made in the registry, and stop/start the service again.
You can also set it back to normal by re-registering the installer:
Start > Run > msiexec /register
Jul 11, 2009 | Palm Z22 Handheld
Error in Palm Desktop on PC
You need version Palm desktop v6.2 (not v4) to run under Vista. If you have the 64 bit version of Vista you will have to use Bluetooth to transfer data, not USB. Enjoy and please rate this post.
Mar 21, 2009 | Palm Tungsten T3 Handheld
Won't load documents to go therefore I can't transfer documents
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista.
Jan 11, 2009 | Palm Tungsten E2 (Multilingual) Handheld
USB Device Not Recognized for Palm Treo 680
if you are using Vista ultimate, it is a 64 bit operating system and therefore palm doesn't have official support for it yet, but someone has found a solution:
http://forums.palm.com/palm/board/message?board.id=windows_hotsync&thread.id=17980
Jul 19, 2008 | Palm Treo 680 Smartphone
Palm Treo 500 Centro Logo
91 people viewed this question
Top Palm Computers & Internet Experts
MUSTAFA BULENT...
MUSTAFA BULENT...
David Payne
David Payne
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
